trojan:Win32/Wacatac.B!ml and Win32/CryptInject!ml
Posted: Monday 07 December 2020 13:13
by vicen
Hello
Last monts I was using domoticz under windows version stable 2020_2.11995, without problems, recently to activate python and to activate zibbee2mqtt i updated to beta versions. Today I observed an extrange behaviour in my pc and it was noticed some trojan in the file installation of domoticz beta file: C:\Users\vicen\Downloads\domoticz_windows_x86 (10)\DomoticzSetup_2020_2.12715.exe and trying to update to new version it was blocked with the today version 2020_2.12731.exe.
To return to stable version 2020_2.11995, the instalation system days says it's no possble maintaining the configuration.
I think some expert should verify this informations.
Thanks by your return
Best regards
Vicen
Re: trojan:Win32/Wacatac.B!ml and Win32/CryptInject!ml
Posted: Monday 07 December 2020 13:53
by plugge
Had a similar experience with two such beta files. Windows Defender signaled a threat. Kaspersky said 'no threat'.
Try to double check it with, f.e. Kaspeski, https://opentip.kaspersky.com/ .
If that doesn't see a threat, then it's clean.
Posted: Tuesday 08 December 2020 19:39
by vicen
Thanks a lot by your suggestion plugge, I verified with kaspersky and no trojan was found I reinstall the new beta version 2020_2.12731.
I see you are using too windows 10 with domoticz, has you experience with zigbee2mqtt pluggin?
Best regards
Vicen
Posted: Wednesday 09 December 2020 0:27
by plugge
vicen wrote: Tuesday 08 December 2020 19:39 I see you are using too windows 10 with domoticz, has you experience with zigbee2mqtt pluggin?
I neither use zigbee nor mqtt. I restrict my system to RFXrtx and wifi, to keep it simple.
