calander not working
Posted: Wednesday 27 January 2021 18:04
by Jaccovr
hi, im not a newbe but i just cant figer out wy my calander wil not show my apointments,
i have read all logs and look into (F12 and look for error) if i use outlook. i receive thiss error:
Exception: DateTimeZone::__construct(): Unknown or bad timezone (Customized Time Zone) in /var/www/html/vendor/dashticz/ical/vendor/om/icalparser/src/IcalParser.php:260
Stack trace:
#0 /var/www/html/vendor/dashticz/ical/vendor/om/icalparser/src/IcalParser.php(260): DateTimeZone->__construct('Customized Time...')
#1 /var/www/html/vendor/dashticz/ical/vendor/om/icalparser/src/IcalParser.php(131): om\IcalParser->parseRow('TZID:Customized...')
#2 /var/www/html/vendor/dashticz/ical/vendor/om/icalparser/src/IcalParser.php(47): om\IcalParser->parseString('BEGIN:VCALENDAR...', NULL)
#3 /var/www/html/vendor/dashticz/ical/index.php(71): om\IcalParser->parseFile('https://outlook...')
#4 main
and if i use hotmail i receive thiss error:
if i look in the pi i cant find anny folders in :
/var/www/html/vendor/dashticz/ical/vendor/om/icalparser/src//vendor/dashticz/ical/vendor/om/icalparser/src/
folder structure stops @
/var/www/html
my popup calander works good? (use v3.7.3 beta)
anny help wil be good!
Marcel
Re: calander not working
Posted: Wednesday 27 January 2021 19:36
by Lokonli
Jaccovr wrote: Wednesday 27 January 2021 18:04 hi, im not a newbe but i just cant figer out wy my calander wil not show my apointments,
Stack trace:
#4 main
/var/www/html
Marcel
On the folder structure: You used the automatic install?
Then dashticz runs in a Docker container. Your 'local' Dashticz home folder, for instance /home/pi/dashticz is mapped to /var/www/html in the Docker container. So the files your are looking for can be found in /home/pi/dashticz
For the first calendar:
It seems that a timezone is used, which is not recognized by the icalparser.
It's relatively easy to add a new timezone, but I have to know the exact timezone string.
Can you download the ical file, open it in a text editor, and search for the timezone label?
Alternative:
Add the following block parameter to the calendar block:
method: 0
Then the 'old' PHP ical library is used. It probably will work, but there might be some issues with recurring events.
For the hotmail calendar:
Open the icalurl in a browser. Do you receive an ical file? Open the ical file in a text editor. Does it look like ical format? Does it contain appointments in the future?
Test.
Test a calendar block with the following icalurl. This one is working:
icalurl: 'https://racingnews365.nl/ics/download/calendar-formula-2021.ics?all'
Posted: Wednesday 27 January 2021 20:07
by Jaccovr
hi,
this is my icalparser file:
<?php
namespace om;
use DateInterval;
use DateTime;
use DateTimeZone;
use Exception;
use InvalidArgumentException;
use RuntimeException;
 * Copyright (c) 2004-2020 Roman Ožana (https://www.omdesign.cz)
 * @author Roman Ožana <[email protected]>
class IcalParser {
	/** @var DateTimeZone */
	public $timezone;
	/** @var array */
	public $data = [];
	/** @var array */
	protected $counters = [];
	/** @var array */
	private $windowsTimezones;
	public function __construct() {
		$this->windowsTimezones = require __DIR__ . '/WindowsTimezones.php'; // load Windows timezones from separate file
	 * @param string $file
	 * @param callable|null $callback
	 * @return array|null
	 * @throws Exception
	public function parseFile(string $file, callable $callback = null): array {
		if (!$handle = fopen($file, 'r')) {
			throw new RuntimeException('Can\'t open file' . $file . ' for reading');
		fclose($handle);
		return $this->parseString(file_get_contents($file), $callback);
	 * @param string $string
	 * @param callable $callback
	 * @param boolean $add if true the parsed string is added to existing data
	 * @throws Exception
