Page 1 of 2
dzVents errors
Posted: Monday 23 November 2020 22:40
by roblom
Yesterday I was experimenting with mqtt and node-r ed. But it seems I have broken something in Domoticz. Domoticz is quite unstable and crashes often. When I turn on DzEvents I get the following errors.
2020-11-23 22:11:37.745 Error: dzVents: Error: (3.0.16) Consumption: Problem with module: __data_consumption
2020-11-23 22:11:37.745 Error: EventSystem: in /home/pi/domoticz/dzVents/runtime/dzVents.lua: /home/pi/domoticz/dzVents/runtime/EventHelpers.lua:101: attempt to index a boolean value (local 'fileStorage')
2020-11-23 22:11:45.213 Status: dzVents: Info: Handling events for: "Energie (P1)", value: "8071351;9648730;2817226;6193098;590;0"
It seems it's related to my energy consumption script because when I remove that script from the DzEvents script folder the errors are gone.
The problem is that I have no clue how to solve this so hope someone can help.
My Domoticz
Version: 2020.2 (build 12697)
Build Hash: 34c800ea6-modified
Compile Date: 2020-11-22 13:14:05
dzVents Version: 3.0.16
Python Version: 3.7.3 (default, Jul 25 2020, 13:03:44) [GCC 8.3.0]
Re: dzVents errors
Posted: Monday 23 November 2020 22:57
by roblom
When I add my script that uploads data to pvoutput I get different errors.
Error: dzVents: Error: (3.0.16) PVOutput: Error: the return from PVOutput was :
Error: Error opening url: HTTPS://pvoutput.org/service/r2/addstatus.jsp
Error: dzVents: Error: (3.0.16) PVOutput: HTTP/1.1 response: 28 ==>> Timeout was reached
To be clear, I did not change anything to these scripts and they where working without any errors.
Re: dzVents errors
Posted: Monday 23 November 2020 23:00
by waaren
roblom wrote: Monday 23 November 2020 22:40
The datafile of consumption.lua seems to be corrupt. You can delete it and it will be rebuild automatic at the next execution of consumption.lua
sudo rm <domoticz dir>/scripts/dzVents/data/__data_consumption.lua
Re: dzVents errors
Posted: Monday 23 November 2020 23:08
by waaren
roblom wrote: Monday 23 November 2020 22:57 When I add my script that uploads data to pvoutput I get different errors.
Seems not directly related to the other error. Maybe more corruption happened on your system?
Re: dzVents errors
Posted: Monday 23 November 2020 23:28
by roblom
This seems indeed the cause, after removing the file the error didn't came back.
Re: dzVents errors
Posted: Monday 23 November 2020 23:32
by roblom
Thank you for the tip, I'm going to check for a corrupted card.
Re: dzVents errors
Posted: Tuesday 24 November 2020 18:34
by roblom
Checking the SD card for bad sectors is harder than I thought. It's there something else I could try to solve the error because it seems something hangs in DzEvents.
Error: EventSystem: Warning!, lua script /home/pi/domoticz/dzVents/runtime/dzVents.lua has been running for more than 10 seconds
And it seems that not all the DzEvents scripts does cause the error.
Re: dzVents errors
Posted: Thursday 26 November 2020 22:21
by roblom
sudo badblocks -vsn /dev/sdq
Checking for bad blocks in non-destructive read-write mode
From block 0 to 15558143
Checking for bad blocks (non-destructive read-write test)
Testing with random pattern: done
Pass completed, 0 bad blocks found. (0/0/0 errors)
So no bad blocks but still it seems DzEvents gives errors. Is it possible to reinstall Domoticz? Our is it better to start over from scratch? This is for about Domoticz not a big issue but I also had for example node-red and Mosquito installed so this is less easy.
Re: dzVents errors
Posted: Thursday 26 November 2020 22:51
by waaren
roblom wrote: Tuesday 24 November 2020 18:34
Can you activate dzVents debug logging? [setup][settings][other] (close to the bottom) It might reveal some useful information and / or what is causing this.
Re: dzVents errors
Posted: Friday 27 November 2020 0:58
by roblom
I don't see anything useful only this below.
2020-11-27 00:54:40.700 Error: dzVents: Error: (3.0.17) PVOutput: HTTP/1.1 response: 28 ==>> Timeout was reached
2020-11-27 00:54:40.701 Error: dzVents: Error: (3.0.17) PVOutput: Error: the return from PVOutput was :
2020-11-27 00:55:12.886 Error: EventSystem: Warning!, lua script /home/pi/domoticz/dzVents/runtime/dzVents.lua has been running for more than 10 seconds
2020-11-27 00:55:24.372 Error: EventSystem: Warning!, lua script /home/pi/domoticz/dzVents/runtime/dzVents.lua has been running for more than 10 seconds
I also removed the Domoticz folder, reinstalled Domoticz and recovered the database and put back the lua and DzEvents scripts. But the problem stays the same.
It looks like there is no response from the internet possible causing DzEvents keeps waiting for response or something.
Re: dzVents errors
Posted: Friday 27 November 2020 7:50
by waaren
roblom wrote: Friday 27 November 2020 0:58 It looks like there is no response from the internet possible causing dzVents keeps waiting for response for something.
Could be if you use os.execute(curl ...) or io.popen(curl ... ) in a script but not when using openURL. The openURL passes control to domoticz via the commandURL and does not wait for a response. The response can be catched by another instance (could be the same- but also zero or more other scripts) based on the set callback string but this is an optional- and none blocking mechanism.
It looks like one of the domoticz threads "hangs" on a HTTP call causing the EventSystem thread not getting enough time to process its tasks.
