extra support of Tuya TRV TS0601 in Zigate
I bought 2 Tuya TRV TS0601 (Thermostatic Radiator Valve) and paired them to Zigate.
They are working but on minimum scale, only 3 devices are created (Current Temp, Setpoint, ThermoMode (0, 10, 20 = heat/auto/off?))
Is it possible to add some extra features as battery level (and/or battery low), window detection, valve position, running_state, away_mode, preset?
As a reference see https://github.com/Koenkk/zigbee2mqtt.i ... rmostat.md
Especially battery state (and/or battery low) and valve position would be nice to have.
If I need to test someting, please let me know.
Json export raw devices
{"Version":"3","ZDeviceName":"Thermostaat Eetkamer","Status":"inDB","SQN":"34","Ep":{"01":{"0000":{"0004":"_TZE200_ckud7u2l","0005":"TS0601","0000":"3","0001":"85","0002":"0","0003":"1","0007":"3"},"0004":{},"ef00":{},"000a":{},"0019":{},"Type":"Temp/ThermoSetpoint/ThermoMode_2","ClusterType":{"219":"Temp","220":"ThermoSetpoint","221":"ThermoMode_2"},"0201":{"0012":245,"001c":"Manual"},"0402":{"0000":180}}},"Heartbeat":"4938","RIA":"0","LQI":114,"Battery":{},"Model":"TS0601","ForceAckCommands":[],"MacCapa":"80","IEEE":"5c0272fffec9d600","Type":"Temp/ThermoSetpoint/ThermoMode_2","ProfileID":"0104","ZDeviceID":"0051","App Version":"85","Attributes List":{},"DeviceType":"RFD","HW Version":"1","Last Cmds":[],"LogicalType":"End Device","Manufacturer":"","Manufacturer Name":"_TZE200_ckud7u2l","NbEp":"1","PowerSource":"Battery","ReceiveOnIdle":"","Stack Version":"0","Stamp":{"Time":"2021-01-11 17:53:44","MsgType":"8002","LastSeen":"11/01/2021 15:40:42"},"ZCL Version":"3","Health":"Live","ConfigSource":"DeviceConf","Capability":["Reduced-Function Device","Standard security","NwkAddr should be allocated"],"WriteAttributes":{"Ep":{"01":{"0000":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0004":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"ef00":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"000a":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0019":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0201":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0402":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}}}}},"Bind":{"01":{"0019":{"Target":"0000","Stamp":"01/01/2021 15:28:09","Phase":"binded","Status":"00","i_sqn":3903},"ef00":{"Target":"0000","Stamp":"01/01/2021 15:28:09","Phase":"binded","Status":"00","i_sqn":3904}}},"Epv2":{"01":{"ClusterIn":{},"ClusterOut":{},"ProfileID":"0104","ZDeviceID":"0051"}},"ConsistencyCheck":"ok","RollingLQI":[111,108,108,117,117,105,105,111,111,114,114],"NwkID":"8d4d"}
pipiche
Re: extra support of Tuya TRV TS0601 in Zigate
Post by pipiche »
The Window detection is currently under development, so that might come at a point of time,
as the others I don't really see a Use Case and the way to implement with the current set of Domotciz Widget expect creating too many widgets
For the Battery % this should be already reported
I have no batterylevel reported, devices are already one week alive.
johnrwoods
Domoticz version: 2022.2
Post by johnrwoods »
Hi Walter,
Did you ever get the battery level showing for your TS0601s?
I have just added two of these TRVs to my Domoticz/Zigate installation and have the same issue as you.
Three devices are created for each TRV (Temperature, Setpoint and an Off, Auto, Manual selector switch) but no battery level.
No but Pipiche will work on it as soon as he has received the TRV personally see https://github.com/pipiche38/Domoticz-Zigate/issues/779
Should work soon, but I see that other zigbee plugins also have issues with battery reporting on this TRV.
pipiche
Post by pipiche »
Interesting, there is no battery level reported in the tuya app
That could be a reason everybody is struggling with the battery level...
