question about dzvents / myscript
Posted: Monday 11 January 2021 17:55
by pvklink
Hi i have a question about dzvents / myscript.
This is THE script that manage all my events, so very important (and it works more then perfect).
And now my situation, in the corona-period, some events are outdated.
for example when a event like "local timer_opstaan_on1" is not active for a certain time i like to disable it.
What is the best way to do this in my script,
by disabling with the local timer with -- signs or something else ?
I can imagine that when adding -- to a timer, the on statement has problems with an non-existent timer...
-- dit script bevat de timers voor de Schakelgroepen
-- motion aan uit in verschillende scripts...nakijken .
-- motion 10 seconds timeout omdat nas niet beschikbaar is?
local timer_avond_huis_on   = '25 minutes before sunset on mon,tue,wed,thu,fri,sat,sun'         -- AVOND HUIS SFEERVERLICHTING AAN hele week
local timer_avond_tuin_on   = '15 minutes after sunset on mon,tue,wed,thu,fri,sat,sun'          -- AVOND TUIN SFEERVERLICHTING AAN hele week
local timer_avond_huis_off1 = 'at 23:00 on mon,tue,wed,thu,sun'                                 -- AVOND SFEERVERLICHTING UIT werkw
local timer_avond_huis_off2 = 'at 23:45 on fri,sat'                                             -- AVOND SFEERVERLICHTING UIT weekend
local timer_slapen_on1      = 'at 23:05 on mon,tue,wed,thu,sun'                                 -- SLAPEN AAN werkw
local timer_slapen_on2      = 'at 23:50 on fri,sat'                                             -- SLAPEN AAN weekend
local timer_check           = 'at 24:00 on mon,tue,wed,thu,fri,sat,sun'                         -- CHECKS UITVOEREN
local timer_slapen_off1     = 'at 06:08 on mon,tue,thu,fri'                                     -- SLAPEN UIT werkw peter
local timer_slapen_off2     = 'at 07:08 on mon,tue,wed,thu,fri'                                 -- SLAPEN UIT werkw MO
local timer_slapen_off3     = 'at 08:55 on sat,sun'                                             -- SLAPEN UIT weekend
--local timer_opstaan_on1     = 'at 06:10 on mon,tue,thu,fri'                                     -- OPSTAAN AAN werkw peter
local timer_opstaan_on2     = 'at 07:10 on mon,tue,wed,thu,fri'                                 -- OPSTAAN AAN werkw mo
local timer_opstaan_on3     = 'at 09:00 on sat,sun'                                             -- OPSTAAN AAN weekend
--local timer_opstaan_off1    = 'at 06:15 on mon,tue,thu,fri'                                     -- OPSTAAN EINDE werkw peter
local timer_opstaan_off2    = 'at 07:25 on mon,tue,wed,thu,fri'                                 -- OPSTAAN EINDE werkw mo
local timer_opstaan_off3    = 'at 09:15 on sat,sun'                                             -- OPSTAAN EINDE weekend
local timer_zon_on          = '2 minutes after sunrise on mon,tue,wed,thu,fri,sat,sun'          -- ZON OP
local timer_zon_off         = '2 minutes after sunset on mon,tue,wed,thu,fri,sat,sun'           -- ZON ONDER
local timer_ontbijten_on1   = 'at 06:13 on mon,tue,thu,fri'                                     -- ONTBIJTEN AAN werkw PETER
local timer_ontbijten_on2   = 'at 07:20 on mon,tue,wed,thu,fri'                                 -- ONTBIJTEN AAN werkw MO
local timer_ontbijten_on3   = 'at 09:20 on sat,sun'                                             -- ONTBIJTEN AAN WEEKEND
local timer_ontbijten_off1  = 'at 06:44 on mon,tue,thu,fri'                                     -- ONTBIJTEN UIT werkw PETER
local timer_ontbijten_off2  = 'at 08:00 on mon,tue,wed,thu,fri'                                 -- ONTBIJTEN UIT werkw MO
local timer_ontbijten_off3  = 'at 11:00 on sat,sun'                                             -- ONTBIJTEN UIT WEEKEND