Maybe you can catch relevant information when you activate domoticz debug logging. (warning: It will produce an awful lot of log lines)
The domoticz logfile location and other settings are defined in /etc/init.d/domoticz.sh
the relevant settings are in set to the DAEMON_ARGS var.
with an editor of choice
DAEMON_ARGS="$DAEMON_ARGS -log /var/log/domoticz.log" # or any other OS file
DAEMON_ARGS="$DAEMON_ARGS -loglevel  normal, status, error, debug" #enable debug
#DAEMON_ARGS="$DAEMON_ARGS -loglevel  normal,status,error" # default loglevels (# commented now)
DAEMON_ARGS="$DAEMON_ARGS -debuglevel normal,hardware,received,webserver,eventsystem,python,thread_id"
sudo systemctl daemon-reload
sudo service domoticz stop
sudo service domoticz start
sudo tail -f /var/log/domoticz.log
Re: dzVents errors
Posted: Saturday 28 November 2020 0:32
by waaren
roblom wrote: Friday 27 November 2020 0:58 I don't see anything useful only this below.
I added an extra debug file (module.log) in build 12707 to investigate the issue a bit more and I when I saw the message
Error: EventSystem: Warning!, lua script domoticz/dzVents/runtime/dzVents.lua has been running for more than 10 seconds
once, I could now determine that it was caused by a combination of many time triggered scripts activated in one dzVents.lua pass, one of them in which I have to use wget to get information from my Enphase solar panels. The wget took much longer then normal and this caused the 10 seconds Error.
So maybe if you update to beta 12707 or later and activate dzVents debug mode you can also identify what is causing the message.
btw. I now made the wget script kind of async by separating the wget part from the data processing part using customEvents.
Re: dzVents errors
Posted: Saturday 28 November 2020 9:15
by roblom
I tried to update but it didn't go higher than my current 12705 version. Also not with a manual update using ./updatebeta.
I also saw the error below.
2020-11-28 08:22:34.044 Error: FCM: Could not send message, HTTP Error
2020-11-28 08:22:34.173 Error: Pushover: Could not send message!
Could that be related?
Re: dzVents errors
Posted: Saturday 28 November 2020 14:09
by waaren
roblom wrote: Saturday 28 November 2020 9:15 I tried to update but it didn't go higher than my current 12705 version. Also not with a manual update using ./updatebeta.
Seems that the Linux tar for donload got corrupted somehow. Until someone fix this:
if You replace <domoticz dir>/dzVents/runtime/EventHelpers.lua with below file, you will effectively have the same as in build 12707.
Related in a sense that the issue is triggered by a network hickup of some kind.
EventHelpers.lua (from build 12707)
local _ = require('lodash')
local GLOBAL_DATA_MODULE = 'global_data'
local utils = require('Utils')
local persistence = require('persistence')
local HTTPResponse = require('HTTPResponse')
local Timer = require('Timer')
local Security = require('Security')
local SystemEvent = require('SystemEvent')
local CustomEvent = require('CustomEvent')
local HistoricalStorage = require('HistoricalStorage')
local function EventHelpers(domoticz, mainMethod)
	local globalsDefinition
	local currentPath = globalvariables['script_path']
	if (_G.TESTMODE) then
		-- make sure you run the tests from the tests folder !!!!
		_G.scriptsFolderPath = currentPath .. 'scripts'
		package.path =
			currentPath .. 'scripts/?.lua;' ..
			currentPath .. 'data/?.lua;' ..
			currentPath .. '/../?.lua;' ..
			package.path
	local validEventTypes = 'devices,timer,security,customEvents,system,httpResponses,scenes,groups,variables'
	local inValidEventTypes = 'on,logging,active,data,execute'
	local webRoot = globalvariables['domoticz_webroot']
	local _url = 'http://127.0.0.1:' .. (tostring(globalvariables['domoticz_listening_port']) or "8080")
	local settings = {
		['Log level'] = tonumber(globalvariables['dzVents_log_level']) or 1,
		['Domoticz url'] = _url,
		url = _url,
		webRoot = tostring(webRoot),
		serverPort = globalvariables['domoticz_listening_port'] or '8080',
		dzVentsVersion = globalvariables.dzVents_version,
		domoticzVersion = globalvariables.domoticz_version,
		location = {
			name = utils.urlDecode(globalvariables['domoticz_title'] or "Domoticz"),
			latitude = globalvariables.latitude or 0,
			longitude = globalvariables.longitude or 0,
	if (webRoot ~= '' and webRoot ~= nil) then
		settings['Domoticz url'] = settings['Domoticz url'] .. '/' .. tostring(webRoot)
	_G.logLevel = settings['Log level']
	if (domoticz == nil) then
		local Domoticz = require('Domoticz')
		domoticz = Domoticz(settings)
	local self = {
		['utils'] = utils, -- convenient for testing and stubbing
		['domoticz'] = domoticz,
		['settings'] = settings,
		self.scriptsFolderPath = scriptsFolderPath
		self.dataFolderPath = _G.dataFolderPath
		function self._getUtilsInstance()
			return utils
	function self.getStorageContext(storageDef, module)
		local storageContext = {}
		local fileStorage, value, ok
		--require('lodash').print(1, storageDef)
		if (storageDef ~= nil) then
			-- load the datafile for this module
			ok, fileStorage = pcall(require, module)
			if type(fileStorage) == 'boolean' then
				utils.log('Problem with module: ' .. module, utils.LOG_ERROR)
