Zigate and Aqara Relay Error OUT OF RANGE
pfloryann
Post by pfloryann »
From a while i have a strange error from Aqara Relay (i have 2 relays same model in 2 different places of the house). Every few minutes i recived in Domoticz logs error OUT of range from every relays but ONLY ON CHANNEL 1. When it occurs this error all my automation doesn't work or they have a big delay 5-10 seconds. I checked the level signal for every relay is 3 for channel 1 and 4 or better on channel 2. I don't know what is the problem.
2020-11-30 16:04:00.286 Error: (Zigate) ReadCluster 0b04 - 59c0/01 Attribute: 050b Type: 29 Size: 0002 Data: ffff Out of Range!!
2020-11-30 16:06:40.622 Error: (Zigate) ReadCluster 0b04 - c023/01 Attribute: 050b Type: 29 Size: 0002 Data: ffff Out of Range!!
2020-11-30 16:19:00.684 Error: (Zigate) ReadCluster 0b04 - 59c0/01 Attribute: 050b Type: 29 Size: 0002 Data: ffff Out of Range!!
2020-11-30 16:21:41.018 Error: (Zigate) ReadCluster 0b04 - c023/01 Attribute: 050b Type: 29 Size: 0002 Data: ffff Out of Range!!
2020-11-30 16:34:01.025 Error: (Zigate) ReadCluster 0b04 - 59c0/01 Attribute: 050b Type: 29 Size: 0002 Data: ffff Out of Range!!
Domoticz on Raspberry Pi 4 Debian 13 x64
Zigbee2mqtt and zigbee devices (Xiaomi, Ikea,Tuya, Philips, Osram), Broadlink, Solar power Victron Energy, Yeelight, Xiaomi Purifier Pro, Roborock S5, Gree AC, JBL soundbar, Philips Android Tv
pipiche
Re: Zigate and Aqara Relay Error OUT OF RANGE
Post by pipiche »
pfloryann wrote: Monday 30 November 2020 15:38 Hi,
The message indicate that the devices 59c0 , c023 are reported bad data as regards to Instant Power.
Now, you are refering to channel 1 and or channel 2. What channels are you referring ?
Which version of the plugin and which branch are you ?
pfloryann
Post by pfloryann »
59c0 - is Aqara relay from kitchen room lights and c023 is Aqara relay from roller blinds, is 2 different devices. The error is on channel 1 for both relays. I using domoticz 2020.2 build 12709 and Zigate Plugin: 4.12.062 beta branch
I think the problem has arisen since I installed the relay no 2 (c023) but i'm not sure.
pipiche
Post by pipiche »
I don't understand what you mean by Channel 1 ? There is no channel 1 on Zigbee nor on Zigate.
I think he uses the aqara relay https://zigbee.blakadder.com/Xiaomi_LLKZMK11LM.html that has 2 relays (=channel). So he has an issue on one of the 2 relays in the device.
pfloryann
Post by pfloryann »
Yes I use 2 x Xiaomi Aqara relay https://zigbee.blakadder.com/Xiaomi_LLKZMK11LM.html everyone as 2 ways/switches (sorry my bad i said 2 channels in my post) I did not refer to zigbee channels. I have this error only on first way(first switch widget in domoticz or so i think) for both Aqara relays.
pfloryann
Post by pfloryann »
Export from zigate webadmin
export(1).txt
(185.38 KiB) Downloaded 57 times
pipiche
Post by pipiche »
What I need is an export of the Plugin RAW Devices (json).
Could you also enable some debug parameter ( Tools-> Debug Advanced )
- debugLumi
- debugClusters
When they are enabled, then just do the actions on 1 relay (which work) and 1 action on 1 relay which doesn't work.
[EDITED]
You have 2 switches and each of 2 "channels", correct ?
You have the same behaviour on each, correct ?
Behaviour is "ReadCluster 0b04 - c023/…ata: ffff Out of Range!!"
on the other the 2 switches performs the action requested , correct ?