local timer_rolluik_omhoog1 = 'at 09:00 on mon,tue,wed,thu,fri'                                 -- ZONWERING OMHOOG werkweek NIELS (geen vakantie)
local timer_rolluik_omhoog2 = 'at 11:00 on mon,tue,wed,thu,fri'                                 -- ZONWERING OMHOOG werkweek NIELS (vakantie)
local timer_rolluik_omhoog3 = 'at 11:00 on sat,sun'                                             -- ZONWERING OMHOOG weekend NIELS (geen vakantie)
local timer_rolluik_omlaag1 = 'at 13:00 on mon,tue,wed,thu,fri,sat,sun'                         -- ZONWERING OMLAAG iedere dag NIELS deze niet als t buiten koud is
local timer_rolluik_omlaag2 = 'at sunset on mon,tue,wed,thu,fri,sat,sun'                        -- ZONWERING OMLAAG iedere dag NIELS
local Timer_dellog          = 'at 10:00 on mon,wed,fri,sun'                                     -- SCHONEN VAN DE LOGFILE
    on = {  timer = {timer_avond_huis_on, timer_avond_tuin_on, timer_slapen_on1, timer_slapen_on2, timer_check, timer_opstaan_on1, timer_opstaan_on2, timer_opstaan_on3, timer_zon_on, timer_ontbijten_on1, timer_ontbijten_on2, timer_ontbijten_on3,
            timer_rolluik_omhoog1,timer_rolluik_omhoog2,timer_rolluik_omhoog3,timer_avond_huis_off1, timer_avond_huis_off2, timer_slapen_off1, timer_slapen_off2, timer_slapen_off3, timer_opstaan_off1, timer_opstaan_off2, timer_opstaan_off3, timer_zon_off, timer_ontbijten_off1,
            timer_ontbijten_off2, timer_ontbijten_off3,timer_rolluik_omlaag1,timer_rolluik_omlaag2,Timer_dellog,}
    logging =   {
                level   = domoticz.LOG_ERROR,
    execute = function(dz,item,info)
    _G.logMarker = _G.moduleLabel -- marker wordt scriptnaam, _G.logMarker = info.scriptName is idem
    local messageTable = {}
    -- HIER START DE EXECUTIE
    if  (dz.devices('Schakelklok').state == 'uit') then        -- GEEN SCHAKELINGEN
        dz.helpers.globalMessage2(dz,item,info,messageTable,'add', ' SCHAKELKLOK: staat UIT, er worden geen automatische schakelingen uitgevoerd...')
    elseif  (dz.devices('Schakelklok').state ~= 'uit')  then                         -- WEL autom timer SCHAKELINGEN
        if  (item.trigger == timer_avond_huis_on) then        -- AVOND HUIS AAN: HUIS sfeerverlichting binnen
                dz.devices('Avond').switchSelector('huis')
        elseif  (item.trigger == timer_avond_tuin_on) then        -- AVOND TUIN AAN: TUIN sfeerverlichting buiten
                dz.devices('Avond').switchSelector('tuin')
        elseif  (item.trigger == timer_slapen_off1 or item.trigger == timer_slapen_off2 or item.trigger == timer_slapen_off3) then      -- SLAPEN UIT
                dz.devices('Slapen').switchOff()
        elseif (item.trigger == timer_opstaan_off1 or item.trigger == timer_opstaan_off2 or item.trigger == timer_opstaan_off3) then        -- OPSTAAN UIT
                dz.devices('Opstaan').switchOff()
        elseif (item.trigger == timer_ontbijten_off1 or item.trigger == timer_ontbijten_off2 or item.trigger == timer_ontbijten_off3) then  -- ONTBIJTEN UIT
                dz.devices('Ontbijten').switchOff()
        elseif  (item.trigger == timer_zon_on) then        -- ZON OP
                dz.devices('Zon op').switchOn()
        elseif  (item.trigger == timer_zon_off) then        -- ZON ONDER
                dz.devices('Zon op').switchOff()
        elseif  (item.trigger    == Timer_dellog) then        -- CLEAN LOG
                dz.devices('clear_log').switchOn()
        elseif  (item.trigger    == timer_check) then        -- CHECK STUFF
                if dz.time.isNightTime then
                    if  (dz.devices('Zon op').state == 'On') then
                        dz.helpers.globalMessage2(dz,item,info,messageTable,'add', ' SCHAKELKLOK: CHECK, status ZON OP klopt niet: is aangepast!...')