			package.loaded[module] = nil -- no caching
			if (ok) then
				-- only transfer data as defined in storageDef
				for _var, _def in pairs(storageDef) do
					local var, def
					if (type(_var) == 'number' and type(_def) == 'string') then
						var = _def
						def = {}
						var = _var
						def = _def
					if (def.history ~= nil and def.history == true) then
						storageContext[var] = HistoricalStorage(fileStorage[var], def.maxItems, def.maxHours, def.maxMinutes, def.getValue)
						if (fileStorage[var] == nil) then
							-- obviously this is a var that was added later
							-- initialize it
							storageContext[var] = def.initial
							storageContext[var] = fileStorage[var]
					local var, def
						var = _def
						def = {}
						var = _var
						def = _def
					--require('lodash').print('>', var, def, '<')
						-- no initial value, just an empty history
						if (def.initial ~= nil) then
							storageContext[var] = nil
		storageContext.initialize = function(varName)
			if (storageContext[varName] ~= nil and storageDef[varName].history == nil ) then
				storageContext[varName] = storageDef[varName].initial
		fileStorage = nil
		return storageContext
	function self.writeStorageContext(storageDef, dataFilePath, dataFileModuleName, storageContext)
		local data = {}
			-- transfer only stuf as described in storageDef
			for var, def in pairs(storageDef) do
				if (type(var) == 'number' and type(def) == 'string') then
					data[def] = storageContext[def]
						data[var] = storageContext[var]._getForStorage()
			local ok, err = pcall(persistence.store, dataFilePath, data)
			-- make sure there is no cache for this 'data' module
			package.loaded[dataFileModuleName] = nil
			if (not ok) then
				utils.log('There was a problem writing the storage values', utils.LOG_ERROR)
				utils.log(err, utils.LOG_ERROR)
	local function getEventInfo(eventHandler, mode)
		local res = {}
		res.type = mode
		res.scriptName = eventHandler.name
		if (eventHandler.trigger ~= nil) then
			res.trigger = eventHandler.trigger
		return res
	local function deprecationWarning(moduleName, key, value, quoted)
		local msg
		if quoted then
			msg = 'dzVents deprecation warning: please use "on = { [\'' .. key .. '\'] = { \'' .. tostring(value) .. '\' } }". Module: ' .. moduleName
			msg = 'dzVents deprecation warning: please use "on = { [\'' .. key .. '\'] = { ' .. tostring(value) .. ' } }". Module: ' .. moduleName
		utils.log(msg, utils.LOG_ERROR)
	function self.callEventHandler(eventHandler, subject)
		local useStorage = false
		if (eventHandler['execute'] ~= nil) then
			-- Prepare storage
			if (eventHandler.data ~= nil) then
				useStorage = true
				local localStorageContext = self.getStorageContext(eventHandler.data, eventHandler.dataFileName)
				if (localStorageContext) then
					self.domoticz.data = localStorageContext
					self.domoticz.data = {}
			if (globalsDefinition) then
				local globalStorageContext = self.getStorageContext(globalsDefinition, '__data_global_data')
				self.domoticz.globalData = globalStorageContext
				self.domoticz.globalData = {}
			-- Run script
			local ok, res, info
			local baseType = subject and subject.baseType or ''
			if (baseType == domoticz.BASETYPE_DEVICE) then
				info = getEventInfo(eventHandler, self.domoticz.EVENT_TYPE_DEVICE)
				ok, res = pcall(eventHandler['execute'], self.domoticz, subject, info)
			elseif (baseType == domoticz.BASETYPE_VARIABLE) then
				info = getEventInfo(eventHandler, self.domoticz.EVENT_TYPE_VARIABLE)
			elseif (baseType == domoticz.BASETYPE_SECURITY) then
				info = getEventInfo(eventHandler, self.domoticz.EVENT_TYPE_SECURITY)
				local security = Security(self.domoticz, info.trigger)
				ok, res = pcall(eventHandler['execute'], self.domoticz, security, info)
			elseif (baseType == domoticz.BASETYPE_SCENE or baseType == domoticz.BASETYPE_GROUP) then
				if (baseType == domoticz.BASETYPE_SCENE) then
					info = getEventInfo(eventHandler, self.domoticz.EVENT_TYPE_SCENE)
					info = getEventInfo(eventHandler, self.domoticz.EVENT_TYPE_GROUP)
			elseif (baseType == domoticz.BASETYPE_HTTP_RESPONSE) then
				info = getEventInfo(eventHandler, self.domoticz.EVENT_TYPE_HTTPRESPONSE)
				info.trigger = subject.callback
				local response = HTTPResponse(self.domoticz, subject)
				ok, res = pcall(eventHandler['execute'], self.domoticz, response, info)
			elseif (baseType == domoticz.BASETYPE_SYSTEM_EVENT) then
				info = getEventInfo(eventHandler, self.domoticz.EVENT_TYPE_DOMOTICZ)
				info.trigger = subject.type
				local dze = SystemEvent(self.domoticz, subject)
				ok, res = pcall(eventHandler['execute'], self.domoticz, dze, info)
			elseif (baseType == domoticz.BASETYPE_CUSTOM_EVENT) then
				info = getEventInfo(eventHandler, self.domoticz.EVENT_TYPE_CUSTOM)
				local custom = CustomEvent(self.domoticz, subject)
				ok, res = pcall(eventHandler['execute'], self.domoticz, custom, info)
				-- timer
				info = getEventInfo(eventHandler, self.domoticz.EVENT_TYPE_TIMER)
				local timer = Timer(self.domoticz, info.trigger)
				ok, res = pcall(eventHandler['execute'], self.domoticz, timer, info)
			if (ok) then
				-- Persist storage
				if (useStorage) then
