Wiki Script, don't work "Python - Monitor Domoticz IP address"
Posted: Friday 18 December 2020 10:52
by bjornsundberg
I Need to have a IP discovery script and "Python - Monitor Domoticz IP address" looks fine but it dosent work. I think urllib2 is the problem.
Any tips on how to get this to work:
https://www.domoticz.com/wiki/Python_-_ ... IP_address
Re: Wiki Script, don't work "Python - Monitor Domoticz IP address"
Posted: Friday 18 December 2020 20:47
by waaren
bjornsundberg wrote: Friday 18 December 2020 10:52
The port number was missing from this python script and the script is written for python2. I now updated the wiki script to include the port number and also added a version that works with python3. (converted from the original using the 2to3 tool (sudo apt install 2to3) )
I tested them successfully on my systems but if it still not OK for you, please include the errors when executed from the command line.
Posted: Sunday 20 December 2020 16:10
by erem
IMHO that script has no purpose.
you publish the new ip address to a sensor you can no longer read, since the ip address has changed.
much better would be an email with the new ip address.
better use a portscanner and scan your network for open port 8080, or whatever port you use. NMAP is a good portscanner
just my S.02
Posted: Sunday 20 December 2020 19:16
by bjornsundberg
erem wrote: Sunday 20 December 2020 16:10
just my S.02
Hi, Sorry for not explaining. I will use it to publish to a mqtt broker that recieves the IP adress. Do you know how to fix the script?
Posted: Sunday 20 December 2020 23:30
by waaren
bjornsundberg wrote: Sunday 20 December 2020 19:16
I fixed the script on the wiki page.
Posted: Monday 21 December 2020 22:18
by bjornsundberg
waaren wrote: Friday 18 December 2020 20:47
Just tested with python3 script but this is the results:
pi@raspberrypi:~/domoticz/scripts/python $ python ip_address.py
File "ip_address.py", line 8, in <module>
import urllib.request, urllib.error, urllib.parse
ImportError: No module named request
Posted: Monday 21 December 2020 23:09
by waaren
bjornsundberg wrote: Monday 21 December 2020 22:18
did you try
after removing the first (shebang) line of the scripts ?
what do you see when entering
python --version
python3 --version
python2 --version
Posted: Tuesday 22 December 2020 18:58
by bjornsundberg
Hi again,
Version of Python:
pi@RPi3:~/domoticz/scripts/python $ python --version
Python 2.7.16
pi@RPi3:~/domoticz/scripts/python $ python3 --version
Python 3.7.3
pi@RPi3:~/domoticz/scripts/python $ python2 --version
Python 2.7.16
Running "python3 ip_address.py"
pi@RPi3:~/domoticz/scripts/python $ python3 ip_address.py
File "ip_address.py", line 27, in <module>
json_object = json.loads(domoticzrequest(domoticzurl)) # retrieve sensor data
File "ip_address.py", line 22, in domoticzrequest
response = urllib.request.urlopen(request)
File "/usr/lib/python3.7/urllib/request.py", line 222, in urlopen
return opener.open(url, data, timeout)
File "/usr/lib/python3.7/urllib/request.py", line 531, in open
response = meth(req, response)
File "/usr/lib/python3.7/urllib/request.py", line 641, in http_response
'http', request, response, code, msg, hdrs)
File "/usr/lib/python3.7/urllib/request.py", line 569, in error
return self._call_chain(*args)
File "/usr/lib/python3.7/urllib/request.py", line 503, in _call_chain
result = func(*args)
File "/usr/lib/python3.7/urllib/request.py", line 649, in http_error_default
raise HTTPError(req.full_url, code, msg, hdrs, fp)
urllib.error.HTTPError: HTTP Error 401: Unauthorized
br
Björn
Posted: Wednesday 23 December 2020 0:08
by waaren
bjornsundberg wrote: Tuesday 22 December 2020 18:58
Seems to be an authorisation issue. (are you authorized to access domoticz without password?)
Make sure that in the Security section in the settings (Setup > Settings > System > Local Networks (no username/password) you allow 127.0.0.1 (and / or ::1 when using IPv6 ) to not need a password.