                else -- daytime
                    if  (dz.devices('Zon op').state == 'Off') then
        elseif  (item.trigger == timer_rolluik_omhoog1 or item.trigger == timer_rolluik_omhoog2 or item.trigger == timer_rolluik_omhoog3) then      -- ZONWERING OMHOOG
                if      (item.trigger == timer_rolluik_omhoog1 and dz.devices('Schakelklok').state ~= 'vakantie')   then
                    dz.devices('Niels rolluik').switchOff()
                elseif  (item.trigger == timer_rolluik_omhoog2 and dz.devices('Schakelklok').state == 'vakantie')   then
                elseif  (item.trigger == timer_rolluik_omhoog3)   then
        elseif  (item.trigger == timer_rolluik_omlaag1) then
                grenstmp_zonwering = 18     -- als het boven deze temp is mag t rolluik in de middag omlaag om hitte te voorkomen
                huidigtmp = dz.devices('Strijp_temp').temperature
                if huidigtmp > grenstmp_zonwering then
                    dz.devices('Niels rolluik').switchOn()
        elseif  (item.trigger == timer_rolluik_omlaag2) then
        if  (dz.devices('Schakelklok').state == 'visite')   then        -- VISITE
            dz.helpers.globalMessage2(dz,item,info,messageTable,'add', ' SCHAKELKLOK: staat op VISITE, er worden beperkt automatische schakelingen uitgevoerd...')
        else        -- ALS ER GEEN VISITE IS DAN GEWOON AVONDVERLICHTING UIT EN SLAPEN AAN
            dz.helpers.globalMessage2(dz,item,info,messageTable,'add', ' SCHAKELKLOK: staat op AUTOMATISCH, er worden automatische schakelingen uitgevoerd...')
            if  (item.trigger == timer_avond_huis_off1 or item.trigger == timer_avond_huis_off2) then                                   -- AVOND UIT:
                dz.devices('Avond').switchSelector('uit')
            elseif  (item.trigger == timer_slapen_on1 or item.trigger == timer_slapen_on2) then                                         -- SLAPEN AAN
                dz.devices('Slapen').switchOn()
        if  (dz.devices('Thuis').state == 'On') then        -- HUIS VAN ALARM AF, ER IS IEMAND THUIS
            if (item.trigger == timer_opstaan_on1 or item.trigger == timer_opstaan_on2 or item.trigger == timer_opstaan_on3) then               -- OPSTAAN AAN en GEEN VAKANTIE
                    dz.devices('Opstaan').switchOn()
            elseif (item.trigger == timer_ontbijten_on1 or item.trigger == timer_ontbijten_on2 or item.trigger == timer_ontbijten_on3) then     -- ONTBIJTEN AAN als iemand thuis en zon onder ....
                if dz.devices('Zon op').state == 'Off' and (dz.devices('Schakelklok').state ~= 'vakantie') then                                 -- zon is nog niet op en geen vakantie !        -- CHECK ZON OP/ONDER
                        dz.devices('Ontbijten').switchOn()
                        --globalMessage(add, ' ONTBIJTEN wordt niet uitgevoerd, de zon is op ....',logcode)
                        dz.helpers.globalMessage2(dz,item,info,messageTable,'add', ' ONTBIJTEN wordt niet uitgevoerd, de zon is op of vakantie staat aan....')
        else        -- HUIS OP ALARM, ER IS NIEMAND THUIS
            dz.helpers.globalMessage2(dz,item,info,messageTable,'add', ' OPSTAAN en ONTBIJTEN scripts worden niet uitgevoerd, er is niemand...')
