Weerlive.nl
Posted: Wednesday 30 December 2020 13:33
Hallo,
I have the following script running, and would like to add a little more. I am new to this area and could use a little push in the right direction.
I would like to add the following: min and max temperature and wind chill maybe even more later, but with some help from you I would be able to do that.
-- KNMI weerlive.nl for domoticz
-- KNMI Weergegevens via Weerlive.nl
-- http://weerlive.nl/delen.php
-- add Domoticz forum link later
-- 2019-06-19 initial version
local apiKey = "local apiKey"
local location = "51.9991039,5.6747544"
-- create below devices in Domoticz
-- creat dummy hardware device WEERLIVE and add:
local wind = 'weerlive wind' -- wind
local baro = 'weerlive barometer' -- Temp + Humidity + Baro
local text = 'weerlive' -- text
local verw = 'weerlive verwachting' -- text
local vis = 'weerlive visibility' -- visibility
local twind = 'weerlive twind' -- text
local alarm = 'weerlive alarm' -- text
logging = {
-- level = domoticz.LOG_DEBUG -- comment when not in dev
timer = { 'every 10 minutes' },
httpResponses = { 'get_weerlive' },
execute = function(dz, item)
if item.isTimer then
dz.log('weerlive started by trigger: ' .. item.trigger, dz.LOG_INFO)
dz.openURL({
url = 'http://weerlive.nl/api/json-data-10min.php?key=' .. apiKey .. '&locatie=' .. location,
method='GET',
callback='get_weerlive'
elseif item.isHTTPResponse then
dz.log('HTTPResponse event was triggered by ' .. item.trigger, dz.LOG_INFO)
if (not item.ok or not item.isJSON) then
dz.log('buienRadar call failed', dz.log_ERROR)
dz.log('responseOK: ' .. tostring(item.ok), dz.LOG_INFO)
dz.log('statusCode: ' .. item.statusCode, dz.LOG_INFO)
dz.log('statusText: ' .. item.statusText, dz.LOG_INFO)
dz.log('json: ', dz.LOG_INFO)
dz.log(item.json, dz.LOG_INFO)
return
if ( not item.json["liveweer"] ) then
dz.log('weerlive data missing liveweer', dz.LOG_ERROR)
return
local wr = { "Noord", "NNO", "NO", "ONO", "Oost", "OZO", "ZO", "ZZO",
"Zuid", "ZZW", "ZW", "WZW", "West", "WNW", "NW", "NNW" }
function w2d(w)
for i,v in pairs(wr) do
if v == w then
return(22.5*(i-1))
function w2e(w)
local we = { "N", "NNE", "NE", "ENE", "E", "ESE", "SE", "SSE",
"S", "SSW", "SW", "WSW", "W", "WNW", "NW", "NNW" }
if v == w then
return we[i]
local wl = item.json["liveweer"][1]
dz.devices(wind).updateWind(w2d(wl["windr"]),w2e(wl["windr"]),
wl['windms'],0,wl['temp'],wl['gtemp'])
function lvstat(lv)
lv = tonumber(lv)
if lv < 35 then return dz.HUM_DRY
elseif 35 < lv and lv < 45 then return dz.HUM_NORMAL
elseif 45 < lv and lv < 55 then return dz.HUM_COMFORTABLE
elseif 55 < lv and lv < 65 then return dz.HUM_NORMAL
else return dz.HUM_WET
-- dz.BARO_CLOUDY, dz.PARTLYCLOUDY, dz.BARO_STABLE, dz.BARO_SUNNY,
-- dz.BARO_THUNDERSTORM, dz.BARO_NOINFO, dz.BARO_UNSTABLE,
-- dz.BARO_RAIN
function ic2fc(ic)
if ic == "zonnig" or ic =="helderenacht" then return dz.BARO_SUNNY
elseif ic == "halfbewolkt" or ic == "mist"
or ic == "nachtmist" then return dz.BARO_PARTLYCLOUDY
elseif ic == "bewolkt" or ic == "zwaarbewolkt"
or ic == "wolkennacht" then return dz.BARO_CLOUDY
elseif ic == "regen" or ic == "buien" or ic == "hagel"
or ic == "sneeuw" then return dz.BARO_RAIN
elseif ic == "bliksem" then return dz.BARO_THUNDERSTORM
dz.log('unknown icon: ' .. ic, dz.LOG_ERROR)
return BARO_NOINFO
dz.devices(baro).updateTempHumBaro(wl["temp"],wl["lv"],
lvstat(wl["lv"]), wl['luchtd'], ic2fc(wl['image']))
local t = nil
t = wl["samenv"]
if dz.devices(text).text ~= t then
dz.devices(text).updateText(t)
t = wl["verw"]
if dz.devices(verw).text ~= t then
dz.devices(verw).updateText(t)
dz.devices(vis).updateVisibility(wl['zicht'])
t = wl["windr"] .. ' ' .. wl["winds"] .. ' Bft'
if dz.devices(twind).text ~= t then
dz.devices(twind).updateText(t)
if wl["alarm"] == "0" then
t = "no alarms"
t = wl['alarm'] .. ': ' .. wl['alarmtxt']
if dz.devices(alarm) ~= t then
dz.devices(alarm).updateText(t)