	public function parseString(string $string, callable $callback = null, bool $add = false): ?array {
		if ($add === false) {
			// delete old data
			$this->data = [];
			$this->counters = [];
		if (!preg_match('/BEGIN:VCALENDAR/', $string)) {
			throw new InvalidArgumentException('Invalid ICAL data format');
		$section = 'VCALENDAR';
		// Replace \r\n with \n
		$string = str_replace("\r\n", "\n", $string);
		// Unfold multi-line strings
		$string = str_replace("\n ", '', $string);
		foreach (explode("\n", $string) as $row) {
			switch ($row) {
				case 'BEGIN:DAYLIGHT':
				case 'BEGIN:VALARM':
				case 'BEGIN:VTIMEZONE':
				case 'BEGIN:VFREEBUSY':
				case 'BEGIN:VJOURNAL':
				case 'BEGIN:STANDARD':
				case 'BEGIN:VTODO':
				case 'BEGIN:VEVENT':
					$section = substr($row, 6);
					$this->counters[$section] = isset($this->counters[$section]) ? $this->counters[$section] + 1 : 0;
					continue 2; // while
					break;
				case 'END:VEVENT':
					$section = substr($row, 4);
					$currCounter = $this->counters[$section];
					$event = $this->data[$section][$currCounter];
					if (!empty($event['RECURRENCE-ID'])) {
						$this->data['_RECURRENCE_IDS'][$event['RECURRENCE-ID']] = $event;
					break;
				case 'END:DAYLIGHT':
				case 'END:VALARM':
				case 'END:VTIMEZONE':
				case 'END:VFREEBUSY':
				case 'END:VJOURNAL':
				case 'END:STANDARD':
				case 'END:VTODO':
					break;
				case 'END:VCALENDAR':
					$veventSection = 'VEVENT';
					if (!empty($this->data[$veventSection])) {
						foreach ($this->data[$veventSection] as $currCounter => $event) {
							if (!empty($event['RRULE']) || !empty($event['RDATE'])) {
								$recurrences = $this->parseRecurrences($event);
								if (!empty($recurrences)) {
									$this->data[$veventSection][$currCounter]['RECURRENCES'] = $recurrences;
								if (!empty($event['UID'])) {
									$this->data["_RECURRENCE_COUNTERS_BY_UID"][$event['UID']] = $currCounter;
					break;
			[$key, $middle, $value] = $this->parseRow($row);
			if ($callback) {
				// call user function for processing line
				call_user_func($callback, $row, $key, $middle, $value, $section, $this->counters[$section]);
			} else {
				if ($section === 'VCALENDAR') {
					$this->data[$key] = $value;
				} else {
					// use an array since there can be multiple entries for this key.  This does not
					// break the current implementation--it leaves the original key alone and adds
					// a new one specifically for the array of values.
					if ($newKey = $this->isMultipleKey($key)) {
						$this->data[$section][$this->counters[$section]][$newKey][] = $value;
					// CATEGORIES can be multiple also but there is special case that there are comma separated categories
					if ($this->isMultipleKeyWithCommaSeparation($key)) {
						if (strpos($value, ',') !== false) {
							$values = array_map('trim', preg_split('/(?<![^\\\\]\\\\),/', $value));
						} else {
							$values = [$value];
						foreach ($values as $value) {
							$this->data[$section][$this->counters[$section]][$key][] = $value;
					} else {
						$this->data[$section][$this->counters[$section]][$key] = $value;
		return ($callback) ? null : $this->data;
	 * @param $event
	 * @return array
	 * @throws Exception
	public function parseRecurrences($event): array {
		$recurring = new Recurrence($event['RRULE']);
		$exclusions = [];
		$additions = [];
		if (!empty($event['EXDATES'])) {
			foreach ($event['EXDATES'] as $exDate) {
				if (is_array($exDate)) {
					foreach ($exDate as $singleExDate) {
						$exclusions[] = $singleExDate->getTimestamp();
				} else {
					$exclusions[] = $exDate->getTimestamp();
		if (!empty($event['RDATES'])) {
			foreach ($event['RDATES'] as $rDate) {
				if (is_array($rDate)) {
					foreach ($rDate as $singleRDate) {
						$additions[] = $singleRDate->getTimestamp();
				} else {
					$additions[] = $rDate->getTimestamp();
		$until = $recurring->getUntil();
		if ($until === false) {
