How to use os.execute in dzVents script
Posted: Monday 07 December 2020 18:33
by Bospieper
I have a small script wich is telling me on a given time if the bedroom door is open or close. This is because I have an airco in that room. So 5 minutes before the airco is on the script checks if the door is open or close. In case of open it sends a notify to my mobile phone. What I want is a spoken message by izsynth by a bluetooth speaker. The speaking part comes from a tutorial from Gadgets-Freaks called Domoticz voice feedback.
Here is the script:
timer = {
'at 22:40'
devices = {
'deurcontact'
logging = {
level = domoticz.LOG_ERROR, -- set to domoticz.LOG_ERROR when all ok
marker = 'Slaapkamer'
execute = function(dz, item, devices)
local deurcontact = dz.devices('Slaapkamer - deurcontact')
if item.isTimer then
if deurcontact.state == 'Off' then
dz.log('Slaapkamerdeur is dicht', dz.LOG_INFO)
elseif deurcontact.state == 'On' then
dz.notify('Slaapkamer', 'slaapkamer deur staat open', dz.PRIORITY_NORMAL,nil,nil, dz.NSS_PUSHOVER)
os.execute("sh /home/pi/domoticz/scripts/play_sound.sh nl ' test ' ")
In the terminal when I give the command: sh play_sound.sh nl 'test' the text is converted to a mp3 file and is audible but in the script nothing happens. I've tried several things from the Domoticz forum but nothing helps.
Maybe some can piont me out what I am doing wrong.
Thanx.
Re: How to use os.execute in dzVents script
Posted: Monday 07 December 2020 20:00
by waaren
Bospieper wrote: Monday 07 December 2020 18:33
Maybe some can point me out what I am doing wrong.
Kind of hard to guess what you tried. "several things" might be clear to you but it does not help in preventing me of pointing you to a topic you have already seen and tried.
Posted: Monday 07 December 2020 20:18
by Bospieper
Hi Waaren,
You are right for me it's clear in what I have tried. As stated before in the terminal setting the play_sound.sh is working.
Tried sudo before the command line (there are topics about rights etc)
I give the play_sound.sh all the rights 777 as user pi
tried several combinations with the quotation marks
tried several combinations with the parentheses
made the play_sound.sh executable.
Posted: Monday 07 December 2020 20:47
by waaren
Bospieper wrote: Monday 07 December 2020 20:18
You might want to look at
this topic where a similar issue was discussed and some possible solutions were posted.
Posted: Monday 07 December 2020 22:00
by Bospieper
Hi Waaren,
I have tried several solutions as mentioned in that topic but unfortunately no positive result. There was one who mentioned something like member to the audiogroup. I looked in to it and saw that only root is member. Don't now if that is right?
Posted: Monday 07 December 2020 22:22
by waaren
Bospieper wrote: Monday 07 December 2020 22:00
Hi Waaren,
Probably depending on which user you use for domoticz?
Posted: Monday 07 December 2020 22:31
by Bospieper
The user is pi within Domoticz and is also the user in the CLI
Posted: Tuesday 08 December 2020 0:25
by waaren
Bospieper wrote: Monday 07 December 2020 22:31
You could try to add user pi to the audiogroup or execute the sh command as root by using sudo
Posted: Tuesday 08 December 2020 16:27
by Bospieper
Hi Waaren,
Working late
I've added user pi to the audio group, that was not the solution.
And yes I already used the sudo before the sh command, also not THE solution.
I am out of options and so do you I presume.
Posted: Tuesday 08 December 2020 17:39
by erem
i assume you refer to this:
https://gadget-freakz.com/domoticz-text-to-speech/
that article is riddled with extra html like <br> and bad formatting.
i assume you removed all that since you state it works from the command line.
that leaves the activation from lua/domoticz as a cause of failure.
you can try to change
into
os.execute("/bin/bash -c" "/home/pi/domoticz/scripts/play_sound.sh nl ' test ')"
and maybe insert something like this into play_sound.sh
echo "test from play_sound.sh" >/home/pi/play_sound.txt
Posted: Tuesday 08 December 2020 19:53
by Bospieper
Hi Erem,
Thanx for also looking in into this problem. Your suggestion of:
os.execute ("/bin/bash -c" "/home/pi/domoticz/scripts/play_sound.sh nl ' test ')"
give some errors related to the quotation marks. [24:40] ')' expected near '/home/pi/domoticz/scripts/play_sound.sh nl ' test ') '
I've tried some possibilities with the double quotation marks but that doesn't seem to help.
Posted: Tuesday 08 December 2020 21:04
by AllesVanZelf
I os.execute like this in one of my scripts:
os.execute('/home/pi/bin/sendsnapshot-nacht.sh')
Make sure the sh file is executable. I used single quotes ' instead of ". Not sure if that makes a different here.
In another script I play a sound by using a dummy switch as "switch on" switch, with the sh file as script://play-sound.sh
In DzVents you can trigger this dummy.
Posted: Wednesday 09 December 2020 12:38
by erem
i created this script test.sh in my home directory
#!/bin/bash
# test script
echo "the test script ran with parameter $1 \"$2\" " >/home/rob/test.txt
and made it executable chmod +x ./test.sh
i created this dzvents script
timer = {
'every minute', -- causes the script to be called every minute
execute = function(domoticz, timer)
os.execute("/home/rob//test.sh nl 'text to be spoken' ")
domoticz.log('Timer event was triggered by ' .. timer.trigger, domoticz.LOG_INFO)
in the log i see
2020-12-09 12:21:00.159 Status: dzVents: Info: Timer event was triggered by every minute
2020-12-09 12:21:00.159 Status: dzVents: Info: ------ Finished os-ex-test
2020-12-09 12:22:00.236 Status: dzVents: Info: ------ Start internal script: os-ex-test:, trigger: "every minute"
2020-12-09 12:22:00.243 Status: dzVents: Info: Timer event was triggered by every minute
2020-12-09 12:22:00.243 Status: dzVents: Info: ------ Finished os-ex-test
and the file test.txt contains
the test script ran with parameter nl "text to be spoken"
this should get you on the path to a working solution
mind you, the file test.txt will be created with the owner that runs domoticz, root in my case.
if you want to read it as pi, add a chmod 755 /home/rob/test.txt after the echo statement in test.sh
suc6
Posted: Thursday 10 December 2020 15:40
by Bospieper
Hi Erem,
Thanx for your reaction. Because of testing, adjusting files etc,etc the result is no sound whatsoever.
So I have to deal first with that problem before executing your suggestion.
Time is here a factor of importance because I almost don't have any
But as soon I have the audio working again I let you know the results.
Thanx in advance.
Piet
Posted: Saturday 19 December 2020 20:18
by Bospieper
So, everything is up and running again even spotify on my raspberry
I am now trying your suggestion and let you know.
Posted: Monday 21 December 2020 13:52
by Bospieper
erem wrote: Wednesday 09 December 2020 12:38
#!/bin/bash
# test script
timer = {
in the log i see
suc6
Hi Erem,
So I tested but still no luck. First I implemented your scripts in my system with minor changes for the path to test.sh etc. This is working, I can see the text file changing when I adjust for example the line " the test script ran with parameter..........". So the os.execute works but I am not having the same lines as you have in my logfiles. The line Info:--------Start internal script: os-ex-test: trigger: 'every minute' is missing in my logfile.
I then changed in your Dzvents script the line: os.execute("/home/rob//test.sh nl 'text to be spoken' ") to os.execute(" /home/pi/domoticz/scripts/sh play_sound.sh nl 'dit is een test' ") I also used the // in your line
In that way my os.execute runs every minute and I can test the several options. This is what my log shows:
Status: dzVents: Info: Test: ------ Start internal script: Test:, trigger: "every minute"
2020-12-21 13:48:00.385 Status: dzVents: Info: Test: Timer event was triggered by every minute
2020-12-21 13:48:00.385 Status: dzVents: Info: Test: ------ Finished Test
2020-12-21 13:48:00.387 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
Any suggestions?
Grz. Piet
Posted: Monday 21 December 2020 14:11
by erem
os-ex-test is the name of my dzevents script.
you see Start internal script: Test:, trigger: "every minute" as your dzvents script is named Test
try and change
to
os.execute(" /home/pi/domoticz/scripts/play_sound.sh nl 'dit is een test' ")
if the play_sound.sh script is executable, no need to call sh.
if play_sound.sh is not executable, do chmod +x play_sound.sh to make i executable.
Posted: Wednesday 23 December 2020 14:32
by erem
and also, if your domoticz runs as root, try and see if play_sound.sh functions when run as root
to become root, do sudo su, this should change the $ prompt to the # prompt
