Domoticz on Synology
Bertone
Post by Bertone »
I want to migrate my installation (Actually Pi3) to a NAS Synology DS120j.
I installed Domoticz on it, plugged my RFLink on USB port and it was OK.
The NAS recognized the usb port but on domoticz, impossible to had hardware (you can see on attachment).
I read that it was necessary to add a capacitor, you think that it can come from that?
Edit : It seems to be OK because I have a mega Ch340
Thank you
jumbotroll
Re: Domoticz on Synology
Post by jumbotroll »
What version of domoticz did you install?
My packages include USB driver for CH340 and should work..
Domoticz v2020.2.12728-8
http://www.jadahl.com/domoticz_2020.2_6 ... armada37xx
https://paypal.me/Jumbotroll
Jumbotroll
Bertone
Post by Bertone »
I installed the last beta version :
*domoticz_armada37xx-6.2_2020.2.12728-8*
Vortex77
Post by Vortex77 »
I tried to install Domoticz in a Virtual Machine (Virtual machine manager) running DSM 6.2.3 (since there is soon a change to DSM 7 and running Domoticz in a Virtual machine using DSM 6.2.3 would be an option to keep it) but during installation procedure there is an error message: "Please install the following package(s) befroe installing this package: Node.js_v4" I tried to install Node.js_v8 and Node.js_V12 .. which are offered in the package center but it does not help. Could you give me a hint how to install the Domoticz package in a virtual DSM machine? I tried various versions ..
Best regards,
Boris
Bertone
Post by Bertone »
Anyone have an idea for my problem? Or commands to launch to get an idea
erem
Domoticz version: 2021.1
Post by erem »
i would keep the RPi, and abandon the synology idea.
Jumbotroll already announced he will not build for dsm 7, so unless others sep in the future for synology looks bleak.
if you run the rpi from usb or ssd storage with proper backup, it is quite good.
Regards,
Rob
Bertone
Post by Bertone »
hi,
I try another up to find a solution :(
Perhaps use Docker if your Synology supports it: https://domoticz.com/forum/viewtopic.php?f=47&t=35639