			//forever... limit to 3 years from now
			$end = new DateTime('now');
			$end->add(new DateInterval('P3Y')); // + 3 years
			$recurring->setUntil($end);
		date_default_timezone_set($event['DTSTART']->getTimezone()->getName());
		$frequency = new Freq($recurring->rrule, $event['DTSTART']->getTimestamp(), $exclusions, $additions);
		$recurrenceTimestamps = $frequency->getAllOccurrences();
		$recurrences = [];
		foreach ($recurrenceTimestamps as $recurrenceTimestamp) {
			$tmp = new DateTime('now', $event['DTSTART']->getTimezone());
			$tmp->setTimestamp($recurrenceTimestamp);
			$recurrenceIDDate = $tmp->format('Ymd');
			$recurrenceIDDateTime = $tmp->format('Ymd\THis');
			if (empty($this->data['_RECURRENCE_IDS'][$recurrenceIDDate]) &&
				empty($this->data['_RECURRENCE_IDS'][$recurrenceIDDateTime])) {
				$gmtCheck = new DateTime('now', new DateTimeZone('UTC'));
				$gmtCheck->setTimestamp($recurrenceTimestamp);
				$recurrenceIDDateTimeZ = $gmtCheck->format('Ymd\THis\Z');
				if (empty($this->data['_RECURRENCE_IDS'][$recurrenceIDDateTimeZ])) {
					$recurrences[] = $tmp;
		return $recurrences;
	private function parseRow($row): array {
		preg_match('#^([\w-]+);?([\w-]+="[^"]*"|.*?):(.*)$#i', $row, $matches);
		$key = false;
		$middle = null;
		$value = null;
		if ($matches) {
			$key = $matches[1];
			$middle = $matches[2];
			$value = $matches[3];
			$timezone = null;
			if ($key === 'X-WR-TIMEZONE' || $key === 'TZID') {
				if (preg_match('#(\w+/\w+)$#i', $value, $matches)) {
					$value = $matches[1];
				$value = $this->toTimezone($value);
				$this->timezone = new DateTimeZone($value);
			// have some middle part ?
			if ($middle && preg_match_all('#(?<key>[^=;]+)=(?<value>[^;]+)#', $middle, $matches, PREG_SET_ORDER)) {
				$middle = [];
				foreach ($matches as $match) {
					if ($match['key'] === 'TZID') {
						$match['value'] = trim($match['value'], "'\"");
						$match['value'] = $this->toTimezone($match['value']);
						try {
							$middle[$match['key']] = $timezone = new DateTimeZone($match['value']);
						} catch (Exception $e) {
							$middle[$match['key']] = $match['value'];
					} elseif ($match['key'] === 'ENCODING') {
						if ($match['value'] === 'QUOTED-PRINTABLE') {
							$value = quoted_printable_decode($value);
		// process simple dates with timezone
		if (in_array($key, ['DTSTAMP', 'LAST-MODIFIED', 'CREATED', 'DTSTART', 'DTEND'], true)) {
			try {
				$value = new DateTime($value, ($timezone ?: $this->timezone));
				$value = null;
		} elseif (in_array($key, ['EXDATE', 'RDATE'])) {
			$values = [];
			foreach (explode(',', $value) as $singleValue) {
				try {
					$values[] = new DateTime($singleValue, ($timezone ?: $this->timezone));
					// pass
			if (count($values) === 1) {
				$value = $values[0];
			} else {
				$value = $values;
		if ($key === 'RRULE' && preg_match_all('#(?<key>[^=;]+)=(?<value>[^;]+)#', $value, $matches, PREG_SET_ORDER)) {
			$middle = null;
			$value = [];
				if (in_array($match['key'], ['UNTIL'])) {
					try {
						$value[$match['key']] = new DateTime($match['value'], ($timezone ?: $this->timezone));
						$value[$match['key']] = $match['value'];
				} else {
		//implement 4.3.11 Text ESCAPED-CHAR
		$text_properties = [
			'CALSCALE', 'METHOD', 'PRODID', 'VERSION', 'CATEGORIES', 'CLASS', 'COMMENT', 'DESCRIPTION',
			'LOCATION', 'RESOURCES', 'STATUS', 'SUMMARY', 'TRANSP', 'TZID', 'TZNAME', 'CONTACT',
			'RELATED-TO', 'UID', 'ACTION', 'REQUEST-STATUS', 'URL',
		if (in_array($key, $text_properties) || strpos($key, 'X-') === 0) {
			if (is_array($value)) {
				foreach ($value as &$var) {
					$var = strtr($var, ['\\\\' => '\\', '\\N' => "\n", '\\n' => "\n", '\\;' => ';', '\\,' => ',']);
			} else {
				$value = strtr($value, ['\\\\' => '\\', '\\N' => "\n", '\\n' => "\n", '\\;' => ';', '\\,' => ',']);
		return [$key, $middle, $value];
	 * Process timezone and return correct one...
