Open Weather Map language Topic is solved
JanvdW
In the Open Weather Map configuration in Dashticz (CONFIG.js) I have set both [owm_country] and owm_lang] to 'NL'. This results in a Dutch description of the weather, but the days are still in English (which is different in the manual. I think that this is caused by the English client OS, but it would be nice if the days are presented in the language that is set in OCNFIG.js as well.
- HansieNL
Re: Open Weather Map language
Do you have the following language setting?
Edit:
Check also the following language setting:
config['language'] = 'nl_NL';
config['calendarlanguage'] = 'nl_NL';
Blah blah blah
JanvdW
The 'language' parameter was fine, but I had no ''calendarlanguage' set. That did the trick and solved the issue. Thanks!
