I have an RFXCOM which I use to control my Somfy shutters, for which a rolling code is implemented. No problems there.
I am now looking to get my garage door to work on the same principle.
There are a number of 433Mhz offerings over on amazon.de, such as this one :
https://www.amazon.de/-/en/Universal-Ra ... r_hp_atf_m
Any ideas whether this would work with an RFXCOM?
Is there any alternative to this? Given it's a door, security is paramount. Whatever solution exists, I will be needing matching remotes which operate on the door directly. Not just via Domoticz (which for security reasons I may not even allow it to open the door but only close).
cheers,
Claude
RFXCOM Garage Door with Rolling Code
ccaru
RFXCom, Somfy RTS, 433Mhz Lighting, Evohome, Smart watering via Netatmo, solenoid valves, soil humidity sensors, Airthings Radon via bluetooth, Marley heat recovery fresh air units, Blue Iris, Alexa via DA Bridge.
