Problem using Costum sensor  [Solved]
YOYO
Domoticz version: V2.23393
Post by YOYO »
Im trying to get data from my wMbus to do some calculations.
In order to do this i'm pushing data using MQTT to a Costum device which i then want to use in a dzvents script.
Unfortunately i cant use any data not even with a simple print script.
I tried different sollutions including the stuff provided in the wiki but i cant get it to work.
Can somebody help me on my wayy?
Script to run:
		timer = {
			'every minute',              -- causes the script to be called every minute
	execute = function(domoticz, timer)
local TempInSensor = 'Stadsverwarming Aanvoer'
local TempOutSensor = domoticz.devices(248)
local Temp_IN = tonumber(TempInSensor.state)
local Temp_Retour = tonumber(TempOutSensor.state)
print('Temp In' .. TEMP_IN .. '°C' )
--local Delta_T = Temp_In -  Temp_Retour
--print('Delta T van Stadsverwarming =' .. Delta_T ..'°C' )
--local Water_M = 1000 * ((domoticz.devices(246).nValue) / 3600)
--print('Watermassa van Stadsverwarming =' .. Water_M .. 'kg')
--local Actueel_Vermogen = Water_M * 4180 * Delta_T
-- print('Actueel vermogen van Stadsverwarming =' .. Actueel_Vermogen .. 'kW')
Error code:
2021-01-20 10:23:00.141 Error: dzVents: Error: (3.0.2) /config/scripts/dzVents/generated_scripts/Script #3.lua:13: attempt to concatenate a nil value (global 'TEMP_IN')
Re: Problem using Costum sensor
YOYO wrote: Wednesday 20 January 2021 10:30 Can somebody help me on my wayy?
Error code:
Can you try this one?
btw what type of devices are these?
If they are temperature sensors you don't have to use the generic state but can use the temperature attribute.
return
    on =
        timer =
    logging =
        level = domoticz.LOG_DEBUG,
        marker = 'Stadsverwarming',
        local TempInSensor = domoticz.devices('Stadsverwarming Aanvoer')
        local Temp_IN = TempInSensor.state
        domoticz.log('Temp In ' .. TEMP_IN .. ' °C' , domoticz.LOG_FORCE )
YOYO
Post by YOYO »
Hi Waaren,
Here is the result for youre code:
 2021-01-20 11:19:00.267 Error: dzVents: Error: (3.0.2) /config/scripts/dzVents/generated_scripts/Script #3.lua:13: attempt to concatenate a nil value (global 'TEMP_IN')
2021-01-20 11:19:00.268 Error: dzVents: Error: (3.0.2) Stadsverwarming: An error occurred when calling event handler Script #4
2021-01-20 11:19:00.268 Error: dzVents: Error: (3.0.2) Stadsverwarming: /config/scripts/dzVents/generated_scripts/Script #4.lua:24: attempt to concatenate a nil value (global 'TEMP_IN')
Its a costum sensor.
Here is the device info:
idx		Hardware		ID		UNIT		Name		Type		Subtype		Data
248		wmbus sensoren		00082248		1		Stadsverwarming Retour		General		Custom Sensor		22.32 °C
YOYO wrote: Wednesday 20 January 2021 11:26
Case matters !
Change
to
        domoticz.log('Temp In ' .. Temp_IN .. ' °C' , domoticz.LOG_FORCE )
YOYO
Re: Problem using Costum sensor  [Solved]
Post by YOYO »
Yes thats giving something:
 2021-01-20 12:12:00.293 Status: dzVents: Info: Stadsverwarming: ------ Start internal script: Script #4:, trigger: "every minute"
2021-01-20 12:12:00.293 Status: dzVents: !Info: Stadsverwarming: Temp In 69.38 °C
2021-01-20 12:12:00.293 Status: dzVents: Info: Stadsverwarming: ------ Finished Script #4
YOYO
Post by YOYO »
@waaren
You where right checked the whole script on typ errors and found some.
Many thanks! :D
