We have a Techneco Elga heat pump but have realised it's capacity is not sufficient. We still want to keep using it but are looking at buying another heat pump, a Sprsun CGK/C-22, and combining that with a boiler tank for domestic hot water.
We have a Plugwise Anna thermostat in the liiving room but Plugwise tells me they can only control one heat pump. I am looking for the possibility of controlling both heat pumps and, if needed, the gas fired boiler if it is really cold, in a cascade system.
Any idea's on how I could maybe do this through Domoticz? Maybe using MQTT and Node-Red? How would I control each unit? Through an Opentherrm Gateway? I want to be able to modulate the water temperature for maximum efficiency.
Cascade control heat pumps
Alain
- Domoticz version: 2022.1
Hue | Zigbee2Mqtt | MQTT | P1 | Xiaomi | RFXCom | Modbus | TP-Link | Node-Red | Grafana |
