Configure failure
Segfault
Domoticz version: GIT
Configure failure
Post by Segfault »
Just updated sources and configure fails. Am I missing some dependency?
-- Detecting CXX compile features - done
-- Submodule update
Submodule 'extern/jsoncpp' (https://github.com/domoticz/jsoncpp) registered for path 'extern/jsoncpp'
Submodule 'minizip' (https://github.com/domoticz/minizip.git) registered for path 'extern/minizip'
Submodule 'extern/mosquitto' (https://github.com/eclipse/mosquitto.git) registered for path 'extern/mosquitto'
Submodule 'extern/sqlite-amalgamation' (https://github.com/azadkuh/sqlite-amalgamation.git) registered for path 'extern/sqlite-amalgamation'
fatal: Needed a single revision
Unable to find current origin/HEAD revision in submodule path 'extern/jsoncpp'
CMake Error at CMakeLists.txt:119 (message):
  git submodule update --init failed with 1, please checkout submodules
Full log here: https://dpaste.com/G5G4P75HM
Re: Configure failure
Segfault wrote: Wednesday 02 December 2020 23:54 Just updated sources and configure fails. Am I missing some dependency?
Just tested on Intel NUC (Debian, Cmake 3.17.2) and Raspberry 4 (Raspbian, Cmake 3.18,3 ) without any issues.
Did you follow this wiki to the letter?
What OS, what cmake?
Segfault
Post by Segfault »
Thanks for reply. Gentoo, cmake-3.19.1, building with openzwave. Just now did a git pull and still the same configure error. :?
Segfault wrote: Thursday 03 December 2020 9:57 Thanks for reply. Gentoo, cmake-3.19.1, building with openzwave. Just now did a git pull and still the same configure error. :?
jsoncpp was moved back from extern to domoticz a couple of builds ago due to problems with the external version. It could be that something in the git config need to be changed for your git, OS or CMake version to make it work.
On my system I still see
.git/modules/extern/jsoncpp/
while I expected it to be here
.git/modules/jsoncpp/
You might want to check this issue (and solution)
on stack overflow
EddyG
Post by EddyG »
I had some compile errors too.
I removed source and did clone both sources (OZW and Domoticz) again and now it compiles ok.
Edit.
OEPS, compile came to a halt in compiling , have to investigate.
In file included from /mnt/extra/Source/dev-domoticz/main/../hardware/MQTT.h:4,
                 from /mnt/extra/Source/dev-domoticz/main/../hardware/MySensorsMQTT.h:3,
                 from /mnt/extra/Source/dev-domoticz/main/mainworker.cpp:76:
/mnt/extra/Source/dev-domoticz/main/../hardware/../main/mosquitto_helper.h:10:10: fatal error: mosquitto.h: No such file or directory
 #include <mosquitto.h>
EddyG wrote: Thursday 03 December 2020 12:42 Compile came to a halt in compiling , have to investigate.
See the same on Raspberry (buster) and on Intel NUC (bullseye) with different cmake andf gcc versions
Opened an issue for it