	 * @param string $zone
	 * @return mixed|null
	private function toTimezone(string $zone) {
		return $this->windowsTimezones[$zone] ?? $zone;
	public function isMultipleKey(string $key): ?string {
		return (['ATTACH' => 'ATTACHMENTS', 'EXDATE' => 'EXDATES', 'RDATE' => 'RDATES'])[$key] ?? null;
	 * @param $key
	 * @return string|null
	public function isMultipleKeyWithCommaSeparation($key): ?string {
		return (['X-CATEGORIES' => 'X-CATEGORIES', 'CATEGORIES' => 'CATEGORIES'])[$key] ?? null;
	public function getAlarms(): array {
		return $this->data['VALARM'] ?? [];
	public function getTimezone(): array {
		return $this->getTimezones();
	public function getTimezones(): array {
		return $this->data['VTIMEZONE'] ?? [];
	 * Return sorted event list as array
	public function getSortedEvents(): array {
		if ($events = $this->getEvents()) {
			usort(
				$events,
				static function ($a, $b): int {
					return ($a['DTSTART'] > $b['DTSTART']) ? 1 : -1;
			return $events;
		return [];
	public function getEvents(): array {
		$events = [];
		if (isset($this->data['VEVENT'])) {
			for ($i = 0; $i < count($this->data['VEVENT']); $i++) {
				$event = $this->data['VEVENT'][$i];
				if (empty($event['RECURRENCES'])) {
					if (!empty($event['RECURRENCE-ID']) && !empty($event['UID']) && isset($event['SEQUENCE'])) {
						$modifiedEventUID = $event['UID'];
						$modifiedEventRecurID = $event['RECURRENCE-ID'];
						$modifiedEventSeq = intval($event['SEQUENCE'], 10);
						if (isset($this->data['_RECURRENCE_COUNTERS_BY_UID'][$modifiedEventUID])) {
							$counter = $this->data['_RECURRENCE_COUNTERS_BY_UID'][$modifiedEventUID];
							$originalEvent = $this->data['VEVENT'][$counter];
							if (isset($originalEvent['SEQUENCE'])) {
								$originalEventSeq = intval($originalEvent['SEQUENCE'], 10);
								$originalEventFormattedStartDate = $originalEvent['DTSTART']->format('Ymd\THis');
								if ($modifiedEventRecurID === $originalEventFormattedStartDate && $modifiedEventSeq > $originalEventSeq) {
									// this modifies the original event
									$modifiedEvent = array_replace_recursive($originalEvent, $event);
									$this->data['VEVENT'][$counter] = $modifiedEvent;
									foreach ($events as $z => $event) {
										if ($events[$z]['UID'] === $originalEvent['UID'] &&
											$events[$z]['SEQUENCE'] === $originalEvent['SEQUENCE']) {
											// replace the original event with the modified event
											$events[$z] = $modifiedEvent;
											break;
									$event = null; // don't add this to the $events[] array again
								} elseif (!empty($originalEvent['RECURRENCES'])) {
									for ($j = 0; $j < count($originalEvent['RECURRENCES']); $j++) {
										$recurDate = $originalEvent['RECURRENCES'][$j];
										$formattedStartDate = $recurDate->format('Ymd\THis');
										if ($formattedStartDate === $modifiedEventRecurID) {
											unset($this->data['VEVENT'][$counter]['RECURRENCES'][$j]);
											$this->data['VEVENT'][$counter]['RECURRENCES'] = array_values($this->data['VEVENT'][$counter]['RECURRENCES']);
											break;
					if (!empty($event)) {
						$events[] = $event;
				} else {
					$recurrences = $event['RECURRENCES'];
					$event['RECURRING'] = true;
					$event['DTEND'] = !empty($event['DTEND']) ? $event['DTEND'] : $event['DTSTART'];
					$eventInterval = $event['DTSTART']->diff($event['DTEND']);
					$firstEvent = true;
