Steinel IS 140-2
Posted: Friday 18 December 2020 14:07
Hello all,
I've recently added the Steinel IS 140-2 PIR to my Smart Home and have included it in the ZWave network. It shows up properly in the Hardware setup, so inclusion seems to have gone correctly. It has been working very well in 'Normal' mode; ie. switching the attached lights when you come near...
However, I was expecting (from reading other threads mentioning this device) that there would be at least one device added to Domoticz as well. I'm expecting a) a trigger switch when motion is detected and hopefully also b) a lux measurement and maybe even c) a switch to manually switch on/off the attached lights.
Looking at the manual, I've already tried switching parameter 9 to "Slave mode with gateway checking" and also tried associating Group 4 (the "Ambient light- Multilevel Sensor Report") with my ZWave dongle (device 1). But still, no new devices are showing up.
And, now that I've switched it to Slave mode, it's no longer controlling the lights attached itself. This indicates to me that at least it's found the lifeline, but
Anyone any tips on what to try next? FYI I'm on Domoticz 2020.2 and I'm using the Aeotec ZStick Gen5.
Thanks in advance!
mvdl
Thanks in advance!
mvdl
