Page 1 of 4
Python plugin: Ubiquiti Unifi Presence
Posted: Friday 04 December 2020 21:27
by wizzard72
Re: Python plugin: Ubiquiti Unifi Presence
Posted: Friday 04 December 2020 22:50
by iganin
I have got three Unifi APs. One of them in my garden. Is there a way to detect when my phone is connected to the AP which is located in my garden? The idea is to send a door bell to garden when i'm there.
Posted: Tuesday 08 December 2020 0:03
by rbosch
I have installed the plugin. Trying to use it with a Dream Machine Pro.
Something goes wrong as I get these errors:
2020-12-07 23:52:04.897 Error: (Unifi Presence) ----> Line 897 in '/usr/lib/python3/dist-packages/requests/models.py', function json
2020-12-07 23:52:04.898 Error: (Unifi Presence) ----> Line 518 in '/usr/lib/python3/dist-packages/simplejson/__init__.py', function loads
2020-12-07 23:52:04.898 Error: (Unifi Presence) ----> Line 370 in '/usr/lib/python3/dist-packages/simplejson/decoder.py', function decode
2020-12-07 23:52:04.898 Error: (Unifi Presence) ----> Line 400 in '/usr/lib/python3/dist-packages/simplejson/decoder.py', function raw_decode
2020-12-07 23:52:14.868 Error: (Unifi Presence) 'onHeartbeat' failed 'IndexError':'string index out of range'.
2020-12-07 23:52:14.868 Error: (Unifi Presence) ----> Line 658 in '/home/pi/domoticz/plugins/Domoticz-Unifi-Presence/plugin.py', function onHeartbeat
2020-12-07 23:52:14.868 Error: (Unifi Presence) ----> Line 345 in '/home/pi/domoticz/plugins/Domoticz-Unifi-Presence/plugin.py', function onHeartbeat
2020-12-07 23:52:24.838 Error: (Unifi Presence) 'onHeartbeat' failed 'IndexError':'string index out of range'.
2020-12-07 23:52:24.838 Error: (Unifi Presence) ----> Line 658 in '/home/pi/domoticz/plugins/Domoticz-Unifi-Presence/plugin.py', function onHeartbeat
2020-12-07 23:52:24.838 Error: (Unifi Presence) ----> Line 345 in '/home/pi/domoticz/plugins/Domoticz-Unifi-Presence/plugin.py', function onHeartbeat
2020-12-07 23:52:34.858 Error: (Unifi Presence) 'onHeartbeat' failed 'IndexError':'string index out of range'.
2020-12-07 23:52:34.858 Error: (Unifi Presence) ----> Line 658 in '/home/pi/domoticz/plugins/Domoticz-Unifi-Presence/plugin.py', function onHeartbeat
2020-12-07 23:52:34.858 Error: (Unifi Presence) ----> Line 345 in '/home/pi/domoticz/plugins/Domoticz-Unifi-Presence/plugin.py', function onHeartbeat
Posted: Tuesday 08 December 2020 7:31
by azonneveld
This is very nice work!
I have not tested it, because I use homekit-homebridge for presence detection.
I was wondering, is it possible to toggle a portforwarding on/off using the the unifi api?
Posted: Tuesday 08 December 2020 8:55
by wkossen
iganin wrote: Friday 04 December 2020 22:50
Just a more or less unrelated answer, wouldn't using Owntracks as a way to determine location be helpful here? (unless you have a lot of gps drift) you could geofence your garden and house and other areas and get quite good approximations of where your phone is.
Posted: Tuesday 08 December 2020 16:35
by wizzard72
rbosch wrote: Tuesday 08 December 2020 0:03
I don't have Dream Machine Pro, so maybe the API output is a little different. Can you post the output of the following url:
https://dreammachineIPAddres:8443/api/s/{}/stat/health
Posted: Tuesday 08 December 2020 16:38
by wizzard72
I think I can.
Do you have an idea how I can present that data in the Domoticz GUI?
Posted: Tuesday 08 December 2020 16:58
by iganin
It becomes interesting. I saw that api can get AP ID for specific MAC from the UniFi controller. However, I have no skills to implement it.
Try "User A in Garden" when the user with MAC A is connected to AP which is labelled as "Garden"
Posted: Tuesday 08 December 2020 17:16
by wizzard72
I want to make a general function so every one can use it. I can make a who is connected to an AP. That can probably be a text device. So you get for example 3 text devices (AP1 / AP2 / AP3 - I can read the names of the AP's from the API) and add to these text devices the devices connected to that AP.
Then in lua you can do your logic
Posted: Tuesday 08 December 2020 17:50
by iganin
It's fine for me.
Posted: Tuesday 08 December 2020 19:36
by wizzard72
I put it on my todo list
Posted: Tuesday 08 December 2020 20:53
by rbosch
The Dreammachine Pro needs to be addressed at port 443. Doing this from the browser result in receiving the welcome screen. But this is probably not what you are looking for. I have Talend API tester installed, so I can fire some json at the machine, but my json knowledge is very limited so I would need some detailed instruction.
Thx for helping!
