Native secure access
hjzwiers
Post by hjzwiers »
Current browsers are giving more warnings over errors in SSL certificate when logging in remotely through your own domain.
How to fix this is well documented in:
https://www.domoticz.com/wiki/Native_se ... ts_Encrypt
This works fine.
The only issue is that every update of Domoticz overwrites your certificate, and so a lot of work when updating (specially when you frequently install Beta's). Is there any way to integrate this by defining your domain in for example the settings file?
Re: Native secure access
hjzwiers wrote: Tuesday 15 December 2020 18:38 The only issue is that every update of Domoticz overwrites your certificate, and so a lot of work when updating (specially when you frequently install Beta's). Is there any way to integrate this by defining your domain in for example the settings file?
See this post where it is explained how you can set the name of the certificate domoticz use.
hjzwiers
Post by hjzwiers »
Thnx for forwarding this link.
Added:
DAEMON_ARGS="$DAEMON_ARGS -sslcert /opt/domoticz/letsencrypt_server_cert.pem"
in /etc/init.d/domoticz.sh (change /opt/domoticz to your domoticz directory)
followed all instructions again in: https://www.domoticz.com/wiki/Native_se ... ts_Encrypt
reforwarded port 80 to server (which is a lot of manual work, because I have nextcloud running on another server which also needs port 80 access)
Now my certificate is on my domain, and all is ok on https ............
Problem is how to make this automated so I don't need to repeat all these actions every three months ......., to do is test if I can now upgrade Domoticz without the certificate being broken
