Daikin CMPfreq logging (defrosts)
Posted: Sunday 27 December 2020 23:17
Dear all,
I want to log the cmpfreq for my Daikin airconditioner to see when the outsideunit go to defrost action and how calm the unit is running, but there is no option inside the default domoticz plugin called Daikin airconditioner, i found a pyton script from github but that one is linked to the default build-in plugin...
What do i see.
visit: http://192.168.0.250/aircon/get_sensor_info
ret=OK,htemp=23.0,hhum=-,otemp=4.0,err=0,cmpfreq=38,mompow=7
Information:
htemp=inside room temp, hhum= not supported on my unit only the Ururu Sahara has this option i think.
otemp= Outside temp, cmpfreq= The outside compressor load normaly between 12 to 84 max, mompow= Inside unit workload
Is there anyway i can edit the default script and where do i find the file? i cannot find it anywhere to edit it, most easy way should be edit hhum or htemp for me.
If i need to offer the hhum(inside temp) option so be it.
Anyone can assist me where to edit/find the config file inside the terminal console ?
of course if anyone know a script to log cmpfreq that would also be fine.
Note: The default Daikin power consumption scheme you cannot see any defrost action because it is too short 5-10 minutes.
Edit:phyton script on github: https://github.com/leejoow/domoticz_daikin_BRP069A42
A defrost action wil show up as cmpfreq=84 that is just the max compressor speed for about 5 to 15 minutes.
What do i see.
Information:
