New clock: haymanclock
Further,I've copied 'clock' to 'basicclock' and made it responsive.
That means that 'basicclock', 'stationclock', 'flipclock' and 'haymanclock' will automatically scale to the block width.
You can reduce the width of the clock via two parameters:
- width: Instead of the width of the block the value of this parameter will be used as width of the clock
- scale: This is a scale factor (0..1) to scale down the width of the clock, relative to the block width
