In the wiki I read the following example:
commandArray['SetSetPoint:MySetPointIdx']='20.5'
Now, this is working just fine, but I was wondering if you NEED to use the IDX or if you can also change the setpoint by using the device name.
Setpoint only adjustable by IDX? Topic is solved
- waaren
Re: Setpoint only adjustable by IDX?
The SetSetPoint command requires an IDX but you can quite easily work around that with:
local tName = 'thermostatName' -- Change to name of thermostat
local function getDeviceID(dev)
return otherdevices_idx[dev]
commandArray['SetSetPoint:' .. getDeviceID(tName)] = '22.5'
return commandArrayDebian buster, bullseye on RPI-4, Intel NUC.
Plantje
Thanks! That would indeed be the next step. You even created the code for me. Great!
Plantje
Worked out just fine!