    else -- ONBEKENDE WAARDE
        dz.helpers.globalMessage2(dz,item,info,messageTable,'add', ' SCHAKELKLOK: heeft een onbekende waarde ...')
    dz.helpers.globalMessage2(dz,item,info,messageTable,'chg')
Re: question aabout dzvents / myscript
Posted: Monday 11 January 2021 18:45
by pvklink
Is something possible like:
1. Timers =
{timer_avond_huis_on: '25 minutes before sunset on mon,tue,wed,thu,fri,sat,sun', enabled}
{timer_avond_tuin_off: '15 minutes after sunset on mon,tue,wed,thu,fri,sat,sun',disabled}
2. Function get_active_timer (timers)
read array timers and give back all the timers that are enabled
3. on = { timer = get_active_timers()}
Posted: Monday 11 January 2021 19:02
by waaren
pvklink wrote: Monday 11 January 2021 17:55 by disabling with the local timer with -- signs or something else ?
That will work as expected. dzVents will skip all commented timers without issues, even if all are commented.
Posted: Monday 11 January 2021 19:06
by pvklink
ok! what a great script language ! :-)
is my second solution (on timer with a function also a way to go , or a dummy way...
Just to check if i design good solutions :-)
Posted: Monday 11 January 2021 19:32
by waaren
pvklink wrote: Monday 11 January 2021 18:45 Is something possible like:
This will work.
local Timers =
    { 'timer_avond_huis_on' , '25 minutes before sunset on mon,tue,wed,thu,fri,sat,sun', true },
    { 'timer_avond_tuin_off', '15 minutes after sunset on mon,tue,wed,thu,fri,sat,sun', false},
    { 'allways',   'every minute', true},
local function get_active_timers(Timers)
    local activeTimers = {}
    for _, record in ipairs(Timers) do
        if record[3] == true then
            table.insert(activeTimers, record[2])
    return activeTimers
return
    on =
        timer = get_active_timers(Timers),
    logging =
        level = domoticz.LOG_DEBUG,
        marker = 'Why do it the easy way'
    execute = function(dz, item)
        dz.log(item.trigger,dz.LOG_DEBUG)
Posted: Tuesday 12 January 2021 8:08
by pvklink
I am gonna try that :-)
Case closed :D
Posted: Wednesday 13 January 2021 11:05
by pvklink
hi @waaren
I adjust the script with the functions. No errors ! :-) and it looks great!
But the script does not execute the different timers anymore.
I think that is because the timernames are not there anymore...like
if (item.trigger == timer_zon_on (timer_zon_on) is not there anymore
Can you look at my script and do some advises to make it work and more managable.
I like the fact that i can enable/disable events easy now!
Is it an idea that dzvents can also adress a timer_name during execution. Not only the time data, so that during executing you can use the time, day etc and the timer_id/name. Suppose you have two timed events on the same time with different execution, then an id/name would be helpfull
local Timers =
    { 'timer_avond_huis_on','25 minutes before sunset on mon,tue,wed,thu,fri,sat,sun', true },
    { 'timer_avond_tuin_on','15 minutes after sunset on mon,tue,wed,thu,fri,sat,sun', true },
    { 'timer_avond_huis_off1','at 23:00 on mon,tue,wed,thu,sun', true },
    { 'timer_avond_huis_off2','at 23:45 on fri,sat', true },
