Error: EventSystem: Lua script did not return a commandArray Topic is solved
foscolino
Domoticz version: 2.20
Post by foscolino »
Hi, i use this code to tun-off lamp if this in on for more times, the script work correctly! ;)
But i see always error " Error: EventSystem: Lua script did not return a commandArray" in log...
Can you help me to find error, please?
local atMinute = '02'
if os.date('%M') ~= atMinute then
    print ('Nessuna azione richiesta, esco dallo script')
print ('Procedo con il controllo LUCI Antibagno')
-- script controllo Luci di Casa - Antibagno
t1 = os.time()
s = otherdevices_lastupdate['S1 - Antibagno - 192.168.20.73']
-- returns a date time like 2013-07-11 17:23:12
year = string.sub(s, 1, 4)
month = string.sub(s, 6, 7)
day = string.sub(s, 9, 10)
hour = string.sub(s, 12, 13)
difference = (os.difftime (t1, t2))
if (otherdevices['S1 - Antibagno - 192.168.20.73'] == 'On' and difference >= 1800 and difference <= 3600) then
   commandArray['SendNotification']='Luce Antibagno#Attenzione, Luce accesa da più di 30 minuti!'
   print('Luce Antibagno accesa da più di 30 minuti')
elseif (otherdevices['S1 - Antibagno - 192.168.20.73'] == 'On' and difference >= 3600 and difference <= 7200) then
   commandArray['SendNotification']='Luce Antibagno#Attenzione, Luce accesa da più di 1 ora!'
   print('Luce Antibagno accesa da più di 1 ora')
Re: Error: EventSystem: Lua script did not return a commandArray
foscolino wrote: Wednesday 16 December 2020 11:17 Can you help me to find error, please?
The declaration of commandArray should be earlier in your script. Use below modified script
local myDevice = 'S1 - Antibagno - 192.168.20.73'
local function timestamp(dateString, pattern)
    local pattern = pattern or  "(%d+)%-(%d+)%-(%d+)%s+(%d+):(%d+):(%d+)"
    local year, month, day, hour, minute, seconds = dateString:match(pattern)
    return os.time( { year = year, month = month, day = day, hour = hour, min = minute, sec = seconds } )
local deltaSeconds = timestamp( otherdevices_lastupdate[myDevice] ) - os.time()
if (otherdevices[myDevice] == 'On' and deltaSeconds >= 1800 and deltaSeconds <= 3600) then
elseif (otherdevices[myDevice] == 'On' and deltaSeconds >= 3600 and deltaSeconds <= 7200) then
foscolino
Post by foscolino »
Hi waaren, thank you very much.
error is disappeared ;)
