New build from source error with CMAKE
Posted: Monday 21 December 2020 10:33
Hardware: RPI4B
Build: Trying to update to lateste version as on 21 dec 2020
Steps to reproduce: rm -Rf dev-domoticz and try new git pull and cmake and make
I tried to update this morning and got all sort of errors about local modified files (did not do that , buut anyway) and decided to remove all dev-domoticz and start from scratch again. Had some error before a while back and this was my fix back then.
However, I get a new error now and I am not sure if I can just ignore this or must this be fixed.
I tried it a couple of times and check the wiki https://www.domoticz.com/wiki/Build_Dom ... rom_source for changes but that is exactly how I am trying to build again.
Is this error save to ignore or did something break because of a change?
Thanks for your response!!
-- Found OpenSSL: /usr/lib/arm-linux-gnueabihf/libcrypto.so (found version "1.1.1d")
-- WITH_DLT = OFF
CMake Warning at extern/mosquitto/CMakeLists.txt:102 (FIND_PACKAGE):
By not providing "FindcJSON.cmake" in CMAKE_MODULE_PATH this project has
asked CMake to find a package configuration file provided by "cJSON", but
CMake did not find one.
Could not find a package configuration file provided by "cJSON" with any of
the following names:
cJSONConfig.cmake
cjson-config.cmake
Add the installation prefix of "cJSON" to CMAKE_PREFIX_PATH or set
"cJSON_DIR" to a directory containing one of the above files. If "cJSON"
provides a separate development package or SDK, be sure it has been
installed.
-- Optional dependency cJSON not found. Some features will be disabled.
