New source for weather - complete and lasting Topic is solved
gamlebardun
Domoticz version: 4.97
Post by gamlebardun »
I propose a new source for domoticz weather data. The norwegian meteorological institute publishes weather data for everywhere for free, and it is a very complete source of weather data;
Example : https://api.met.no/weatherapi/locationf ... n=4.897070
Documentation can be found here : https://developer.yr.no/doc/locationforecast/HowTO/
FireWizard
Re: New source for weather - complete and lasting
Post by FireWizard »
Hi,@gamlebardun,
It is already implemented.
See: Hardware > Meteorologisk institutt Norway (Weather Lookup)
gamlebardun
Hi @FireWizard
I don't have that choice .. is there some incantation I can do to refresh this list?
My install is
Version: 2020.2
Build Hash: b63341bc0
Compile Date: 2020-04-26 13:47:55
dzVents Version: 3.0.2
Python Version: 3.5.4
and Domoticz says there is no update.
Kind regards
FireWizard
Hi, @gamlebardun
I see, you are running version 2020.2 stable.
It has been introduced in the beta version, 12113, published June 1, 2020.
You can upgrade to the beta channel.
See: https://www.domoticz.com/wiki/Domoticz_ ... _-_Commits
gamlebardun
@FireWizard
Ah .. beta.
kiddigital
Post by kiddigital »
Also in the beta is an updated Open Weather Map with a lot of data (and if you activate all sensors, almost 500 sensors with data and forecast data)
hestia
Domoticz version: 2022.1
Post by hestia »
FireWizard wrote: Monday 11 January 2021 14:42 Hi,@gamlebardun,
I've just tried Meteorologisk.
I don't know what to put in "Location"
First I put nothing, it seems to work but with a recurrent error in the log
After I put lat,long and domoticz when down :-( And it was difficult to restart it because the plugin seemed to fall into this error all the time
Domoticz version: 2025.1
I think it should be something like lat=45.767201&lon=4.875536 as it is the same way as the api is using.
It will not crash but it gives strange results in the log file.
I made a request to the developer to change and clarify his implementation https://github.com/domoticz/domoticz/pu ... -784428226
Let's hope he will respond.
EddyG
Post by EddyG »
Only in the source is visible that the location should be written as:
51.95752;5.575657
So just numbers and a " ; " between latitude and longitude.
It would be nice if such an example is visible on the hardware page.
B.t.w. I only get 5 devices. In the json output is MUCH more.
