switch error
Posted: Wednesday 13 January 2021 15:37
by kroonp
Hello all,
Can anyone see what I am doing wrong in the script?
The intention is that if I turn on one switch, the other 2 will turn off.
However, this does not happen.
As soon as I press a switch, it lights up briefly and goes out again. The others don't respond.
Thank you for thinking along.
Peter
devices = {
'Thuis',
'Afwezig',
'Vakantie'
logging =
level = domoticz.LOG_ERROR, -- change to dz.LOG_ERROR when script is OK
marker = 'test Statuscontrole',
execute = function(dz)
local Thuis = dz.devices('Thuis')
local Vakantie=dz.devices('Vakantie')
local Afwezig=dz.devices('Afwezig') -- idx 395
if(Thuis.state=='On') then
Afwezig.switchOff()
Vakantie.switchOff()
elseif(Afwezig.state=='On') then
Thuis.switchOff()
elseif(Vakantie.state=='On') then
Thuis.switchOff()
Afwezig.switchOff()
Re: switch error
Posted: Wednesday 13 January 2021 17:32
by waaren
kroonp wrote: Wednesday 13 January 2021 15:37
Below modified script turns on more logging, shows which device caused the execution of the script and switches the devices silent() so the will not cause a subsequent execution of the script.
return
on =
devices =
'Thuis',
'Afwezig',
'Vakantie',
logging =
level = domoticz.LOG_DEBUG, -- change to dz.LOG_ERROR when script is OK
execute = function(dz, item)
dz.log(item.name .. ', State: ' .. item.state .. ', Type: ' .. item.deviceType, dz.LOG_DEBUG )
local Vakantie = dz.devices('Vakantie')
local Afwezig = dz.devices('Afwezig') -- idx 395
if (Thuis.state == 'On') then
Afwezig.switchOff().silent()
Vakantie.switchOff().silent()
elseif (Afwezig.state == 'On') then
Thuis.switchOff().silent()
elseif (Vakantie.state == 'On') then
Re: switch error
Posted: Wednesday 13 January 2021 22:23
by kroonp
Hallo waaren,
Unfortunately, it doesn't work as expected. Apparently there is still an error in the script.
The intention is that if I turn on one of the switches the other 2 will go out. I don't get it working either with if or elseif.
Is there any other way to get this working.
Peter
Re: switch error
Posted: Thursday 14 January 2021 0:50
by waaren
kroonp wrote: Wednesday 13 January 2021 22:23
The script logic is OK.
What do you see in the log?
Re: switch error
Posted: Thursday 14 January 2021 10:02
by kroonp
The log when i push the 3 switches
- Spoiler: show
2021-01-14 09:59:15.614 Status: dzVents: Debug: test Statuscontrole: Afwezig, State: Off, Type: Light/Switch
2021-01-14 09:59:15.615 Status: dzVents: Debug: test Statuscontrole: Processing device-adapter for Thuis: Switch device adapter
2021-01-14 09:59:15.615 Status: dzVents: Debug: test Statuscontrole: Processing device-adapter for Vakantie: Switch device adapter
2021-01-14 09:59:15.615 Status: dzVents: Info: test Statuscontrole: ------ Finished 00 AB test
2021-01-14 09:59:17.880 Status: dzVents: Info: test Statuscontrole: ------ Start internal script: 00 AB test: Device: "Afwezig (Virtual switch)", Index: 225
2021-01-14 09:59:17.880 Status: dzVents: Debug: test Statuscontrole: Afwezig, State: On, Type: Light/Switch
2021-01-14 09:59:17.881 Status: dzVents: Debug: test Statuscontrole: Processing device-adapter for Thuis: Switch device adapter
2021-01-14 09:59:17.898 Status: dzVents: Debug: test Statuscontrole: Processing device-adapter for Vakantie: Switch device adapter
2021-01-14 09:59:17.898 Status: dzVents: Debug: test Statuscontrole: Constructed timed-command: Off
2021-01-14 09:59:17.898 Status: dzVents: Debug: test Statuscontrole: Constructed timed-command: Off NOTRIGGER
2021-01-14 09:59:17.898 Status: dzVents: Info: test Statuscontrole: ------ Finished 00 AB test
2021-01-14 09:59:51.846 Status: dzVents: Info: test Statuscontrole: ------ Start internal script: 00 AB test: Device: "Vakantie (Dummy)", Index: 246
2021-01-14 09:59:51.846 Status: dzVents: Debug: test Statuscontrole: Vakantie, State: On, Type: Light/Switch
2021-01-14 09:59:51.848 Status: dzVents: Debug: test Statuscontrole: Processing device-adapter for Thuis: Switch device adapter
2021-01-14 09:59:51.848 Status: dzVents: Debug: test Statuscontrole: Processing device-adapter for Afwezig: Switch device adapter
2021-01-14 09:59:51.848 Status: dzVents: Debug: test Statuscontrole: Constructed timed-command: Off
2021-01-14 09:59:51.848 Status: dzVents: Debug: test Statuscontrole: Constructed timed-command: Off NOTRIGGER
2021-01-14 09:59:51.849 Status: dzVents: Debug: test Statuscontrole: Constructed timed-command: Off NOTRIGGER
2021-01-14 09:59:51.849 Status: dzVents: Info: test Statuscontrole: ------ Finished 00 AB test
Re: switch error
Posted: Thursday 14 January 2021 10:56
by kroonp
I also tried this script.