					self.writeStorageContext(eventHandler.data,
						eventHandler.dataFilePath,
						eventHandler.dataFileName,
						self.domoticz.data)
					self.writeStorageContext(globalsDefinition,
						_G.dataFolderPath .. '/__data_global_data.lua',
						_G.dataFolderPath .. '/__data_global_data',
						self.domoticz.globalData)
				self.domoticz.data = nil
				self.domoticz.globalData = nil
				return res
				utils.log('An error occurred when calling event handler ' .. eventHandler.name, utils.LOG_ERROR)
				utils.log(res, utils.LOG_ERROR) -- error info
			utils.log('No "execute" function found in event handler ' .. eventHandler, utils.LOG_ERROR)
	function self.scandir(directory, type)
		local pos, len
		local i, t, popen = 0, {}, io.popen
		local sep = string.sub(package.config, 1, 1)
		local cmd
		local namesLookup = {}
		if (directory == nil) then
			return {}
		if (sep == '/') then
			cmd = 'ls -a "' .. directory .. '"'
			-- assume windows for now
			cmd = 'dir "' .. directory .. '" /B'
		t = {}
		local pfile = popen(cmd)
		for filename in pfile:lines() do
			pos, len = string.find(filename, '.lua', 1, true)
			if (pos and pos > 0 and filename:sub(1, 1) ~= '.' and len == string.len(filename)) then
				local name = string.sub(filename, 1, pos - 1)
				table.insert(t, {
					['type'] = type,
					['name'] = name
				namesLookup[name] = true -- for quick lookup for filename
				--utils.log('Found module in ' .. directory .. ' folder: ' .. t[#t].name, utils.LOG_DEBUG)
		pfile:close()
		return t, namesLookup
	function self.processTimeRuleFunction(fn)
		local ok, res = pcall(fn, self.domoticz)
		if (not ok) then
			utils.log('Error executing custom timer function.', utils.LOG_ERROR)
				print(res)
			return false
		return res
	function self.handleEvents(events, subject)
		local originalLogLevel = _G.logLevel -- a script can override the level
		local function restoreLogging()
			_G.logLevel = originalLogLevel
			_G.logMarker = nil
		if (type(events) ~= 'table') then
			restoreLogging()
			return
		for eventIdx, eventHandler in pairs(events) do
			if (eventHandler.logging) then
				if type(eventHandler.logging) ~= 'table' then
					if type(eventHandler.logging) == 'number' then
						local level = eventHandler.logging
						eventHandler.logging = {}
						eventHandler.logging.level = level
					utils.log(eventHandler.type .. ' script ' .. eventHandler.name .. '.lua has a malformed logging section. Check the documentation.', utils.LOG_FORCE)
				if (eventHandler.logging.level ~= nil) then
					_G.logLevel = eventHandler.logging.level
				if (eventHandler.logging.marker ~= nil) then
					_G.logMarker = eventHandler.logging.marker
			local moduleLabel
			local moduleLabelInfo = ''
			local triggerInfo
			local scriptType = eventHandler.type == 'external' and 'external script: ' or 'internal script: '
			if (eventHandler.type == 'external') then
				moduleLabel = eventHandler.name .. '.lua'
				moduleLabel = eventHandler.name .. ''
			domoticz.moduleLabel = eventHandler.name:gsub('%.lua','') -- used in dynamic logmarker
				moduleLabelInfo = ' Device: "' .. subject.name .. ' (' .. subject.hardwareName .. ')", Index: ' .. tostring(subject.id)
				moduleLabelInfo = ' Variable: "' .. subject.name .. '" Index: ' .. tostring(subject.id)
				moduleLabelInfo = ' Security: "' .. subject.name .. '"'
				moduleLabelInfo = (subject.baseType == 'scene' and ' Scene' or ' Group') .. ': "' .. subject.name .. '", Index: ' .. tostring(subject.id)
				moduleLabelInfo = ' HTTPResponse: "' .. subject.callback .. '"'
				moduleLabelInfo = ' Domoticz event: "' .. subject.name .. '"'
				moduleLabelInfo = ' Custom event: "' .. subject.name .. '"'
			triggerInfo = eventHandler.trigger and ( ', trigger: "' .. eventHandler.trigger .. '"' ) or ''
			local clockTimeStampAtStart = os.clock()
			local timeStampAtStart = os.time()
			utils.log('------ Start ' .. scriptType .. moduleLabel ..':' .. moduleLabelInfo .. triggerInfo, utils.LOG_MODULE_EXEC_INFO)
			local clockTimeSpend = os.clock() - clockTimeStampAtStart
			local realTimeSpend = os.time() - timeStampAtStart
			if realTimeSpend > 9 or clockTimeSpend > 7 then
				utils.log('------ Finished ' .. moduleLabel .. ' after >' .. realTimeSpend .. ' seconds. (using '.. tostring(clockTimeSpend):sub(1,5) .. ' seconds CPU time !)' , utils.LOG_ERROR)
			elseif realTimeSpend > 6 or clockTimeSpend > 5 then
				utils.log('------ Finished ' .. moduleLabel .. ' after >' .. realTimeSpend .. ' seconds. (using '.. tostring(clockTimeSpend):sub(1,5) .. ' seconds CPU time !)' , utils.LOG_FORCE)
				utils.log('------ Finished ' .. moduleLabel , utils.LOG_MODULE_EXEC_INFO)
			if (tonumber(globalvariables['dzVents_log_level']) == utils.LOG_DEBUG or TESTMODE ) then
				local moduleSummary = globalvariables.script_path  .. 'module.log'
				utils.log('Debug: Writing module summary to ' .. moduleSummary ,utils.LOG_FORCE)
				local f = io.open(moduleSummary, 'a' )
				f:write(
					os.date('%x %X - ',timeStampAtStart) .. os.date('%x %X ') .. '(' ..
					string.format('%02d', realTimeSpend) .. ' - ' .. string.format('%.4f',clockTimeSpend) ..
					') ' .. string.format('%35s',moduleLabel) .. ' <<' .. moduleLabelInfo ..
