utils.osExecute leaves defunct processes
Posted: Sunday 17 January 2021 11:44
by krej
In regular lua scripts I use
os.execute('some-command > /data/some-command.output.json &'
to trigger a lenghty (> a few seconds) collection of data that Domoticz some moments later will pick up. Notice the background processing with &. This works well.
Tried the same technique in dzVents, using a timer-triggered
dz.utils.osExecute('some-command > /data/output.json 2> /data/error.json &')
This causes Domoticz to leave a defunct process behind for each execution of the collection script.
# ps -ef | grep fronius | head
root 304 27346 0 04:11 ? 00:00:00 [fetch-fronius-d] <defunct>
root 312 27346 0 Jan16 ? 00:00:00 [fetch-fronius-d] <defunct>
root 317 27346 0 Jan16 ? 00:00:00 [fetch-fronius-d] <defunct>
.. (several 1000-s of processes...)
Same behaviour with plain os.execute in dzVents. I'm running 2020.2 on Linux (x86).
Known problem? Can I call the collection script in some other way to avoid the defunct processes?
Re: utils.osExecute leaves defunct processes
Posted: Sunday 17 January 2021 13:15
by waaren
krej wrote: Sunday 17 January 2021 11:44
.. This causes Domoticz to leave a defunct process behind for each execution of the collection script.
The os.execute and dz.utils.osExecute calls in dzVents are both the same call to the domoticz Lua engine as the one in classic Lua.
I cannot replicate the issue but maybe because I am on 2020.2 build 12850. I sometimes see 1 defunc process for a minute or so but even when I force the background process to be alive for quite a long time 100 or even 2000 seconds I don't see this behavior.
Do you see this with one specific 'some-command' or can you reproduce this with other lengthy commands (eg sleep 20)?
in dzVents 3.1.0 (domoticz build 12771). executeShellCommand() was introduced offering aSync shell command execution in much more robust and useful way including callback and returning results. If your issue cannot be fixed in an acceptable way while on your build of 2020.2 , you might want to have a look at that.
Posted: Sunday 17 January 2021 20:23
by krej
Just tried with this simple script
timer = { 'every minute' },
execute = function(dz, timer)
dz.log('Timer event was triggered by ' .. timer.trigger, dz.LOG_INFO)
os.execute('sleep 20 > /data/sleep.stdout 2> /data/sleep.stderr &')
and the defunct processes still appear.
# ps -ef| grep slee
root 6432 27346 0 19:06 ? 00:00:00 [sleep] <defunct>
root 6792 27346 0 19:07 ? 00:00:00 [sleep] <defunct>
root 7115 27346 0 19:08 ? 00:00:00 [sleep] <defunct>
root 7439 27346 0 19:09 ? 00:00:00 [sleep] <defunct>
root 7817 27346 0 19:10 ? 00:00:00 [sleep] <defunct>
Out of curiosity, I checked signal status for domoticz:
~$ ./signals 27346
SigPnd: 0000000000000000 0
ShdPnd: 0000000000000000 0
SigBlk: 0000000000000000 0
SigIgn: 0000000001001000 1000000000001000000000000 PIPE XFSZ
SigCgt: 00000001800046ea 110000000000000000100011011101010 INT ILL ABRT BUS FPE USR1 SEGV TERM
Domoticz does not ignore SIGCHLD, which means there has to be a signal handler registered that reacts to dead children.
It may be of interest to know that I'm running Domoticz in a docker container.