    { 'timer_slapen_on1','at 23:05 on mon,tue,wed,thu,sun', true },
    { 'timer_slapen_on2','at 23:50 on fri,sat', true },
    { 'timer_check','at 24:00 on mon,tue,wed,thu,fri,sat,sun', true },
    { 'timer_slapen_off1','at 06:08 on mon,tue,thu,fri', true },
    { 'timer_slapen_off2','at 07:08 on mon,tue,wed,thu,fri', true },
    { 'timer_slapen_off3','at 08:55 on sat,sun', true },
    { 'timer_opstaan_on1','at 06:10 on mon,tue,thu,fri', false },
    { 'timer_opstaan_on2','at 07:10 on mon,tue,wed,thu,fri', true },
    { 'timer_opstaan_on3','at 09:00 on sat,sun', true },
    { 'timer_opstaan_off1','at 06:15 on mon,tue,thu,fri', false },
    { 'timer_opstaan_off2','at 07:25 on mon,tue,wed,thu,fri', true },
    { 'timer_opstaan_off3','at 09:15 on sat,sun', true },
    { 'timer_zon_on','2 minutes after sunrise on mon,tue,wed,thu,fri,sat,sun', true },
    { 'timer_zon_off','2 minutes after sunset on mon,tue,wed,thu,fri,sat,sun', true },
    { 'timer_ontbijten_on1','at 06:13 on mon,tue,thu,fri', false },
    { 'timer_ontbijten_on2','at 07:20 on mon,tue,wed,thu,fri', true },
    { 'timer_ontbijten_on3','at 09:20 on sat,sun', true },
    { 'timer_ontbijten_off1','at 06:44 on mon,tue,thu,fri', false },
    { 'timer_ontbijten_off2','at 08:00 on mon,tue,wed,thu,fri', true },
    { 'timer_ontbijten_off3','at 11:00 on sat,sun', true },
    { 'timer_rolluik_omhoog1','at 09:00 on mon,tue,wed,thu,fri', true },
    { 'timer_rolluik_omhoog2','at 11:00 on mon,tue,wed,thu,fri', true },
    { 'timer_rolluik_omhoog3','at 11:00 on sat,sun', true },
    { 'timer_rolluik_omlaag1','at 13:00 on mon,tue,wed,thu,fri,sat,sun', true },
    { 'timer_rolluik_omlaag2','at sunset on mon,tue,wed,thu,fri,sat,sun', true },
    { 'Timer_dellog','at 10:00 on mon,wed,fri,sun', true },
    return activeTimers
    on =
    logging =
                else -- daytime
            dz.helpers.globalMessage2(dz,item,info,messageTable,'add', ' SCHAKELKLOK: staat op AUTOMATISCH. Gebeurtenis:' .. item.trigger .. ', wordt uitgevoerd...')
                --if dz.devices('Zon op').state == 'Off' and (dz.devices('Schakelklok').state ~= 'vakantie') then                                 -- zon is nog niet op en geen vakantie !        -- CHECK ZON OP/ONDER
                --else
                   --     dz.helpers.globalMessage2(dz,item,info,messageTable,'add', ' ONTBIJTEN wordt niet uitgevoerd, de zon is op of vakantie staat aan....')
                --end
Re: question about dzvents / myscript
Posted: Wednesday 13 January 2021 12:07
by waaren
pvklink wrote: Wednesday 13 January 2021 11:05 I adjust the script with the functions. No errors ! :-) and it looks great!
Below version should work.
Is it an idea that dzVents can also address a timer name during execution. Not only the time data, so that during executing you can use the time, day etc. and the timer id/name. Suppose you have two timed events on the same time with different execution, then an id/name would be helpful
Only one occurrence of the same script will be triggered at the request time. So the situation you describe can only happen with separate scripts. In that case it is quite easy to identify the script with _G.moduleLabel or you could set a local scriptVar.