					( eventHandler.trigger and ( ' timer: "' .. eventHandler.trigger .. '"' ) or '') ,'\n')
				f:close()
			restoreLogging()
	function self.processTimeRules(timeRules, testTime)
		-- accepts a table of timeDefs, if one of them matches with the
		-- current time, then it returns true
		-- otherwise it returns false
		local now
		if (testTime == nil) then
			now = self.domoticz.time
			now = testTime
		for i, _rule in pairs(timeRules) do
			if (type(_rule) == 'function') then
				return self.processTimeRuleFunction(_rule), 'function'
			local rule = string.lower(_rule)
			if (now.matchesRule(rule)) then
				return true, _rule
		return false
	function self.checkSecurity(securityDefs, security)
		for i, def in pairs(securityDefs) do
			if (def == security) then
				return true, def
		return false
	local function addBindingEvent(bindings, event, module)
		if (bindings[event] == nil) then
			bindings[event] = {}
		table.insert(bindings[event], module)
	local function loadEventScripts()
		local scripts = {}
		local errModules = {}
		local internalScripts
		local ok, diskScripts, externalNames, moduleName, i, event, j, err
		local modules = {}
		local scripts = {}
		ok, diskScripts, externalNames = pcall(self.scandir, _G.scriptsFolderPath, 'external')
		if (not ok) then
			utils.log(diskScripts, utils.LOG_ERROR)
			modules = diskScripts
		ok = true
		ok, internalScripts = pcall(self.scandir, _G.generatedScriptsFolderPath, 'internal')
		if (not ok) then
			utils.log(internalScripts, utils.LOG_ERROR)
			for i, internal in pairs(internalScripts) do
				if (externalNames[internal.name]) then
					-- oops already there, skipping
					utils.log('There is already an external script with the name "' .. internal.name .. '.lua". Please rename in the internal script.', utils.LOG_ERROR)
					table.insert(modules, internal)
		-- extract global_data module and make sure it is the first in the list
		-- because then peeps can create some globals available everywhere before the other modules load
		local globalIx
		for i, moduleInfo in pairs(modules) do
			if (moduleInfo.name == GLOBAL_DATA_MODULE) then
				globalIx = i
				break
		if (globalIx ~= nil and globalIx > 1) then
			local globalModule = modules[globalIx]
			table.remove(modules, globalIx)
			table.insert(modules, 1, globalModule)
		for i, moduleInfo in ipairs(modules) do
			local module, skip
			local moduleName = moduleInfo.name
			local logScript = (moduleInfo.type == 'external' and 'Script ' or 'Internal script ')
			_G.domoticz = {
				['LOG_INFO'] = utils.LOG_INFO,
				['LOG_MODULE_EXEC_INFO'] = utils.LOG_MODULE_EXEC_INFO,
				['LOG_DEBUG'] = utils.LOG_DEBUG,
				['LOG_ERROR'] = utils.LOG_ERROR,
				['SECURITY_DISARMED'] = self.domoticz.SECURITY_DISARMED,
				['SECURITY_ARMEDAWAY'] = self.domoticz.SECURITY_ARMEDAWAY,
				['SECURITY_ARMEDHOME'] = self.domoticz.SECURITY_ARMEDHOME,
			ok = true
			ok, module = pcall(require, moduleName)
			_G.domoticz = nil
			if (ok) then
				if (moduleName == GLOBAL_DATA_MODULE) then
					if (module.data ~= nil) then
						globalsDefinition = module.data
							self.globalsDefinition = globalsDefinition
					if (module.helpers ~= nil) then
						self.domoticz.helpers = module.helpers
					if (type(module) == 'table') then
						skip = false
						if (module.active ~= nil) then
							local active = false
							if (type(module.active) == 'function') then
								active = module.active(self.domoticz)
							if (not active) then
								skip = true
						if (not skip) then
							if (module.on ~= nil and module['execute'] ~= nil) then
								module.name = moduleName
								module.type = moduleInfo.type
								module.dataFileName = '__data_' .. moduleName
								module.dataFilePath = _G.dataFolderPath .. '/__data_' .. moduleName .. '.lua'
								table.insert(scripts, module)
								utils.log(logScript .. moduleName .. '.lua has no "on" and/or "execute" section, not a dzVents module. Skipping', utils.LOG_DEBUG)
								--table.insert(errModules, moduleName)
						utils.log(logScript .. moduleName .. '.lua is not a dzVents module. Skipping', utils.LOG_DEBUG)
				utils.log(module, utils.LOG_ERROR)
		return scripts, errModules
	function self.getEventBindings(mode, testTime)
		local bindings = {}
		local ok, i, event, j, device, err
		local modules = {}
		if not self.scripts then
			self.scripts, self.errModules = loadEventScripts()
		if (mode == nil) then mode = 'device' end
		for i, module in pairs(self.scripts) do
			local logScript = (module.type == 'external' and 'Script ' or 'Internal script ')
			for j, event in pairs(module.on) do
				if type(j) ~= 'string' or type(event) ~= 'table' or validEventTypes:find(j) == nil then
					if not self.scripts[i].invalidOnSection then
						self.scripts[i].invalidOnSection = true
						if type(j) == "string" and validEventTypes:find(j) == nil then
							if inValidEventTypes:find(j) then
								utils.log('You entered "' .. tostring(j) .. '" in the on = section. Probably you misplaced your curly brackets', utils.LOG_FORCE)
								utils.log('Valid eventTypes are: ' .. validEventTypes, utils.LOG_DEBUG )
								utils.log('You entered "' .. tostring(j) .. '" in the on = section. Maybe you meant "' .. utils.fuzzyLookup(j, utils.stringSplit(validEventTypes,',')) ..'"?', utils.LOG_FORCE)
							utils.log('You entered "' .. utils.toStr(event) .. '" as trigger but the eventType is not (properly) set')
						utils.log(logScript .. module.name .. '.lua has an invalid on = section;  please check the wiki. Skipping it until fixed.', utils.LOG_ERROR)
					if (mode == 'timer' and j == 'timer') then
						-- { ['timer'] = { 'every minute ', 'every hour' } }
						if type(event) ~= 'table' then
							utils.log(logScript .. module.name .. '.lua has a malformed timer = section. Check the documentation.', utils.LOG_FORCE)
							event = { event }
						local triggered, def = self.processTimeRules(event)
