Zigbee2MQTT pairing but not showing devices in devices tab
Posted: Friday 01 January 2021 23:12
Hello
sorry for the newbie question (I'm certain I'm forgetting a very simple step)
the thing is that I have a newly clean install of domoticz and zigbee2mqtt and plugin on my raspberry. I have a couple of mija door sensors and a buton.
I'm able to install the zigbee2mqtt plugin, I can pair the devices, and I see them under custom/zigbee2mqtt
pronlem is that they dont appear under the devices tab!
any help¿?
edit, additional info: log when pairing:
any help¿?
etup
All
Status
Filter: X
2021-01-01 23:15:50.175 Status: Incoming connection from: 192.168.1.155
2021-01-01 23:17:30.704 Status: New sensors allowed for 5 minutes...
2021-01-01 23:27:15.153 Status: New sensors allowed for 5 minutes...
2021-01-01 23:28:07.351 (Zigbee2MQTT) 22 64 61 74 65 43 6f 64 65 22 3a 22 32 30 31 39 30 36 30 38 "dateCode":"20190608
2021-01-01 23:28:07.351 (Zigbee2MQTT) 22 2c 22 66 72 69 65 6e 64 6c 79 5f 6e 61 6d 65 22 3a 22 43 ","friendly_name":"C
2021-01-01 23:28:07.351 (Zigbee2MQTT) 6f 6f 72 64 69 6e 61 74 6f 72 22 2c 22 69 65 65 65 41 64 64 oordinator","ieeeAdd
2021-01-01 23:28:07.351 (Zigbee2MQTT) 72 22 3a 22 30 78 30 30 31 32 34 62 30 30 31 34 64 39 35 62 r":"0x00124b0014d95b
2021-01-01 23:28:07.351 (Zigbee2MQTT) 37 66 22 2c 22 6c 61 73 74 53 65 65 6e 22 3a 31 36 30 39 35 7f","lastSeen":16095
2021-01-01 23:28:07.351 (Zigbee2MQTT) 34 30 30 38 37 33 30 33 2c 22 6e 65 74 77 6f 72 6b 41 64 64 40087303,"networkAdd
2021-01-01 23:28:07.351 (Zigbee2MQTT) 72 65 73 73 22 3a 30 2c 22 73 6f 66 74 77 61 72 65 42 75 69 ress":0,"softwareBui
2021-01-01 23:28:07.351 (Zigbee2MQTT) 6c 64 49 44 22 3a 22 7a 53 74 61 63 6b 31 32 22 2c 22 74 79 ldID":"zStack12","ty
2021-01-01 23:28:07.351 (Zigbee2MQTT) 70 65 22 3a 22 43 6f 6f 72 64 69 6e 61 74 6f 72 22 7d 2c 7b pe":"Coordinator"},{
2021-01-01 23:28:07.351 (Zigbee2MQTT) 22 64 65 73 63 72 69 70 74 69 6f 6e 22 3a 22 4d 69 4a 69 61 "description":"MiJia
2021-01-01 23:28:07.352 (Zigbee2MQTT) 20 64 6f 6f 72 20 26 20 77 69 6e 64 6f 77 20 63 6f 6e 74 61 .door.&.window.conta
2021-01-01 23:28:07.352 (Zigbee2MQTT) 63 74 20 73 65 6e 73 6f 72 22 2c 22 66 72 69 65 6e 64 6c 79 ct.sensor","friendly
2021-01-01 23:28:07.352 (Zigbee2MQTT) 5f 6e 61 6d 65 22 3a 22 30 78 30 30 31 35 38 64 30 30 30 32 _name":"0x00158d0002
2021-01-01 23:28:07.352 (Zigbee2MQTT) 61 36 32 32 64 35 22 2c 22 69 65 65 65 41 64 64 72 22 3a 22 a622d5","ieeeAddr":"
2021-01-01 23:28:07.352 (Zigbee2MQTT) 30 78 30 30 31 35 38 64 30 30 30 32 61 36 32 32 64 35 22 2c 0x00158d0002a622d5",
2021-01-01 23:28:07.352 (Zigbee2MQTT) 22 6c 61 73 74 53 65 65 6e 22 3a 31 36 30 39 35 34 30 30 37 "lastSeen":160954007
2021-01-01 23:28:07.352 (Zigbee2MQTT) 38 33 36 39 2c 22 6d 6f 64 65 6c 22 3a 22 4d 43 43 47 51 30 8369,"model":"MCCGQ0
2021-01-01 23:28:07.352 (Zigbee2MQTT) 31 4c 4d 22 2c 22 6d 6f 64 65 6c 49 44 22 3a 22 6c 75 6d 69 1LM","modelID":"lumi
2021-01-01 23:28:07.352 (Zigbee2MQTT) 2e 73 65 6e 73 6f 72 5f 6d 61 67 6e 65 74 22 2c 22 6e 65 74 .sensor_magnet","net
2021-01-01 23:28:07.352 (Zigbee2MQTT) 77 6f 72 6b 41 64 64 72 65 73 73 22 3a 33 39 36 33 37 2c 22 workAddress":39637,"
2021-01-01 23:28:07.352 (Zigbee2MQTT) 74 79 70 65 22 3a 22 55 6e 6b 6e 6f 77 6e 22 2c 22 76 65 6e type":"Unknown","ven
2021-01-01 23:28:07.352 (Zigbee2MQTT) 64 6f 72 22 3a 22 58 69 61 6f 6d 69 22 7d 5d .. .. .. .. .. dor":"Xiaomi"}]
