.js Function user variables
Posted: Saturday 19 December 2020 9:59
by Enz0jacco
hey guys,
i've got the following situation:
I use two user variables which can only be either 'Open' or 'Closed'
I want the background color to change according this status.
I tried the following but my js knowledge is not very good:
function getStatus_v18(block){
var idx = block.idx;
var device = block.device;
   if(parseString(device['Data'])='Open'){
      block.addClass='Klepopen';
   else {
      block.addClass='Klepdicht';
any ideas?
Re: .js Function user variables
Posted: Saturday 19 December 2020 10:11
by madpatrick
This is my setup.
in custom.js
var trigger_207 = false; //Alarm modefunction getStatus_207(block)
function getStatus_207(block) {
    var Data = block.device.Data;
    if(device['Status']=='On') {
        trigger_207 = true;
        block.addClass = 'warning1';	// set the addClass parameter for block 207
    else {
        block.addClass = ''; 		// reset the addClass parameter for block
    handleWarning();
in custom.css
.warning1 {
   	background: rgba(255,0,0,0.6) !important;
	background-clip: padding-box;
	border: 3px solid white !important;
	border-radius: 15px!important;
Posted: Saturday 19 December 2020 12:39
by Lokonli
Enz0jacco wrote: Saturday 19 December 2020 9:59 hey guys,
   else {
any ideas?
The if statement is wrong. Change it to:
if(parseString(device['Data'])=='Open'){
(The single '=' is an assignment, for comparison use '==')
Posted: Saturday 19 December 2020 13:35
by Enz0jacco
omg silly me, I could've known that.
unfortunately that was not the only problem.
I think maybe that var device and data is not correct but I'm not sure what it should be as it is a user variable.
Posted: Saturday 19 December 2020 14:20
by Lokonli
O yes, indeed.
For variables it's device['Value'] instead of device['Data']
Posted: Saturday 19 December 2020 14:29
by Enz0jacco
Ok did that and now I think there is something wrong with the getstatus part. I tried to put the v18 between quotes but that doesnt do the trick either.
Posted: Saturday 19 December 2020 15:25
by Lokonli
And remove parseString...
Posted: Saturday 19 December 2020 15:41
by Enz0jacco
ah makes sense ! its working perfectly thnx again!