						if (triggered) then
							-- this one can be executed
							module.trigger = def
							event.type = 'timer'
							table.insert(bindings, module)
					elseif (mode == 'device' and j == 'devices') then
						-- { ['devices'] = { 'devA', ['devB'] = { ..timedefs }, .. }
						for devIdx, devName in pairs(event) do
							-- detect if devName is of the form ['devB'] = { 'every hour' }
							if (type(devName) == 'table') then
								local triggered, def = self.processTimeRules(devName, testTime)
								if (triggered) then
									addBindingEvent(bindings, devIdx, module)
								-- a single device name (or id)
								addBindingEvent(bindings, devName, module)
					elseif (mode == 'scenegroups' and (j == 'scenes' or j == 'groups')) then
						-- { ['scenes'] = { 'scA', ['scB'] = { ..timedefs }, .. }
						for scgrpIdx, scgrpName in pairs(event) do
							-- detect if scgrpName is of the form ['devB'] = { 'every hour' }
							if (type(scgrpName) == 'table') then
								local triggered, def = self.processTimeRules(scgrpName, testTime)
								if (triggered) then
									addBindingEvent(bindings, scgrpIdx, module)
								-- a single scene or group name (or id)
								addBindingEvent(bindings, scgrpName, module)
					elseif (mode == 'variable' and j == 'variables') then
						-- { ['variables'] = { 'varA', 'varB' }
						for varIdx, varName in pairs(event) do
							addBindingEvent(bindings, varName, module)
					elseif (mode == 'security' and j == 'security') then
						local triggered, def = self.checkSecurity(event, self.domoticz.security)
						if (triggered) then
					elseif (mode == 'httpResponse' and j == 'httpResponses') then
						-- { ['httpResponses'] = { 'callbackA', 'callbackB' }
						for i, callbackName in pairs(event) do
							addBindingEvent(bindings, callbackName, module)
					elseif (mode == 'system' and j == 'system') then
						-- { ['system'] = { 'start', 'end' }
						for evtIdx, systemEvent in pairs(event) do
							-- detect if system is of the form ['start'] = { 'every hour' }
							if (type(systemEvent) == 'table') then
								local triggered, def = self.processTimeRules(systemEvent, testTime)
								if (triggered) then
									addBindingEvent(bindings, evtIdx, module)
								-- a single system event
								addBindingEvent(bindings, systemEvent, module)
					elseif (mode == 'customEvents' and j == 'customEvents') then
						-- { customEvents = { 'myEvent', ['anotherEvent'] = { ... timeDefs ... } }
						for evtIdx, customEventName in pairs(event) do
							-- detect if customEvent is of the form ['myEvent'] = { 'every hour' }
							if (type(customEventName) == 'table') then
								local triggered, def = self.processTimeRules(customEventName, testTime)
								if (triggered) then
								-- a single custom event
								addBindingEvent(bindings, customEventName, module)
		return bindings, self.errModules
	function self.dumpCommandArray(commandArray, fromIndex, force)
		local printed = false
		local level = utils.LOG_DEBUG
		if (fromIndex == nil) then
			fromIndex = 1
		if (force == true and force ~= nil or globalvariables['testmode'] == true) then
			level = utils.LOG_INFO
		for k, v in pairs(commandArray) do
			if ((fromIndex ~= nil and k >= fromIndex) or fromIndex == nil) then
				if (not printed) then
					utils.log('Commands sent to Domoticz: ', level)
				if (type(v) == 'table') then
					for kk, vv in pairs(v) do
						utils.log('- ' .. kk .. ' = ' .. _.str(vv), level)
					utils.log(k .. ' = ' .. v, level)
				printed = true
		if (printed) then utils.log('=====================================================', level) end
	function self.findScriptForTarget(target, allEventScripts)
		-- event could be like: myPIRLivingRoom
		-- or myPir(.*)
			allEventScripts is a dictionary where
			each key is the name or id of a device and the value
			is a table with all the modules for this device
				['myDevice'] = {
					modA, modB, modC
				['anotherDevice'] = {
					modD
				12 = {
					modE, modF
				['myDev*'] = {
					modG, modH
		local modules
		-- only search for named and wildcard triggers,
		-- id is done later
		for scriptTrigger, scripts in pairs(allEventScripts) do
			local function strFind(str, key)
				return string.find(str, key)
			local ok, res = pcall(strFind, scriptTrigger, '*');
			if not ok then
				utils.log('Script name: ' .. scripts[1].name  .. '.lua, has a malformed on = section. The trigger = ' .. _.str(scriptTrigger) , utils.LOG_ERROR)
				allEventScripts[scriptTrigger] = ''
			elseif res then -- a wild-card was used
				scriptTrigger = ('^' .. scriptTrigger:gsub("[%^$]","."):gsub("*", ".*") .. '$')
				local function sMatch(text, match) -- specialized sanitized match function to allow combination of Lua magic chars in wildcards
					local sanitizedMatch = match:gsub("([%%%(%)%[%]%+%-%?])", "%%%1") -- escaping all 'magic' chars except *, ., ^ and $
					return text:match(sanitizedMatch)
				if sMatch(target, scriptTrigger) then
					if modules == nil then modules = {} end
					for i, mod in pairs(scripts) do
						table.insert(modules, mod)
				if (scriptTrigger == target) then
					-- there is trigger for this target
		return modules
	function self.dispatchDeviceEventsToScripts(domoticz)
		if (domoticz == nil) then -- you can pass a domoticz object for testing purposes
			domoticz = self.domoticz
		local allEventScripts = self.getEventBindings()
		domoticz.changedDevices().forEach( function(device)
			local scriptsToExecute = self.findScriptForTarget(device.name, allEventScripts)
			local idScripts = allEventScripts[device.id]
			local caSize = _.size(self.domoticz.commandArray)
			if (idScripts ~= nil) then
				-- merge id scripts with name scripts
				if (scriptsToExecute == nil) then
					scriptsToExecute = {}
				for i, mod in pairs(idScripts) do
					table.insert(scriptsToExecute, mod)
