QueuedCommand on selector switch not executing
Posted: Thursday 03 December 2020 22:21
I noticed a strange behavior since beta 12501 and still exists in latest beta 12709 but i believe it worked fine in 12497
I have 2 scripts. First triggered script contains these lines:
The result of the first line triggers another script "Check MKs" which contains the line:
So far, so good
Then the second line of the first script should change the state of the selector switch again after 5 sec but it doesn't. No errors, just not switching.
It looks like the queud command 'afterSec(5)' is forgotten by DzVents
But if i disable the line of the second script, then the second line of the first script does switch the selectorswitch after 5sec.
Also tried without the "afterSec" and "silent" but didn't help.
I could not find any related changes in the latest beta's.
What could cause this behavior?
if checkmks then dz.devices('Alarm').switchSelector('Check MKs').afterSec(1) end -- check MK's uitvoeren
if alarmschakelen then dz.devices('Alarm').switchSelector(alarmmodus).afterSec(5) end -- Alarm inschakelen
dz.devices('Alarm').switchSelector(0).afterSec(1).silent()
