Xiaomi has apparently blocked UDP port 9898 with firmware 1.4.1_176.0220 and prevented communication with domotics and other smart home software.
I think so because my gateway suddenly doesn't work after 2 years of operation. See also:
https://translate.google.com/translate? ... Cr-gelben- mihome adapter
https://www.smarthomejetzt.de/xiaomi-mi ... 8-oeffnen/
Greetings Hans
Xioami Gateway not more compatible / Port 9898 now closed Topic is solved
doelle4
Re: Xioami Gateway not more compatible / Port 9898 now closed
Wrong Alarm. Gateway works now also, only Router Problem.
But when Port 9898 is closed , you can make the Fix from the Link
Greetings Hans
Greetings Hans