2021-01-01 23:28:07.353 (Zigbee2MQTT - Zigbee2MQTT API Transport) Updating device from 0:'{"type":"request","requestId":13,"command":"devices_get","params":{}}' to have values 0:'{"type": "response", "requestId": 13, "isError": false, "payload": [{"dateCode": "20190608", "friendly_name": "Coordinator", "ieeeAddr": "0x00124b0014d95b7f", "lastSeen": 1609540087303, "networkAddress": 0, "softwareBuildID": "zStack12", "type": "Coordinator"}, {"description": "MiJia door & window contact sensor", "friendly_name": "0x00158d0002a622d5", "ieeeAddr": "0x00158d0002a622d5", "lastSeen": 1609540078369, "model": "MCCGQ01LM", "modelID": "lumi.sensor_magnet", "networkAddress": 39637, "type": "Unknown", "vendor": "Xiaomi"}]}'.
2021-01-01 23:28:16.130 (Zigbee2MQTT) MqttClient::ping
2021-01-01 23:28:16.130 (Zigbee2MQTT) Sending 2 bytes of data
2021-01-01 23:28:16.130 (Zigbee2MQTT) c0 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. �
2021-01-01 23:28:16.181 (Zigbee2MQTT) Received 2 bytes of data
2021-01-01 23:28:16.181 (Zigbee2MQTT) d0 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. Ю
2021-01-01 23:28:20.864 (Zigbee2MQTT) Received 230 bytes of data
2021-01-01 23:28:20.864 (Zigbee2MQTT) 30 e3 01 00 16 7a 69 67 62 65 65 32 6d 71 74 74 2f 62 72 69 0㮮.zigbee2mqtt/bri
2021-01-01 23:28:20.864 (Zigbee2MQTT) 64 67 65 2f 6c 6f 67 7b 22 6d 65 73 73 61 67 65 22 3a 22 69 dge/log{"message":"i
2021-01-01 23:28:20.864 (Zigbee2MQTT) 6e 74 65 72 76 69 65 77 5f 73 75 63 63 65 73 73 66 75 6c 22 nterview_successful"
2021-01-01 23:28:20.864 (Zigbee2MQTT) 2c 22 6d 65 74 61 22 3a 7b 22 64 65 73 63 72 69 70 74 69 6f ,"meta":{"descriptio
2021-01-01 23:28:20.865 (Zigbee2MQTT) 6e 22 3a 22 4d 69 4a 69 61 20 64 6f 6f 72 20 26 20 77 69 6e n":"MiJia.door.&.win
2021-01-01 23:28:20.865 (Zigbee2MQTT) 64 6f 77 20 63 6f 6e 74 61 63 74 20 73 65 6e 73 6f 72 22 2c dow.contact.sensor",
2021-01-01 23:28:20.865 (Zigbee2MQTT) 22 66 72 69 65 6e 64 6c 79 5f 6e 61 6d 65 22 3a 22 30 78 30 "friendly_name":"0x0
2021-01-01 23:28:20.865 (Zigbee2MQTT) 30 31 35 38 64 30 30 30 32 61 36 32 32 64 35 22 2c 22 6d 6f 0158d0002a622d5","mo
2021-01-01 23:28:20.865 (Zigbee2MQTT) 64 65 6c 22 3a 22 4d 43 43 47 51 30 31 4c 4d 22 2c 22 73 75 del":"MCCGQ01LM","su
2021-01-01 23:28:20.865 (Zigbee2MQTT) 70 70 6f 72 74 65 64 22 3a 74 72 75 65 2c 22 76 65 6e 64 6f pported":true,"vendo
2021-01-01 23:28:20.865 (Zigbee2MQTT) 72 22 3a 22 58 69 61 6f 6d 69 22 7d 2c 22 74 79 70 65 22 3a r":"Xiaomi"},"type":
2021-01-01 23:28:20.865 (Zigbee2MQTT) 22 70 61 69 72 69 6e 67 22 7d .. .. .. .. .. .. .. .. .. .. "pairing"}
2021-01-01 23:28:20.865 (Zigbee2MQTT - Zigbee2MQTT API Transport) Updating device from 0:'{"type": "response", "requestId": 13, "isError": false, "payload": [{"dateCode": "20190608", "friendly_name": "Coordinator", "ieeeAddr": "0x00124b0014d95b7f", "lastSeen": 1609540087303, "networkAddress": 0, "softwareBuildID": "zStack12", "type": "Coordinator"}, {"description": "MiJia door & window contact sensor", "friendly_name": "0x00158d0002a622d5", "ieeeAddr": "0x00158d0002a622d5", "lastSeen": 1609540078369, "model": "MCCGQ01LM", "modelID": "lumi.sensor_magnet", "networkAddress": 39637, "type": "Unknown", "vendor": "Xiaomi"}]}' to have values 0:'{"type": "response", "requestId": 11, "isError": false, "payload": {"message": "interview_successful", "meta": {"description": "MiJia door & window contact sensor", "friendly_name": "0x00158d0002a622d5", "model": "MCCGQ01LM", "supported": true, "vendor": "Xiaomi"}, "type": "pairing"}}'.
