Blockly doesn't react on kaku motion sensor Topic is solved
svdhaar
Post by svdhaar »
Hi!
I have a question. I'm a newby concerning blockly.
i have domo with a 433transceiver and some kaku devices.
With blockly i'm trying to setup a schedule: if bewegingsensor = on and it's dark, turn on a light.
I've even tried without the timing schedule. it seems that blockly doesn't react at all on the motionsensor.
The motionsensor is returning on / of in domo when it's activated.
i also have a script in the sensor setup which makes a snapshot via an ipcam (without blockly) which is working good.
blockly is reacting ok when i try a simple thing with a manual switch
Any one an idea?
Re: Blockly doesn't react on kaku motion sensor
svdhaar wrote: Friday 15 January 2021 7:51 Any one an idea?
Your time conditions are mutually exclusive so the [and] should change to [or]
Also
you have [ sensor = ] [ On and time ... and time ... ]
and that should be
[sensor = On ] and [ time .. or time ... ]
svdhaar
Post by svdhaar »
waaren wrote: Friday 15 January 2021 8:22
Also
and that should be
thx for your tip!
I think my biggest issue is that the blockly doesn't react at all when i use the motionsensor.
Even this one doesn't do anything:
When i use an manual switch, it does work.. > Nevermind.. It just started to work. :-)
kuifje
Domoticz version: latest
Post by kuifje »
SvdHaar.
you need to change the blue do-if in to a normal do blockly. This one is waiting for more.
kuifje
