zwave switch MERTEN 507501
Posted: Thursday 26 November 2020 20:52
by peter383
Hallo!
Does anybody know Merten507501 switches? I am not able to include them.
How do I know it is possible to include them?
Is there any idea is it possible?
Thanks for your answers.
Peter
Re: zwave switch MERTEN 507501
Posted: Wednesday 02 December 2020 23:46
by lumbermatt
I managed to associate the Merten 507502 (which is pretty the same one but with two channels).
Before including them you have to exclude it from the previous inclusion or to reset it. Just press three time in a row in less than 1,5s the small black button and then keep it pushed for more than 5s. The module will reset itself.
If you used the Merten FunkConnect! Software (not the "easy" pairing like advertised by Merten), it might have locked the reset function to avoid an unwanted reset. Then you need to revert to the software, remove the lock and exclude the node or reset it.
After that just put your controller in inclusion mode an press press three time in a row in less than 1,5s the small black button. Sometimes the association do not work on the first try and succeeds in a second attempt.