2021-01-01 23:28:20.872 (Zigbee2MQTT) MqttClient::publish zigbee2mqtt/bridge/config/devices/get ()
2021-01-01 23:28:20.872 (Zigbee2MQTT) Sending 41 bytes of data
2021-01-01 23:28:20.873 (Zigbee2MQTT) 30 27 00 25 7a 69 67 62 65 65 32 6d 71 74 74 2f 62 72 69 64 0'.%zigbee2mqtt/brid
2021-01-01 23:28:20.873 (Zigbee2MQTT) 67 65 2f 63 6f 6e 66 69 67 2f 64 65 76 69 63 65 73 2f 67 65 ge/config/devices/ge
2021-01-01 23:28:20.873 (Zigbee2MQTT) 74 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. t
2021-01-01 23:28:20.923 (Zigbee2MQTT) Received 41 bytes of data
2021-01-01 23:28:20.923 (Zigbee2MQTT) 30 27 00 25 7a 69 67 62 65 65 32 6d 71 74 74 2f 62 72 69 64 0'.%zigbee2mqtt/brid
2021-01-01 23:28:20.923 (Zigbee2MQTT) 67 65 2f 63 6f 6e 66 69 67 2f 64 65 76 69 63 65 73 2f 67 65 ge/config/devices/ge
2021-01-01 23:28:20.923 (Zigbee2MQTT) 74 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. t
2021-01-01 23:28:20.923 (Zigbee2MQTT) Received 549 bytes of data
2021-01-01 23:28:20.923 (Zigbee2MQTT) 30 a2 04 00 21 7a 69 67 62 65 65 32 6d 71 74 74 2f 62 72 69 0®.!zigbee2mqtt/bri
2021-01-01 23:28:20.923 (Zigbee2MQTT) 64 67 65 2f 63 6f 6e 66 69 67 2f 64 65 76 69 63 65 73 5b 7b dge/config/devices[{
2021-01-01 23:28:20.923 (Zigbee2MQTT) 22 64 61 74 65 43 6f 64 65 22 3a 22 32 30 31 39 30 36 30 38 "dateCode":"20190608
2021-01-01 23:28:20.923 (Zigbee2MQTT) 22 2c 22 66 72 69 65 6e 64 6c 79 5f 6e 61 6d 65 22 3a 22 43 ","friendly_name":"C
2021-01-01 23:28:20.923 (Zigbee2MQTT) 6f 6f 72 64 69 6e 61 74 6f 72 22 2c 22 69 65 65 65 41 64 64 oordinator","ieeeAdd
2021-01-01 23:28:20.924 (Zigbee2MQTT) 72 22 3a 22 30 78 30 30 31 32 34 62 30 30 31 34 64 39 35 62 r":"0x00124b0014d95b
2021-01-01 23:28:20.924 (Zigbee2MQTT) 37 66 22 2c 22 6c 61 73 74 53 65 65 6e 22 3a 31 36 30 39 35 7f","lastSeen":16095
2021-01-01 23:28:20.924 (Zigbee2MQTT) 34 30 31 30 30 38 37 35 2c 22 6e 65 74 77 6f 72 6b 41 64 64 40100875,"networkAdd
2021-01-01 23:28:20.924 (Zigbee2MQTT) 72 65 73 73 22 3a 30 2c 22 73 6f 66 74 77 61 72 65 42 75 69 ress":0,"softwareBui
2021-01-01 23:28:20.924 (Zigbee2MQTT) 6c 64 49 44 22 3a 22 7a 53 74 61 63 6b 31 32 22 2c 22 74 79 ldID":"zStack12","ty
2021-01-01 23:28:20.924 (Zigbee2MQTT) 70 65 22 3a 22 43 6f 6f 72 64 69 6e 61 74 6f 72 22 7d 2c 7b pe":"Coordinator"},{
2021-01-01 23:28:20.924 (Zigbee2MQTT) 22 64 65 73 63 72 69 70 74 69 6f 6e 22 3a 22 4d 69 4a 69 61 "description":"MiJia