local Timers =
    { 'Allways','every minute', false }, -- for test
    { 'Never','never', false }, -- for test
    return activeTimers
    on =
    logging =
        if record[3] == true and record[2] == item.trigger then
            item.trigger = record[1]
            break
        if  (item.trigger == 'timer_avond_huis_on') then        -- AVOND HUIS AAN: HUIS sfeerverlichting binnen
        elseif  (item.trigger == 'timer_avond_tuin_on') then        -- AVOND TUIN AAN: TUIN sfeerverlichting buiten
        elseif  (item.trigger == 'timer_slapen_off1' or item.trigger == 'timer_slapen_off2' or item.trigger == 'timer_slapen_off3') then      -- SLAPEN UIT
        elseif (item.trigger == 'timer_opstaan_off1' or item.trigger == 'timer_opstaan_off2' or item.trigger == 'timer_opstaan_off3') then        -- OPSTAAN UIT
        elseif (item.trigger == 'timer_ontbijten_off1' or item.trigger == 'timer_ontbijten_off2' or item.trigger == 'timer_ontbijten_off3') then  -- ONTBIJTEN UIT
        elseif  (item.trigger == 'timer_zon_on') then        -- ZON OP
        elseif  (item.trigger == 'timer_zon_off') then        -- ZON ONDER
        elseif  (item.trigger == 'Timer_dellog') then        -- CLEAN LOG
        elseif  (item.trigger == 'timer_check') then        -- CHECK STUFF
                else -- daytime
        elseif  (item.trigger == 'timer_rolluik_omhoog1' or item.trigger == 'timer_rolluik_omhoog2' or item.trigger == 'timer_rolluik_omhoog3') then      -- ZONWERING OMHOOG
                if      (item.trigger == 'timer_rolluik_omhoog1' and dz.devices('Schakelklok').state ~= 'vakantie')   then
                elseif  (item.trigger == 'timer_rolluik_omhoog2' and dz.devices('Schakelklok').state == 'vakantie')   then
                elseif  (item.trigger == 'timer_rolluik_omhoog3')   then
        elseif  (item.trigger == 'timer_rolluik_omlaag1') then
        elseif  (item.trigger == 'timer_rolluik_omlaag2') then
            if  (item.trigger == 'timer_avond_huis_off1' or item.trigger == 'timer_avond_huis_off2') then                                   -- AVOND UIT:
            elseif  (item.trigger == 'timer_slapen_on1' or item.trigger == 'timer_slapen_on2') then                                         -- SLAPEN AAN
            if (item.trigger == 'timer_opstaan_on1' or item.trigger == 'timer_opstaan_on2' or item.trigger == 'timer_opstaan_on3') then               -- OPSTAAN AAN en GEEN VAKANTIE
            elseif (item.trigger == 'timer_ontbijten_on1' or item.trigger == 'timer_ontbijten_on2' or item.trigger == 'timer_ontbijten_on3') then     -- ONTBIJTEN AAN als iemand thuis en zon onder ....
                --else
                --end
Posted: Wednesday 13 January 2021 12:11
by pvklink
I tried to solve it myself by adding an extra function to retrieve to eventname from the array, i use Timers again and match this with item.trigger
this part:
local function get_active_timer(Timers,trigger) -- PVK ADDED
local activeTimer = {}
if record[2] == trigger then
table.insert(activeTimer, record[1])
return activeTimer
activeTimerx = get_active_timer(Timers,item.trigger)
dz.helpers.globalMessage2(dz,item,info,messageTable,'add', ' SCHAKELKLOK: test activeTimer=' .. activeTimer[1])
but i get an error when showing the value of activeTimer[1]
2021-01-13 12:12:00.280 Error: dzVents: Error: (3.0.19) An error occurred when calling event handler DZ_schakelklok
2021-01-13 12:12:00.280 Error: dzVents: Error: (3.0.19) ...icz/scripts/dzVents/generated_scripts/DZ_schakelklok.lua:78: attempt to index a nil value (global 'activeTimer')
202
local Timers =
--    { 'timer_ontbijten_on3','at 09:20 on sat,sun', true },
    { 'timer_ontbijten_on3','at 12:03 on mon,tue,wed,thu,fri', true },          --test
    return activeTimers
    on =
    logging =
        return activeTimer
                else -- daytime
                --else
                --end
Re: question about dzvents / myscript  [Solved]
Posted: Wednesday 13 January 2021 12:21
by pvklink
This one works great !
Posted: Wednesday 13 January 2021 13:32
by pvklink
For those who want to reuse this, here my master timer script (with many thanks to @waaren)
@waaren when you have sparetime :-) can you take a look if this scripti is modelled well, or if you can suggest some improvements?
