Marley MenV 180 II Heat Recovery Unit
ccaru
Post by ccaru »
I have a Marley MenV 180 Heat Recovery Unit which comes with an RF remote.
I was able to detect the remote using Lighting 4/PT2262. The buttons are On/Off, Increase Fan Speed, Decrease Fan Speed and Summer Mode.
However, I don't seem to be able to control the Unit using Domoticz without a remote.
I have a couple of questions:
1. Is Lighting 4 also transmitting from RFXCOM or only receiving?
2. How do I determine the state of the device from Domoticz ? For example the On/Off switch is a single button on the remote. I press it once to change state from On to Off or vice versa. But in the log I can see that multiple signals are sent in quick succession when i press the button once. The longer I press, the quicker the action is. I have tried a number of switch types - contact, on/off, but I don't seem to find a good way to control.
thanks for any insight!
Claude
RFXCom, Somfy RTS, 433Mhz Lighting, Evohome, Smart watering via Netatmo, solenoid valves, soil humidity sensors, Airthings Radon via bluetooth, Marley heat recovery fresh air units, Blue Iris, Alexa via DA Bridge.