2021-01-01 23:28:20.924 (Zigbee2MQTT) 20 64 6f 6f 72 20 26 20 77 69 6e 64 6f 77 20 63 6f 6e 74 61 .door.&.window.conta
2021-01-01 23:28:20.924 (Zigbee2MQTT) 63 74 20 73 65 6e 73 6f 72 22 2c 22 66 72 69 65 6e 64 6c 79 ct.sensor","friendly
2021-01-01 23:28:20.924 (Zigbee2MQTT) 5f 6e 61 6d 65 22 3a 22 30 78 30 30 31 35 38 64 30 30 30 32 _name":"0x00158d0002
2021-01-01 23:28:20.924 (Zigbee2MQTT) 61 36 32 32 64 35 22 2c 22 69 65 65 65 41 64 64 72 22 3a 22 a622d5","ieeeAddr":"
2021-01-01 23:28:20.924 (Zigbee2MQTT) 30 78 30 30 31 35 38 64 30 30 30 32 61 36 32 32 64 35 22 2c 0x00158d0002a622d5",
2021-01-01 23:28:20.924 (Zigbee2MQTT) 22 6c 61 73 74 53 65 65 6e 22 3a 31 36 30 39 35 34 30 30 37 "lastSeen":160954007
2021-01-01 23:28:20.924 (Zigbee2MQTT) 38 33 36 39 2c 22 6d 61 6e 75 66 61 63 74 75 72 65 72 49 44 8369,"manufacturerID
2021-01-01 23:28:20.924 (Zigbee2MQTT) 22 3a 34 31 35 31 2c 22 6d 61 6e 75 66 61 63 74 75 72 65 72 ":4151,"manufacturer
2021-01-01 23:28:20.924 (Zigbee2MQTT) 4e 61 6d 65 22 3a 22 4c 55 4d 49 22 2c 22 6d 6f 64 65 6c 22 Name":"LUMI","model"
2021-01-01 23:28:20.924 (Zigbee2MQTT) 3a 22 4d 43 43 47 51 30 31 4c 4d 22 2c 22 6d 6f 64 65 6c 49 :"MCCGQ01LM","modelI
2021-01-01 23:28:20.924 (Zigbee2MQTT) 44 22 3a 22 6c 75 6d 69 2e 73 65 6e 73 6f 72 5f 6d 61 67 6e D":"lumi.sensor_magn
2021-01-01 23:28:20.924 (Zigbee2MQTT) 65 74 22 2c 22 6e 65 74 77 6f 72 6b 41 64 64 72 65 73 73 22 et","networkAddress"
2021-01-01 23:28:20.924 (Zigbee2MQTT) 3a 33 39 36 33 37 2c 22 70 6f 77 65 72 53 6f 75 72 63 65 22 :39637,"powerSource"
2021-01-01 23:28:20.924 (Zigbee2MQTT) 3a 22 42 61 74 74 65 72 79 22 2c 22 74 79 70 65 22 3a 22 45 :"Battery","type":"E
2021-01-01 23:28:20.924 (Zigbee2MQTT) 6e 64 44 65 76 69 63 65 22 2c 22 76 65 6e 64 6f 72 22 3a 22 ndDevice","vendor":"
2021-01-01 23:28:20.924 (Zigbee2MQTT) 58 69 61 6f 6d 69 22 7d 5d .. .. .. .. .. .. .. .. .. .. .. Xiaomi"}]
2021-01-01 23:28:26.207 (Zigbee2MQTT) MqttClient::ping
2021-01-01 23:28:26.207 (Zigbee2MQTT) Sending 2 bytes of data
2021-01-01 23:28:26.208 (Zigbee2MQTT) c0 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. �
2021-01-01 23:28:26.258 (Zigbee2MQTT) Received 2 bytes of data
2021-01-01 23:28:26.258 (Zigbee2MQTT) d0 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. Ю
2021-01-01 23:28:36.182 (Zigbee2MQTT) MqttClient::ping