			if (scriptsToExecute ~= nil) then
				utils.log('Handling events for: "' .. device.name .. '", value: "' .. tostring(device.state) .. '"', utils.LOG_MODULE_EXEC_INFO)
				self.handleEvents(scriptsToExecute, device)
				self.dumpCommandArray(self.domoticz.commandArray, caSize + 1)
		end)
		return self.domoticz.commandArray
	function self.dispatchSceneGroupEventsToScripts(domoticz)
		local allEventScripts = self.getEventBindings('scenegroups')
		local processItem = function(item, loglabel)
			utils.log(loglabel .. '-event for: ' .. item.name .. ' value: ' .. tostring(item.state), utils.LOG_DEBUG)
			local scriptsToExecute = self.findScriptForTarget(item.name, allEventScripts)
			local idScripts = allEventScripts[item.id]
				utils.log('Handling events for: "' .. item.name .. '", value: "' .. tostring(item.state) .. '"', utils.LOG_MODULE_EXEC_INFO)
				self.handleEvents(scriptsToExecute, item)
		domoticz.changedScenes().forEach(function(scene)
			processItem(scene, 'Scene')
		end)
		domoticz.changedGroups().forEach(function(group)
			processItem(group, 'Group')
		end)
	function self.dispatchTimerEventsToScripts()
		local scriptsToExecute = self.getEventBindings('timer')
		self.handleEvents(scriptsToExecute)
		self.dumpCommandArray(self.domoticz.commandArray)
	function self.dispatchSecurityEventsToScripts()
		local updates =_G.securityupdates
		if (updates ~= nil) then
			for i, securityState in pairs(updates) do
				local security = {
					baseType = domoticz.BASETYPE_SECURITY,
					name = securityState
				self.domoticz.security = securityState
				local scriptsToExecute = self.getEventBindings('security', nil)
				self.handleEvents(scriptsToExecute, security)
	function self.dispatchVariableEventsToScripts(domoticz)
		local allEventScripts = self.getEventBindings('variable')
		domoticz.changedVariables().forEach(function(variable)
			-- first search by name
			local scriptsToExecute = self.findScriptForTarget(variable.name, allEventScripts)
				-- search by id
				scriptsToExecute = allEventScripts[variable.id]
				utils.log('Handling variable-events for: "' .. variable.name .. '", value: "' .. tostring(variable.value) .. '"', utils.LOG_MODULE_EXEC_INFO)
				self.handleEvents(scriptsToExecute, variable)
		end)
	function self.dispatchHTTPResponseEventsToScripts(domoticz)
		local httpResponseScripts = self.getEventBindings('httpResponse')
		local responses =_G.httpresponse
		if (responses ~= nil) then
			for i, response in pairs(responses) do
				response.baseType = domoticz.BASETYPE_HTTP_RESPONSE
				local callback = response.callback
				local scriptsToExecute = self.findScriptForTarget(callback, httpResponseScripts)
					utils.log('Handling httpResponse-events for: "' .. callback .. '"', utils.LOG_MODULE_EXEC_INFO)
					self.handleEvents(scriptsToExecute, response)
	function self.dispatchSystemEventsToScripts(domoticz)
		if (_G.notification == nil) then
			return
		local systemEventScripts = self.getEventBindings('system', nil)
		local systemEvents =_G.notification.domoticz
		if (systemEvents ~= nil) then
			for i, event in pairs(systemEvents) do
				event.name = SystemEvent(self.domoticz, event)["type"]
				if event.name == nil then
					utils.log('System event "' .. event.type .. '" is not supported yet.', utils.LOG_ERROR)
					event.baseType = domoticz.BASETYPE_SYSTEM_EVENT
					local scriptsToExecute = self.findScriptForTarget(event.name, systemEventScripts)
						utils.log('Handling system event for: "' .. event.name .. '"', utils.LOG_MODULE_EXEC_INFO)
						self.handleEvents(scriptsToExecute, event)
	function self.dispatchCustomEventsToScripts(domoticz)
		if (_G.notification == nil or _G.notification.customevent == nil ) then
			return
		for _, row in ipairs(_G.notification.customevent) do
			 if row.data.name:match('^___%a*__$') then
				table.insert(self.domoticz.commandArray, { [ row.data.name:sub(4,-3) ] = row.data.data })
		local customEventScripts = self.getEventBindings('customEvents', nil)
		local customEvents = _G.notification.customevent
		if (customEvents ~= nil) then
			for i, customEvent in pairs(customEvents) do
				customEvent.name = customEvent.data.name
				customEvent.baseType = domoticz.BASETYPE_CUSTOM_EVENT
				local scriptsToExecute = self.findScriptForTarget(customEvent.name, customEventScripts)
					utils.log('Handling Domoticz custom event for: "' .. customEvent.name .. '"', utils.LOG_MODULE_EXEC_INFO)
					self.handleEvents(scriptsToExecute, customEvent)
	function self.getEventSummary(domoticz)
		local items = {}
		local length = 0
			table.insert(items, '- Device: ' .. device.name)
			length = length + 1
		end)
			table.insert(items, '- Variable: ' .. variable.name)
			length = length + 1
		end)
		local securityUpdates =_G.securityupdates
		if (securityUpdates ~= nil) then
			for i, securityState in pairs(securityUpdates) do
				table.insert(items, '- Security: ' .. securityState)
				length = length + 1
			table.insert(items, '- Scene: ' .. scene.name)
			length = length + 1
		end)
			table.insert(items, '- Group: ' .. group.name)
			length = length + 1
		end)
				table.insert(items, '- HTTPResponse: ' .. response.callback)
				length = length + 1
		local domoticzEvents = _G.notification and _G.notification.domoticz or nil
		if (domoticzEvents ~= nil) then
			for i, domoticzEvent in pairs(domoticzEvents) do
				table.insert(items, '- Domoticz: ' .. domoticzEvent.type) -- .. ' - ' .. domoticzEvent.status)
				length = length + 1
		local customEvents = _G.notification and _G.notification.customEvents or nil
				table.insert(items, '- Custom: ' .. customEvent.type) -- .. ' - ' .. customEvent.status)
				length = length + 1
		return items, length;
	return self
return EventHelpers
Re: dzVents errors
Posted: Sunday 29 November 2020 11:28
by roblom
The update runs normal but it installs version 12705. Just checked and it still says that there is no update available.