					foreach ($recurrences as $j => $recurDate) {
						$newEvent = $event;
						if (!$firstEvent) {
							unset($newEvent['RECURRENCES']);
							$newEvent['DTSTART'] = $recurDate;
							$newEvent['DTEND'] = clone($recurDate);
							$newEvent['DTEND']->add($eventInterval);
						$newEvent['RECURRENCE_INSTANCE'] = $j;
						$events[] = $newEvent;
						$firstEvent = false;
		return $events;
	public function getReverseSortedEvents(): array {
			usort(
				$events,
					return ($a['DTSTART'] < $b['DTSTART']) ? 1 : -1;
			return $events;
		return [];
if i use method :0 i get thiss error
<br />
<b>Fatal error</b>: Array and string offset access syntax with curly braces is no longer supported in <b>/var/www/html/vendor/dashticz/ical/ical5/helpers/SG_iCal_Duration.php</b> on line <b>44</b><br />
what do i need to change on the file?
thanks
Posted: Wednesday 27 January 2021 20:21
by Lokonli
The icalparser file I know :). I mean the link you use for icalurl.
With method:0 the 'ical5' module is used.
Unfortunately, your PHP version is relatively new. The ical5 module doesn't work anymore on your system, and we have to use method:1 (=default)
So that also means that we have to fix the new ical module by adding the timezone info.
If you send me the icalurl parameter by PM I can have a look.
Posted: Wednesday 27 January 2021 20:43
by Jaccovr
if i use the working link i get this and no info on my dash:
<br />
<b>Warning</b>:  Undefined array key "DESCRIPTION" in <b>/var/www/html/vendor/dashticz/ical/index.php</b> on line <b>87</b><br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
{"1616756400":{"id":0,"title":"RN365 Bahrein - Eerste vrije training","desc":null,"location":"Bahrein International Circuit, sakhir","start":1616756400,"end":1616761800,"allDay":false},"1616770800":{"id":1,"title":"RN365 Bahrein - Tweede vrije training","desc":null,"location":"Bahrein International Circuit, sakhir","start":1616770800,"end":1616776200,"allDay":false},"1616842800":{"id":2,"title":"RN365 Bahrein - Derde vrije training","desc":null,"location":"Bahrein International Circuit, sakhir","start":1616842800,"end":1616842800,"allDay":false},"1616853600":{"id":3,"title":"RN365 Bahrein - Kwalificatie","desc":null,"location":"Bahrein International Circuit, sakhir","start":1616853600,"end":1616857200,"allDay":false},"1616937000":{"id":4,"title":"RN365 Bahrein - Race","desc":null,"location":"Bahrein International Circuit, sakhir","start":1616937000,"end":1616944200,"allDay":false},"1618560000":{"id":5,"title":"RN365 Emilia-Romagna - Eerste vrije training","desc":null,"location":"Autodromo Enzo e Dino Ferrari, imola","start":1618560000,"end":1618565400,"allDay":false},"1618574400":{"id":6,"title":"RN365 Emilia-Romagna - Tweede vrije training","desc":null,"location":"Autodromo Enzo e Dino Ferrari, imola","start":1618574400,"end":1618579800,"allDay":false},"1618650000":{"id":7,"title":"RN365 Emilia-Romagna - Derde vrije training","desc":null,"location":"Autodromo Enzo e Dino Ferrari, imola","start":1618650000,"end":1618653600,"allDay":false},"1618660800":{"id":8,"title":"RN365 Emilia-Romagna - Kwalificatie","desc":null,"location":"Autodromo Enzo e Dino Ferrari, imola","start":1618660800,"end":1618660800,"allDay":false},"1618744200":{"id":9,"title":"RN365 Emilia-Romagna - Race","desc":null,"location":"Autodromo Enzo e Dino Ferrari, imola","start":1618744200,"end":1618751400,"allDay":false}}