I already have changed statements with if and or or or by using your wildcard construct, looks much better!
When this script is perfect i am gonna update all my scripts with events with this setup, like my irrigation timer script...
Peter
local Timers =
    { 'timer_ontbijten_on3','at 13:08 on mon,tue,wed,thu,fri', true },  -- TEST
    { 'timer_rolluik_omhoog1','at 09:00 on mon,tue,wed,thu,fri', false },
    return activeTimers
    on =
    logging =
    for _, record in ipairs(Timers) do  -- de eventnaam ophalen en item.trigger inhoud geven van opgehaalde eventnaam
            break
        elseif dz.helpers.matchesWildCardedString(dz,item.trigger, 'timer_slapen_off*') then    -- SLAPEN UIT
        elseif dz.helpers.matchesWildCardedString(dz,item.trigger, 'timer_opstaan_off*') then   -- OPSTAAN UIT
        elseif dz.helpers.matchesWildCardedString(dz,item.trigger, 'timer_ontbijten_off*') then -- ONTBIJTEN UIT
                else -- daytime
        elseif dz.helpers.matchesWildCardedString(dz,item.trigger, 'timer_rolluik_omhoog*') then -- ZONWERING OMHOOG
        if  (dz.devices('Schakelklok').state == 'visite')   then                                    -- VISITE, dan geen AVOND uit en geen SLAPEN aan
            if dz.helpers.matchesWildCardedString(dz,item.trigger, 'timer_avond_huis_off*') then    -- AVOND UIT:
            elseif dz.helpers.matchesWildCardedString(dz,item.trigger, 'timer_slapen_on*') then     -- SLAPEN AAN
            if dz.helpers.matchesWildCardedString(dz,item.trigger, 'timer_opstaan_on*') then        -- OPSTAAN AAN EN BIJ INSTELLING VAKANTIE en wel THUIS ?
            elseif dz.helpers.matchesWildCardedString(dz,item.trigger, 'timer_ontbijten_on*') then  -- ONTBIJTEN AAN als iemand thuis en zon onder ....
        dz.helpers.globalMessage2(dz,item,info,messageTable,'add', ' SCHAKELKLOK: heeft een onbekende waarde:' .. item.trigger)
Posted: Wednesday 13 January 2021 14:07
by waaren
pvklink wrote: Wednesday 13 January 2021 13:32 If you can suggest some improvements?
No real reason to change something. Your coding style is tailored to your taste. I would use another approach but that would not make it better or significant quicker.
Posted: Wednesday 13 January 2021 16:44
by pvklink
Ok, based on my style an updated version for a main timer script.
All my devices are grouped and each group has an switch you can turn on/off managed by another script that handles only manual actions.
The below script handles events. and events turn one or more groups (via switches on/off)
I try to keep the rules as much as possible in the timer script..
local Timers =
    { 'timer_ontbijten_on3','at 16:21 on mon,tue,wed,thu,fri', false },  -- TEST activiteit waarvan je de tijd kan aanpassen
    return activeTimers
return
    on ={timer = get_active_timers(Timers),},
    logging ={level   = domoticz.LOG_ERROR,},
	local triggername = '';
    for _, record in ipairs(Timers) do  -- de eventnaam ophalen en triggername inhoud geven van opgehaalde eventnaam
            triggername = record[1]
            break
    dz.helpers.globalMessage2(dz,item,info,messageTable,'add', ' SCHAKELKLOK: staat op: ' .. dz.devices('Schakelklok').state .. ' en gebeurtenis: ' .. triggername .. ' is geactiveerd om: ' .. item.trigger)
    if  (dz.devices('Schakelklok').state ~= 'uit')  then                                    -- WEL autom timer SCHAKELINGEN: auto, vakantie, visite
        if dz.helpers.matchesWildCardedString(dz,triggername, 'timer_avond_huis_on*') then      -- AVOND HUIS AAN: HUIS sfeerverlichting binnen
        elseif dz.helpers.matchesWildCardedString(dz,triggername, 'timer_avond_tuin_on*') then -- AVOND TUIN AAN: TUIN sfeerverlichting buiten
        elseif dz.helpers.matchesWildCardedString(dz,triggername, 'timer_avond_huis_off*') then    -- AVOND UIT:
            if  (dz.devices('Schakelklok').state ~= 'visite')   then                                    -- VISITE, dan geen AVOND uit en geen SLAPEN aan
                dz.helpers.globalMessage2(dz,item,info,messageTable,'add', ' AVOND HUIS UIT wordt niet uitgevoerd, visite-mode staat aan....')
