Blocky and ventilation with two sensors Topic is solved
rolandtwilt
Post by rolandtwilt »
Good morning, I've been puzzling for a while, while the solution is probably simple, but I can't. I would like the fan in the meter cupboard to start extracting when the temperature in the meter cupboard is 8 degrees higher than the temperature in the hall and then only stop extracting when the difference is less than 5 degrees. Example; meter cupboard temp is 38 degrees, hall 30, exhaust on until the temperature differences are only 5 degrees. (degrees randomly) Who can help me with an example Blocky?
Re: Blocky and ventilation with two sensors
rolandtwilt wrote: Sunday 29 November 2020 16:39 Who can help me with an example Blocky?
I don't think you can calculate a delta temperature with a Blockly script.
rolandtwilt
In any case I have been helped because I do know the name of what I am looking for (delta temperature) thank you!
rolandtwilt wrote: Sunday 29 November 2020 18:11 In any case I have been helped because I do know the name of what I am looking for (delta temperature) thank you!
The dzVents script in this post might help to get you started.
rolandtwilt
thank you very much and have a nice day
rolandtwilt
The script is a great start and I'm starting to get it, thanks again
rolandtwilt
this has become the final script:
-- temperature Delta
local temperatureInside = 'temperatuur hal'
local temperatureOutside = 'temperatuur meterkast'
local ventilate = 'ventilate'
return
    on = { devices = { temperatureInside, temperatureOutside, ventilate } },
    execute = function(dz, devices)
one = (dz.devices(temperatureOutside).temperature) - (dz.devices(temperatureInside).temperature)
        a = 4
        b = 2
        if one > a then
            if dz.devices('ventilate').state == 'Off' then dz.devices('ventilate').switchOn() end
        if one < b then
            if dz.devices('ventilate').state == 'On' then dz.devices('ventilate').switchOff() end
thanks a lot!!
