Node ID - device IDX/ID
Posted: Wednesday 13 January 2021 12:35
by thomasbaetge
Hi there,
this might be a stupid question, but I didn't find the answer so far:
how do I get from the z-wave node ID to the domoticz device IDX or ID??
I have a lot of sensors, some of which died, but I can not identify this relationsship.
Thanks in advance,
T.
Re: Node ID - device IDX/ID
Posted: Thursday 14 January 2021 8:34
by lost
Usually, I get the node ID (hexadecimal or base 16 version, starting with 0x under parenthesis) under the hardware tab after selecting the tuning button of z-wave controller.
I then go back to devices and use the search text field (upper right) as a filter with the hexadecimal node ID (removing 0x prefix).
Then, if your node ID is 0xHh (with H/h in 0..9/A..F), you'll more easily spot node devices as their ID include this Hh (possibly prefixed with a variable nb of zeroes, usually 4), and 2 more digits (Dd) as a postfix. This helps make the link to IDx on the same line.
Take care that search does not target specifically the ID, so you may get lines from other devices, but this helps a lot.
Posted: Thursday 14 January 2021 17:12
by thomasbaetge
thanks, but that did not work :(
what I did now was sorting the nodes by id and the z-wave devices by id and worked my way up through the devices, comparing battery levels and 'last seen' info as well. This way I was able to identify my devices.
my 2 cent: this z-wave stuff can go away, I will replace it by zigbee.
Posted: Thursday 14 January 2021 18:54
by lost
thomasbaetge wrote: Thursday 14 January 2021 17:12 thanks, but that did not work :(
Strange, maybe my explanations were not very good but image inclusion is a pain (link to external hosting)...
Maybe zigbee is easier because 1 device = 1 function (so not that cheap)!
But loosing interoperability & having controllers/plugin evolution needed to handle specific devices reminds me RFXCOM... In the end???
Posted: Friday 15 January 2021 12:14
by waltervl
I am no Zwave user but using http://<domoticz-server-IP>/json.htm?type=openzwavenodes&idx=controlleridx should give a long list with also the IDX in it (although I am not sure it is the same IDX you are looking for)
see also https://www.domoticz.com/wiki/Domoticz_ ... parameters
Posted: Friday 15 January 2021 14:36
by thomasbaetge
lost wrote: Thursday 14 January 2021 18:54
Your explanation was good, it simply did not work for me. I thought there would be a 1:1 relationship visible, but I could not find it. Anyway, I identified my devices :)
Posted: Friday 15 January 2021 15:06
by thomasbaetge
waltervl wrote: Friday 15 January 2021 12:14 I am no Zwave user but using http://<domoticz-server-IP>/json.htm?type=openzwavenodes&idx=controlleridx should give a long list with also the IDX in it (although I am not sure it is the same IDX you are looking for)
thanks, tried that one, but did not find the device ID or IDX. The idx given there is the z-wave node ID.
Posted: Friday 15 January 2021 15:54
by waltervl
Following this discussion the Node ID is part of the Device ID and should highlight (when hoover above it?) when using default theme.
viewtopic.php?t=29603
But apperantly is does not anymore (I cannot test it)
See also this discussion on Github https://github.com/domoticz/domoticz/co ... 17e275f09b
Edit: it should look something like this:
ZWave highlite.png (213.53 KiB) Viewed 1344 times
Posted: Saturday 16 January 2021 1:15
by waltervl
I have updated the ZWave Wiki page to make it more clear.
Also please indicate if you see the highlighted Node ID's on your device list as there is some confusion about this.
Posted: Monday 18 January 2021 15:45
by thomasbaetge
Thanks a lot, that worked for me :)