        elseif dz.helpers.matchesWildCardedString(dz,triggername, 'timer_slapen_on*') then     -- SLAPEN AAN
                dz.helpers.globalMessage2(dz,item,info,messageTable,'add', ' SLAPEN AAN wordt niet uitgevoerd, visite-mode staat aan....')
        elseif dz.helpers.matchesWildCardedString(dz,triggername, 'timer_slapen_off*') then    -- SLAPEN UIT
        elseif dz.helpers.matchesWildCardedString(dz,triggername, 'timer_opstaan_on*') then     -- OPSTAAN AAN EN BIJ INSTELLING VAKANTIE en wel THUIS ?
            if  (dz.devices('Thuis').state == 'On') and (dz.devices('Schakelklok').state ~= 'vakantie') then                                            -- ER IS IEMAND THUIS en geen vakantie
                dz.helpers.globalMessage2(dz,item,info,messageTable,'add', ' OPSTAAN AAN wordt niet uitgevoerd, er is niemand thuis of vakantie-mode staat aan!...')
        elseif dz.helpers.matchesWildCardedString(dz,triggername, 'timer_opstaan_off*') then   -- OPSTAAN UIT
        elseif dz.helpers.matchesWildCardedString(dz,triggername, 'timer_ontbijten_on*') then  -- ONTBIJTEN AAN
            if  (dz.devices('Thuis').state == 'On') and (dz.devices('Schakelklok').state ~= 'vakantie') and dz.devices('Zon op').state == 'Off' then    -- ER IS IEMAND THUIS, geen vakantie en het is nog donker
                dz.helpers.globalMessage2(dz,item,info,messageTable,'add', ' ONTBIJTEN AAN wordt niet uitgevoerd, er is niemand thuis of vakantie-mode staat aan of de zon is al/nog op!...')
        elseif dz.helpers.matchesWildCardedString(dz,triggername, 'timer_ontbijten_off*') then -- ONTBIJTEN UIT
        elseif dz.helpers.matchesWildCardedString(dz,triggername, 'timer_zon_on*') then        -- ZON OP
        elseif dz.helpers.matchesWildCardedString(dz,triggername, 'timer_zon_off*') then        -- ZON ONDER
        elseif  (triggername == 'Timer_dellog') then                                           -- CLEAN LOG
        elseif  (triggername == 'timer_check') then                                            -- CHECK STUFF
                else -- daytime
        elseif dz.helpers.matchesWildCardedString(dz,triggername, 'timer_rolluik_omhoog*') then -- ZONWERING OMHOOG
                if      (triggername == 'timer_rolluik_omhoog1' and dz.devices('Schakelklok').state ~= 'vakantie')   then
                elseif  (triggername == 'timer_rolluik_omhoog2' and dz.devices('Schakelklok').state == 'vakantie')   then
                elseif  (triggername == 'timer_rolluik_omhoog3')   then
        elseif dz.helpers.matchesWildCardedString(dz,triggername, 'timer_rolluik_omlaag*') then -- ZONWERING OMLAAG
            if  (triggername == 'timer_rolluik_omlaag1') then
            dz.helpers.globalMessage2(dz,item,info,messageTable,'add', ' SCHAKELKLOK: onbekende timers! ' .. triggername)
        dz.helpers.globalMessage2(dz,item,info,messageTable,'add', ' SCHAKELKLOK: staat uit. Er vinden geen schakelingen plaats! ' .. triggername)