Posted: Tuesday 08 December 2020 21:04
by iganin
I try to start the plugging on Docker and get this
2020-12-08 20:57:10.090 Status: (UniFi Presence) Started.
2020-12-08 20:57:10.147 Error: (UnifiPresence) failed to load 'plugin.py', Python Path used was '/opt/domoticz/plugins/Domoticz-Unifi-Presence/:/usr/lib/python38.zip:/usr/lib/python3.8:/usr/lib/python3.8/lib-dynload:/usr/local/lib/python3.8/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.8/dist-packages'.
2020-12-08 20:57:10.148 Error: (UniFi Presence) Module Import failed, exception: 'ModuleNotFoundError'
2020-12-08 20:57:10.148 Error: (UniFi Presence) Module Import failed: ' Name: requests'
2020-12-08 20:57:10.148 Error: (UniFi Presence) Error Line details not available
It seems i'm missing some python modules. Going to investigate it as I use my own container.
Posted: Saturday 12 December 2020 13:07
by wizzard72
rbosch wrote: Tuesday 08 December 2020 20:53
Thx for helping!
Aha, didn't know that the Dreammachine Pro used port 443. Can you test this,you need to be logged into the Dreammachine webpage and then:
https://dreammachineIPAddres:443/api/s/ ... tat/health
Can you paste the result or send me a PM
Posted: Saturday 12 December 2020 13:08
by wizzard72
iganin wrote: Tuesday 08 December 2020 21:04
Looks like you don't have the Python3 module requests
Posted: Tuesday 15 December 2020 10:45
by wizzard72
Updated the plugin.
Done some improvements:
- detect the hardware in the site
- the pulled hardware information is directly connected to the detected hardware
- the dreammachine (pro) use a slightly different login url. In the hardware page you now can select Dreammachine or Controller
Because of changes in the hardware tab, you have to update the plugin (git pull) and restart domoticz.
Posted: Tuesday 22 December 2020 10:22
by Luuc_a
Hi Wizard,
Because of the Christmas holidays I have some time to test the update
Unfortunaly it's not working for my setup. The errors I get are:
2020-12-22 10:18:23.171 Error: (Unifi) 'onHeartbeat' failed 'KeyError'.
2020-12-22 10:18:23.171 Error: (Unifi) ----> Line 835 in '/home/pi/domoticz/plugins/Domoticz-Unifi-Presence/plugin.py', function onHeartbeat
2020-12-22 10:18:23.171 Error: (Unifi) ----> Line 412 in '/home/pi/domoticz/plugins/Domoticz-Unifi-Presence/plugin.py', function onHeartbeat
2020-12-22 10:18:23.171 Error: (Unifi) ----> Line 463 in '/home/pi/domoticz/plugins/Domoticz-Unifi-Presence/plugin.py', function request_details
The output of the API is:
{"meta":{"rc":"error","msg":"api.err.LoginRequired"},"data":[]}
I use a Unifi Gateway Pro 3.
Posted: Thursday 07 January 2021 9:41
by David82
I think there is a probleem with de login command.
with correct login data I get this:
2021-01-07 08:07:48.277 Status: (UniFI) Started.
2021-01-07 08:07:49.313 (UniFI) Debug logging mask set to: NONE
2021-01-07 08:07:49.313 (UniFI) setVersionCheck - Plugin allowed to start (triggered by: onStart)
2021-01-07 08:07:49.313 (UniFI) Number of icons loaded = 3
2021-01-07 08:07:49.313 (UniFI) onStart: Items = UnifiPresenceAnyone
2021-01-07 08:07:49.313 (UniFI) onStart: Icon 101 Name = UnifiPresence
2021-01-07 08:07:49.313 (UniFI) onStart: Items = UnifiPresenceOverride
2021-01-07 08:07:49.313 (UniFI) onStart: Icon 102 Name = UnifiPresence
2021-01-07 08:07:49.313 (UniFI) onStart: Items = UnifiPresenceDevice
2021-01-07 08:07:49.313 (UniFI) onStart: Icon 103 Name = UnifiPresence
2021-01-07 08:07:49.309 Status: (UniFI) Entering work loop.
2021-01-07 08:07:49.310 Status: (UniFI) Initialized version 2.5.0, author 'Wizzard72'
2021-01-07 08:07:50.475 (UniFI) detect Unifi Devices: Invalid login, or login has expired
2021-01-07 08:07:50.476 (UniFI) create_devices: Found phone to monitor from configuration = Phone1=00:11:32:18:B0:XX
2021-01-07 08:07:59.998 (UniFI) onHeartbeat: Attempting to reconnect Unifi Controller
2021-01-07 08:08:00.885 (UniFI) onHeartbeat: Requesting Unifi Controller details
2021-01-07 08:08:00.906 (UniFI) request_details: Invalid login, or login has expired
2021-01-07 08:08:00.927 (UniFI) request_online_phones: Invalid login, or login has expired
2021-01-07 08:08:00.927 (UniFI) ProcessDevices: Total Phones connected = 0
2021-01-07 08:08:05.439 (UniFI) onHeartbeat: Attempting to reconnect Unifi Controller
2021-01-07 08:08:06.204 (UniFI) onHeartbeat: Requesting Unifi Controller details
2021-01-07 08:08:06.224 (UniFI) request_details: Invalid login, or login has expired
2021-01-07 08:08:06.243 (UniFI) request_online_phones: Invalid login, or login has expired
2021-01-07 08:08:06.244 (UniFI) ProcessDevices: Total Phones connected = 0
with the incorrect login
2021-01-07 08:08:44.504 Status: (UniFI) Started.
