koensch wrote: Saturday 02 January 2021 12:24
now i'm having a lua script and i am looking for a way to read a particular setting's value into a script variable to use it in a calculation.
can someone help me by showing where to find a sample or where this is documented?
You cannot do it directly in Lua or dzVents but you can use domoticz.openURL in dzVents or curl in Lua and call the api. You need admin rights to do that ( either by including a username/password in the url of a auser with admin rights or by allowing local network in settings to access domoticz without password)
Some of the settings are base64 encoded
You can find the api call
on this Wiki page
in dzVents it could look like the samplescript below
__________________________________________________________________________________________________________________________
When not yet familiar with dzVents please start with reading
Get started Before implementing (~ 5 minutes). Special attention please for "In Domoticz go to Setup > Settings > Other and in the section EventSystem make sure the checkbox 'dzVents enabled' is checked. Also make sure that in the Security section in the settings you allow 127.0.0.1 to not need a password. dzVents uses that port to send certain commands to Domoticz. Finally make sure you have set your current location in Setup > Settings > System > Location, otherwise there is no way to determine nighttime/daytime state."
___________________________________________________________________________________________________________________________
script to get and decode settings
local scriptVar = 'getSettings'
return
on =
timer =
'every minute' , --- change to your liking
httpResponses =
scriptVar,
logging =
level = domoticz.LOG_DEBUG, -- change to domoticz.LOG_ERROR when all ok
marker = scriptVar,
execute = function(dz, item)
local settingsEncoded =
ClickatellTo = true,
HTTPPostContentType = true,
HTTPURL = true,
EmailUsername = true,
EmailPassword = true,
ClickatellAPI = true,
IFTTTAPI = true,
MyDomoticzPassword = true,
local function showSettings(t)
for key, value in pairs(t) do
if settingsEncoded[key] then
value = dz.utils.fromBase64(value)
dz.log(key .. ': ' .. dz.utils._.str(value) )
if item.isTimer or item.isDevice then
settingsURL = dz.settings['Domoticz url'] .. '/json.htm?type=settings'
dz.openURL(
url = settingsURL,
callback = scriptVar
elseif item.isJSON then
showSettings(item.json)
dz.log('There was a problem handling' .. item.trigger, dz.LOG_ERROR)
dz.log(item, dz.LOG_DEBUG)
