Tasmota ->MQTT->Domoticz issue (Solved)
Posted: Wednesday 16 December 2020 16:23
I trying to switch two virtual devise from Tasmota using MQTT:
One of the has IDX 534 and the second 1081
As you can see the message to 1081 fails.
I tried another MQTT format, still the same response
The configuration of the devises looks similar
Does someone has an idea what could be wrong?
2020-12-14 22:14:03.389 MQTT: Topic: domoticz/in, Message: {"idx":534,"nvalue":1}
2020-12-14 22:15:20.069 MQTT: Topic: domoticz/in, Message: {"idx":1081,”nvalue":1}
2020-12-14 22:15:20.070 Error: MQTT: Invalid data received!
2020-12-16 15:56:09.934 MQTT: Topic: domoticz/in, Message: {"command":"switchlight","idx”:1080,"switchcmd":"On"}
2020-12-16 15:56:09.934 Error: MQTT: Invalid data received!
2020-12-16 15:56:10.927 MQTT: Topic: domoticz/in, Message: {"command":"switchlight","idx”:1080,"switchcmd":"Off"}
2020-12-16 15:56:10.927 Error: MQTT: Invalid data received!
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"Status" : "On",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "Switch",
"SwitchType" : "On/Off",
"SwitchTypeVal" : 0,
"Timers" : "false",
"Type" : "Light/Switch",
"TypeImg" : "lightbulb",
"Unit" : 1,
"Used" : 1,
"UsedByCamera" : false,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "534"
"Status" : "Off",
"StrParam1" : "",
"StrParam2" : "",
"Timers" : "false",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "1080"
