Possible to run in docker on Synolgy?
Posted: Wednesday 06 January 2021 15:51
by mikkelnl
Hi!
Been reading several posts online about getting Domoticz running on a Synology NAS via a docker container. I can setup the container just fine (the one by linuxserver.io for example), but even if I enable elevated permissions, Domoticz seems to be unable to communicatie with my RFXCOM which is connected via one of the USB ports of the NAS.
Anyone know if this is a knows issue with recent DSM versions maybe?
Re: Possible to run in docker on Synolgy?
Posted: Wednesday 12 May 2021 20:52
by filbert
From my limited experience, installing packages in Docker on Synology is not straightforward. Is there a step by step guide to do it?
Posted: Wednesday 12 May 2021 22:42
For the Official Docker there is guide for Synology:
https://domoticz.com/forum/viewtopic.php?f=47&t=35639
Posted: Thursday 15 July 2021 12:20
by JackD
Did you install the usb drivers?, If you run DSM 6.xx on your Synology it is easy to use the driver pack from Jadahl for this
http://www.jadahl.com/ .
DSM 7 I don't know.....
But there are more possible potential problems why you can't get Domoticz to run on Docker on your Synology
mikkelnl wrote: Wednesday 06 January 2021 15:51
Hi!
Posted: Wednesday 04 August 2021 13:48
by Charles512
Simply open the Synology Package Center, search for Docker and install the package. Once you installed it, the Docker detail page in the Synology Package Center should look like the screenshot below. You can then open the Docker package.
Walgreenslistens
