Python plugin Segmentation fault
Posted: Tuesday 26 January 2021 19:11
I have a strange problem. I'm trying to develop af Python Plugin and every time i change ant parameters the plugin creates a segmentation fault. Even the base plugin template create a seg. fault when stopping the plugin. The log shows this:
domoticz (build 12839) are homecompiled on a fully updated Fedora 33 system with this commandline:
Can someone tell me what I'm doing wrong og tell me what I'm missing
2021-01-26 18:55:05.541 (Test) Processing 'onStopCallback' message
2021-01-26 18:55:05.541 (Test) Calling message handler 'onStop'.
2021-01-26 18:55:05.541 (Test) ==================================================
2021-01-26 18:55:05.541 (Test) onStop called
Fatal Python error: Segmentation fault
Thread 0x00007f0f14621880 (most recent call first):
<no Python frame>
2021-01-26 18:55:05.545 Error: Domoticz(pid:413010, tid:413013('PluginMgr')) received fatal signal 11 (Segmentation fault)
2021-01-26 18:55:05.545 Error: siginfo address=0x64d52, address=0x7f0f145dc065
2021-01-26 18:55:05.559 Error: Failed to start gdb, will use backtrace() for printing stack frame
2021-01-26 18:55:05.578 Error: #0 /home/users/peterm/udvikling/domoticz/domoticz_test/usr/bin/domoticz() [0xdc4e2c]
2021-01-26 18:55:05.578 Error: #1 /home/users/peterm/udvikling/domoticz/domoticz_test/usr/bin/domoticz() [0xdc50a4]
2021-01-26 18:55:05.578 Error: #2 /home/users/peterm/udvikling/domoticz/domoticz_test/usr/bin/domoticz : signal_handler(int, siginfo_t*, void*) + 0x216 [0xdc52bd]
2021-01-26 18:55:05.578 Error: #3 /lib64/libpthread.so.0 : + 0x141e0 [0x7f0f145dc1e0]
2021-01-26 18:55:05.578 Error: #4 /lib64/libpthread.so.0 : raise + 0x145 [0x7f0f145dc065]
2021-01-26 18:55:05.578 Error: #5 /lib64/libpthread.so.0 : + 0x141e0 [0x7f0f145dc1e0]
2021-01-26 18:55:05.578 Error: #6 /lib64/libpython3.9.so : PyEval_ReleaseLock + 0x19 [0x7f0f1368cde0]
2021-01-26 18:55:05.578 Error: #7 /home/users/peterm/udvikling/domoticz/domoticz_test/usr/bin/domoticz : Plugins::CPlugin::Stop() + 0x128 [0x122fe8a]
2021-01-26 18:55:05.578 Error: #8 /home/users/peterm/udvikling/domoticz/domoticz_test/usr/bin/domoticz : Plugins::onStopCallback::ProcessLocked() + 0x38 [0x12335d8]
2021-01-26 18:55:05.578 Error: #9 /home/users/peterm/udvikling/domoticz/domoticz_test/usr/bin/domoticz : Plugins::CPluginMessageBase::Process() + 0x45 [0xd00d03]
2021-01-26 18:55:05.578 Error: #10 /home/users/peterm/udvikling/domoticz/domoticz_test/usr/bin/domoticz : Plugins::CPluginSystem::Do_Work() + 0x339 [0x1239bb5]
2021-01-26 18:55:05.578 Error: #11 /home/users/peterm/udvikling/domoticz/domoticz_test/usr/bin/domoticz : void std::__invoke_impl<void, void (Plugins::CPluginSystem::*)(), Plugins::CPluginSystem*>(std::__invoke_memfun_deref, void (Plugins::CPluginSystem::*&&)(), Plugins::CPluginSystem*&&) + 0x67 [0x123ffa3]
2021-01-26 18:55:05.578 Error: #12 /home/users/peterm/udvikling/domoticz/domoticz_test/usr/bin/domoticz : std::__invoke_result<void (Plugins::CPluginSystem::*)(), Plugins::CPluginSystem*>::type std::__invoke<void (Plugins::CPluginSystem::*)(), Plugins::CPluginSystem*>(void (Plugins::CPluginSystem::*&&)(), Plugins::CPluginSystem*&&) + 0x37 [0x123fee5]
2021-01-26 18:55:05.578 Error: #13 /home/users/peterm/udvikling/domoticz/domoticz_test/usr/bin/domoticz : void std::thread::_Invoker<std::tuple<void (Plugins::CPluginSystem::*)(), Plugins::CPluginSystem*> >::_M_invoke<0ul, 1ul>(std::_Index_tuple<0ul, 1ul>) + 0x43 [0x123fe55]
2021-01-26 18:55:05.578 Error: #14 /home/users/peterm/udvikling/domoticz/domoticz_test/usr/bin/domoticz : std::thread::_Invoker<std::tuple<void (Plugins::CPluginSystem::*)(), Plugins::CPluginSystem*> >::operator()() + 0x18 [0x123fe0e]
2021-01-26 18:55:05.578 Error: #15 /home/users/peterm/udvikling/domoticz/domoticz_test/usr/bin/domoticz : std::thread::_State_impl<std::thread::_Invoker<std::tuple<void (Plugins::CPluginSystem::*)(), Plugins::CPluginSystem*> > >::_M_run() + 0x1c [0x123fd7e]
2021-01-26 18:55:05.578 Error: #16 /lib64/libstdc++.so.6 : + 0xd65f4 [0x7f0f1433e5f4]
2021-01-26 18:55:05.578 Error: #17 /lib64/libpthread.so.0 : + 0x93f9 [0x7f0f145d13f9]
2021-01-26 18:55:05.578 Error: #18 /lib64/libc.so.6 : clone + 0x43 [0x7f0f14031903]
_test_run_domoticz.sh: line 42: 413010 Segmentation fault (core dumped) ${_PRG_TEST} -approot $USERDATA -www $WWW_PORT -sslwww $SSL_PORT -sslcert $SSLCERT -sslpass $SSLPASS -sslmethod $SSLMETHOD -ssloptions $SSLOPTIONS -ssldhparam $SSLDHPARAM -wwwroot $WWW_ROOT -dbase $DBASE -userdata $USERDATA -verbose $VERBOSE -log $LOG -loglevel $LOGLEVEL -debug
cmake CMakeLists.txt \
-DUSE_STATIC_LIBSTDCXX=NO \
-DUSE_STATIC_OPENZWAVE=YES \
-DUSE_STATIC_BOOST=NO \
-DUSE_OPENSSL_STATIC=NO \
-DUSE_BUILTIN_MQTT=NO \
-DUSE_BUILTIN_SQLITE=NO
make