2021-01-07 08:08:45.538 (UniFI) Debug logging mask set to: NONE
2021-01-07 08:08:45.538 (UniFI) setVersionCheck - Plugin allowed to start (triggered by: onStart)
2021-01-07 08:08:45.538 (UniFI) Number of icons loaded = 3
2021-01-07 08:08:45.538 (UniFI) onStart: Items = UnifiPresenceAnyone
2021-01-07 08:08:45.538 (UniFI) onStart: Icon 101 Name = UnifiPresence
2021-01-07 08:08:45.538 (UniFI) onStart: Items = UnifiPresenceOverride
2021-01-07 08:08:45.538 (UniFI) onStart: Icon 102 Name = UnifiPresence
2021-01-07 08:08:45.538 (UniFI) onStart: Items = UnifiPresenceDevice
2021-01-07 08:08:45.538 (UniFI) onStart: Icon 103 Name = UnifiPresence
2021-01-07 08:08:45.533 Status: (UniFI) Entering work loop.
2021-01-07 08:08:45.534 Status: (UniFI) Initialized version 2.5.0, author 'Wizzard72'
2021-01-07 08:08:47.203 (UniFI) detect Unifi Devices: Invalid login, or login has expired
2021-01-07 08:08:47.204 (UniFI) create_devices: Found phone to monitor from configuration = Phone1=00:11:32:18:B0:XX
2021-01-07 08:08:56.726 (UniFI) onHeartbeat: Attempting to reconnect Unifi Controller
2021-01-07 08:09:02.448 (UniFI) onHeartbeat: Attempting to reconnect Unifi Controller
2021-01-07 08:09:08.314 (UniFI) onHeartbeat: Attempting to reconnect Unifi Controller
2021-01-07 08:09:14.253 (UniFI) onHeartbeat: Attempting to reconnect Unifi Controller
2021-01-07 08:09:20.174 (UniFI) onHeartbeat: Attempting to reconnect Unifi Controller
unifi controler versie 6.0.36 (Build: atag_6.0.36_14304) (raspberry)
USG-3P
Posted: Monday 11 January 2021 0:15
by rbosch
Thx for the update for the dream machine. I have done a fresh git pull, and selected the Dream machine option.
But still getting errors:
2021-01-11 00:10:06.423 Error: (Unifi Presence) 'onStart' failed 'JSONDecodeError'.
2021-01-11 00:10:06.424 Error: (Unifi Presence) ----> Line 872 in '/home/pi/domoticz/plugins/Domoticz-Unifi-Presence/plugin.py', function onStart
2021-01-11 00:10:06.424 Error: (Unifi Presence) ----> Line 215 in '/home/pi/domoticz/plugins/Domoticz-Unifi-Presence/plugin.py', function onStart
2021-01-11 00:10:06.424 Error: (Unifi Presence) ----> Line 706 in '/home/pi/domoticz/plugins/Domoticz-Unifi-Presence/plugin.py', function detectUnifiDevices
2021-01-11 00:10:06.424 Error: (Unifi Presence) ----> Line 900 in '/usr/local/lib/python3.7/dist-packages/requests/models.py', function json
2021-01-11 00:10:06.424 Error: (Unifi Presence) ----> Line 518 in '/usr/lib/python3/dist-packages/simplejson/__init__.py', function loads
2021-01-11 00:10:06.424 Error: (Unifi Presence) ----> Line 370 in '/usr/lib/python3/dist-packages/simplejson/decoder.py', function decode
2021-01-11 00:10:06.424 Error: (Unifi Presence) ----> Line 400 in '/usr/lib/python3/dist-packages/simplejson/decoder.py', function raw_decode
Looking at this PHP client class from @mallepietje
https://github.com/Art-of-WiFi/UniFi-AP ... ag/v1.1.63, it seems that for querying the API an insert in the base URL should be made by adding /proxy/network/.
if ($this->is_unifi_os) {
$url = $this->baseurl . '/proxy/network' . $path;
} else {
$url = $this->baseurl . $path;
Also some code is dedicated to doing smart stuff with the token:
if ($this->is_unifi_os && $this->request_type !== 'GET') {
$csrf_token = $this->extract_csrf_token_from_cookie();
if ($csrf_token) {
$headers[] = 'x-csrf-token: ' . $csrf_token;
Not sure how to translate this to modifications to your python script.
(I have a lot of general programming knowledge but no python experience).
Hope this helps.
Posted: Monday 11 January 2021 8:58
by wizzard72
@rbosch, can you login into your dreammachine and then change the url into this:
https://dreammachineIP:Port:/api/s/default/stat/device
Can you send me the output by pm.
