Delay between Zwave PIR and Hue lamps
Posted: Monday 18 January 2021 20:24
I have the following issue; i use a Zwave PIR to control a few Hue lamps in the house. I already noticed a (small) delay on a lamp i have in my bedroom, upon entering the room, the delay is around 3/4 seconds. This was not ideal, but ah well, doable. Last weekend i added the same setup with 3 Hue lamps in a group, so i control the group for switch on/off. The delay is not up to 40 seconds. Is this normal behaviour and should i just control them using a Hue motion sensor or could there be a different problem? To be complete let me show the setup, maybe something there is wrong, or could be done better.
dzVents script:
Then i have 2 scenes in domoticz which call a script (see attached screenshot), basicly i have this with the 'On Action': script://hue-scripts/Lamp_Overloop_Overdag.sh
The file content of Lamp_Overloop_Overdag.sh is:
#!/bin/bash
curl --request PUT --data "{\"scene\": \"y79k6DsXpJj-eGY\"}" http://192.168.80.117/api/<username>/groups/23/action
Any help would be really appriciated.
Regards,
Peter
dzVents script:
active = true,
devices = {
['Group Overloop boven'] = {'on mon,tue,wed,thu,fri,sat,sun'}
timer = {
'every minute on mon,tue,wed,thu,fri,sat,sun'
data = {
counter = { initial = 0 }
domoticz.log('[DEVICE][OVERLOOP] Sensor status.: ' ..domoticz.devices('ZW Sensor Overloop Trap').state)
domoticz.log('[DEVICE][OVERLOOP] Lamp Status...: ' ..domoticz.devices('Group Overloop boven').state)
domoticz.log('[DEVICE][OVERLOOP] Lux Value.....: ' ..domoticz.devices('ZW Lux Overloop Trap').lux)
domoticz.log('[DEVICE][OVERLOOP] Counter Value.: ' ..domoticz.data.counter)
if (domoticz.devices('ZW Sensor Overloop Trap').state == 'On') and
(domoticz.devices('Group Overloop boven').state == 'Off') and
(domoticz.devices('ZW Lux Overloop Trap').lux <= 15) then
if (domoticz.time.hour >= 7) and (domoticz.time.hour < 23) then
domoticz.scenes('Lamp_Overloop_Overdag').switchOn()
domoticz.log('[DEVICE][OVERLOOP] Motion sensor Overloop is aan, schakelaar is aangezet (routine 7-23)')
if (domoticz.time.hour >= 23) and (domoticz.time.hour < 7) then
domoticz.scenes('Lamp_Overloop_Avond').switchOn()
domoticz.log('[DEVICE][OVERLOOP] Motion sensor Overloop is aan, schakelaar is aangezet (routine 23-7)')
if (domoticz.devices('ZW Sensor Overloop Trap').state == 'Off') and
(domoticz.devices('Group Overloop boven').state ~= 'Off') then
domoticz.devices('Group Overloop boven').switchOff()
domoticz.log('[DEVICE][OVERLOOP] Schakelaar overloop is uitgezet')
#!/bin/bash
Regards,
Peter
