Dashticz v3.7 master
Posted: Sunday 13 December 2020 16:43
by Lokonli
I've just released v3.7 master.
It contains all functionality from v3.6.9 beta.
Main changes compared to v3.6 master:
Garbage
  • Update of quite some garbage providers
  • New representation as table layout.
  • Customize styling via trashtoday and trashtomorrow css classes
  • Date separator configurable
Dials
  • Dials now enabled for most devices
  • Set the block parameter ``animation`` to ``true`` or ``false`` to enable/disable dial animations.
  • Combine data from several devices
Enhancements
  • Stationclock: new configuration options
  • Graphs: Customize the button icons in custom graphs
  • Colorpicker: Support for WW dimmers (Philips Hue for instance)
  • Configure Dashticz configuration settings in the url. For instance, to start Dashticz with an alternative configuration script use 'http://dashticz ip:port/?cfg=CONFIG.new.js
  • The css class 'timeout' is added to blocks for devices in Domoticz timeout state
  • Button, special blocks: Initiate the 'url' parameter as POST request by setting 'newwindow: 4'
  • Set config setting 'security_panel_lock' to '2' to activate security panel lock in 'Armed Home' mode as well.
New functionality
  • Graph as moving time chart
  • Custom html block
Fixes
  • X10 security motion device
  • Scenes will switch always to on
  • New Covid-19 server
  • PV Output temp device
  • Remove scroll bar of the modal security panel (security panel lock)
For the release notes, check:
https://dashticz.readthedocs.io/en/mast ... notes.html
Re: Dashticz v3.7 master
Posted: Monday 14 December 2020 13:22
by Jimster
Great work!
Posted: Monday 22 February 2021 22:38
by Afterburner
I tried to upgrade to 3.7 from 3.6. I used the git pull command but get a list of merge issues. I'am on ubuntu server that's uptodate. How to solve this?
Posted: Tuesday 23 February 2021 8:06
by Lokonli
Afterburner wrote: Monday 22 February 2021 22:38 Hi,
First, make a backup of your config files (custom/CONFIG.js, custom/custom.js, custom/custom.css) and store them outside the dashticz folder.
You did not make any local changes that you want to keep?
Then:
git fetch origin
git reset --hard origin
This will overwrite your local changes! (including custom.css and custom.js)
Then restore the config files to the custom folder.
If you used the automatic install script, then I recommend to recreate the Docker image with:
make stop
make start
Posted: Tuesday 23 February 2021 20:24
by Afterburner
Thanks for the quick respons and making this wonderfull software work.
Your solution did the job. Something for the manual?
I made a backup already from the custom directory. Appearently however the 'old' files are still there after the update. So a restore is not needed....or do I miss something?
Posted: Tuesday 23 February 2021 20:54
by kiddigital
Although there is a nice Beta branch next to the 'stable' Master branch, I noticed that 3.7 isn't tagged/released in the Master branch. Any specific reason? For people modifying things, having a fixed/tagged commit is a good reference to work with :)
