2 different block sizes for same item
madpatrick
Domoticz version: 2026.1
Post by madpatrick »
I want to present the currentweather_big_owm on 2 different screens.
1x at the normal screen and 1x at the standby screen.
The only issue i have is that i need to different blocksizes.
I've tried this, but doesn't work
var currentweather_1 = 'currentweather_big_owm';
var currentweather_2 = 'currentweather_big_owm';
blocks[currentweather_1] 		= {width :12}
blocks[currentweather_2] 		= {width :6}
columns[10] = {}
columns[10]['blocks'] = currentweather_1]
columns[10]['width'] 	= 4
columns_standby[1] = {}
columns_standby[1]['blocks'] = [currentweather_2]
Krenstik
Re: 2 different block sizes for same item
Post by Krenstik »
Maybe can work set different size of collum ;-)
I´ve used it for the same value and different screens...
madpatrick
Krenstik wrote: Monday 11 January 2021 22:39 Maybe can work set different size of collum ;-)
Would be nice if it works for the standby screen.
With a normal screen this is working, but with the standby screen no.
Is it possible to use columns with the standby screen ?
