How to read and write a Domoticz variable with dzVents  [Solved]
gschmidt
Post by gschmidt »
I am trying to create a doorbell dzVents script. (I have a working blockly version)
The doorbell device is an RFXtrx433XL device (cheap Action stuff)
When pressed (depending on the pressure) it sends in a few milliseconds a few On commands.
So a domoticz variable is used to turn on a virtual on/off switch which sends a voice command to my google homes (in node-red)
The script is not working though because can't find how to access (read and write) the domoticz variable "deurbellen"
This my current script but apparently the "variable" method I use is not correct.
-- Send Telegram Notification if Deurbel (RFXtrx433XL) is turned on
-- and also turns on a virtual on/off switch which activates a google home voice command in node-red
   on =
        devices = {'Deurbel'}
        variables = { 'deurbellen' }
   execute = function(dz, variable)
        local Switch = dz.devices('Bel_Schakelaar')
        local Security = dz.devices('Deurbel Security')
        if dz.devices('Deurbel').state == "On" and variable.value == 'Niet aangebeld' then
            variable.set('Er wordt aangebeld')
            Switch.cancelQueuedCommands()
            Switch.switchOn()
            dz.notify(Switch.name,'Er wordt aangebeld!', dz.PRIORITY_NORMAL,'','',dz.NSS_TELEGRAM)
            dz.log('Device ' .. Switch.name .. ' state: ' .. Switch.state, dz.LOG_INFO)
            Switch.switchOff().afterSec(8)
            Security.switchNormal().afterSec(8)
            variable.set('Niet aangebeld').afterSec(10)
How can I read and write the value of a Domoticz variable?
Re: How to read and write a Domoticz variable with dzVents
gschmidt wrote: Saturday 23 January 2021 13:49 The script is not working though because can't find how to access (read and write) the domoticz variable "deurbellen"
Can you try this ?
I commented the line
because switchNormal() is not a dzVents method and I don't know what you want with this.
return
   on =
        devices =
            'Deurbel',
   logging =
        level = domoticz.LOG_DEBUG,
        marker = 'deurbel',
   execute = function(dz, item)
        local deurState = dz.variables('Deurbellen')
        local deurbel = dz.devices('Deurbel')
        if deurbel.state == "On" and deurState.value == 'Niet aangebeld' then
            deurState.set('Er wordt aangebeld')
            Switch.switchOn()
            -- Security.switchNormal().afterSec(8) -- SwitchNormal is not a dzVents command
            deurState.set('Niet aangebeld').afterSec(10)
gschmidt
Post by gschmidt »
waaren wrote: Saturday 23 January 2021 15:00
Can you try this ?
return
   on =
        devices =
            'Deurbel',
   logging =
        marker = 'deurbel',
            Switch.switchOn()
Thanx man! When I learned the doorbell in domoticz, 2 devices were created: doorbell device and a security device.
If the doorbell is physically pressed the doorbell device is turned on but also the security device is set to alarm.
So I want to set this alarm back to Normal To sync this device with the doorbell.
What is the command to do this then?
Hmmm...now that I mention it, maybe I could use the alarm device instead of the virtual switch to trigger the voice alarm in node-red. This would save an extra domoticz (virtual) device
gschmidt wrote: Sunday 24 January 2021 9:34 When I learned the doorbell in domoticz, 2 devices were created: doorbell device and a security device.
What is the type and subtype of this device (taken from the devices tab) ?
gschmidt
Post by gschmidt »
waaren wrote: Sunday 24 January 2021 10:33
Type: Security
SubType: X10 Security
gschmidt wrote: Sunday 24 January 2021 13:02 Type: Security
can you try with
Security.update(0).afterSec(8)
gschmidt
Re: How to read and write a Domoticz variable with dzVents  [Solved]
Post by gschmidt »
waaren wrote: Sunday 24 January 2021 14:00
can you try with
Working thanx!