Does not work either.
Peter
return
on =
devices =
'Thuis',
'Afwezig',
'Vakantie',
logging =
marker = 'Testing Statuscontrole',
local Vakantie = dz.devices('Afwezig')
local Afwezig = dz.devices('Vakantie') -- idx 395
if(item.name=='Thuis') then
if Afwezig.state=='On' then
Afwezig.switchOff()
if Vakantie.state=='On' then
Afwezig.switchOff()
if(item.name=='Afwezig') then
if Thuis.state=='On' then
Thuis.switchOff()
if(item.name=='Vakantie') then
Thuis.switchOff()
Afwezig.switchOff()
Index: 395
2021-01-14 10:51:17.198 Status: dzVents: Debug: Testing Statuscontrole: Thuis, State: On, Type: Light/Switch
2021-01-14 10:51:17.199 Status: dzVents: Debug: Testing Statuscontrole: Processing device-adapter for Afwezig: Switch device adapter
2021-01-14 10:51:17.199 Status: dzVents: Debug: Testing Statuscontrole: Processing device-adapter for Vakantie: Switch device adapter
2021-01-14 10:51:17.199 Status: dzVents: Info: Testing Statuscontrole: ------ Finished 00 AB test
Re: switch error
Posted: Thursday 14 January 2021 11:18
by waaren
kroonp wrote: Thursday 14 January 2021 10:02
- Spoiler: show
This log shows that the script works as expected and the right commands are send. What happens if you switch the devices in the Gui from the switch tab ?
Re: switch error
Posted: Thursday 14 January 2021 11:20
by waaren
kroonp wrote: Thursday 14 January 2021 10:56
You don't have to modify the script. It works as expected. If the switches do not react there is another issue on the system.
Re: switch error
Posted: Thursday 14 January 2021 12:32
by kroonp
Thuis Afwezig Vakantie
Start postion Off Off Off
switch Thuis On On Off Off
switich Afwezig On On blink-Off Off
switchVakantie On On Off blink-Off
switich Afwezig On Off On Off
switchVakantie On Off On blink-Off
switich Vakantie On Off Off ON
switch Afwezig On Off On Off
Re: switch error
Posted: Thursday 14 January 2021 12:44
by kroonp
The third version ( from vakantie-afwezig to thuis) works Oke!
Re: switch error
Posted: Thursday 14 January 2021 13:31
by waaren
kroonp wrote: Thursday 14 January 2021 12:44
Can you please double check that no other scripts are active- or On-Off actions / On-Off delays are defined for these switches?
Re: switch error
Posted: Thursday 14 January 2021 15:48
by kroonp
I closed all other scripts.
I restart system
Does not work
I created three new dummy's: een-twee-drie
I have adapted your script with the three new dummy switches. Get the same result as the third postions as above.
return
on =
devices =
'een',
'twee',
'drie'
logging =
local Thuis = dz.devices('een') -- 1847
local Vakantie = dz.devices('twee') -- 1848
local Afwezig = dz.devices('drie') -- 1849
Re: switch error
Posted: Thursday 14 January 2021 16:21
by waaren
kroonp wrote: Thursday 14 January 2021 15:48
Found something. Because the script did not look at the item that triggered the script it always evaluates the first if.
I tested below version and that one does the job in all cases.
return
on =
devices =
'Een',
'Twee',
'Drie'
logging =
level = domoticz.LOG_ERROR, -- change to dz.LOG_DEBUG when developing / debugging
local Thuis = dz.devices('Een') -- 1847
local Vakantie = dz.devices('Twee') -- 1848
local Afwezig = dz.devices('Drie') -- 1849
if item.active then
if item ~= Thuis then Thuis.switchOff().silent() end
if item ~= Vakantie then Vakantie.switchOff().silent() end
if item ~= Afwezig then Afwezig.switchOff().silent() end
Re: switch error [Solved]
Posted: Thursday 14 January 2021 16:41
by kroonp
Great that you found that. Now it works for me too. It took me and you a lot of effort but I am very happy that it is now working, I will be even more careful and check next time. Thanks again and have a nice day.
Peter