So I changed the EventHelpers.lua file. But now what? I still see the same errors in the log, do I need to look somewhere else or do I have to look for something specific?
Re: dzVents errors
Posted: Sunday 29 November 2020 12:03
by waaren
roblom wrote: Sunday 29 November 2020 11:28 So I changed the EventHelpers.lua file. But now what? I still see the same errors in the log, do I need to look somewhere else or do I have to look for something specific?
If you have Debug on for dzVents you now should see a file <domoticz dir>/dzVents/scripts/module.log
sudo tail -f <domoticz dir>/dzVents/scripts/module.log should show you lines like
11/29/20 11:54:02 - 11/29/20 11:54:02 (00 - 0.0129)                        PVOutput.lua << timer: "every 6 minutes"
11/29/20 11:54:02 - 11/29/20 11:54:02 (00 - 0.0237)                         splitP1.lua << timer: "every 1 minutes"
11/29/20 11:54:03 - 11/29/20 11:54:03 (00 - 0.0505)                  getEnergyCosts.lua << HTTPResponse: "dailyEnergyCost_energy"
11/29/20 11:54:04 - 11/29/20 11:54:04 (00 - 0.0038)                        PVOutput.lua << HTTPResponse: "PVOutput"
11/29/20 11:55:00 - 11/29/20 11:55:00 (00 - 0.0671)               Bathroom humidity.lua << timer: "every minute between 05:15 and 23:30"
11/29/20 11:55:00 - 11/29/20 11:55:01 (01 - 0.0131)                      splitDaily.lua << timer: "every 5 minutes"
between () you see clocktime in seconds - CPU time in seconds)
Maybe this will give you more information on your issue.
Re: dzVents errors
Posted: Sunday 29 November 2020 12:50
by roblom
Don't see anything strange
11/29/20 12:32:10 - 11/29/20 12:32:11 (01 - 0.3582)                     consumption.lua << Device: "Energie (P1) (P1-poort)", Index: 175
11/29/20 12:32:16 - 11/29/20 12:32:18 (02 - 0.4877)                     consumption.lua << Device: "Energie (P1) (P1-poort)", Index: 175
11/29/20 12:32:23 - 11/29/20 12:32:25 (02 - 0.3597)                     consumption.lua << Device: "Energie (P1) (P1-poort)", Index: 175
11/29/20 12:32:35 - 11/29/20 12:32:36 (01 - 0.3578)                     consumption.lua << Device: "Energie (P1) (P1-poort)", Index: 175
11/29/20 12:32:43 - 11/29/20 12:32:45 (02 - 0.3946)                     consumption.lua << Device: "Energie (P1) (P1-poort)", Index: 175
11/29/20 12:32:57 - 11/29/20 12:32:58 (01 - 0.3883)                     consumption.lua << Device: "Energie (P1) (P1-poort)", Index: 175
11/29/20 12:33:03 - 11/29/20 12:33:04 (01 - 0.3678)                     consumption.lua << Device: "Energie (P1) (P1-poort)", Index: 175
11/29/20 12:33:16 - 11/29/20 12:33:17 (01 - 0.4505)                     consumption.lua << Device: "Energie (P1) (P1-poort)", Index: 175
11/29/20 12:33:23 - 11/29/20 12:33:24 (01 - 0.3717)                     consumption.lua << Device: "Energie (P1) (P1-poort)", Index: 175
11/29/20 12:33:35 - 11/29/20 12:33:37 (02 - 0.4186)                     consumption.lua << Device: "Energie (P1) (P1-poort)", Index: 175
11/29/20 12:33:42 - 11/29/20 12:33:43 (01 - 0.3773)                     consumption.lua << Device: "Energie (P1) (P1-poort)", Index: 175
11/29/20 12:33:54 - 11/29/20 12:33:56 (02 - 0.3425)                     consumption.lua << Device: "Energie (P1) (P1-poort)", Index: 175
11/29/20 12:34:02 - 11/29/20 12:34:03 (01 - 0.3821)                     consumption.lua << Device: "Energie (P1) (P1-poort)", Index: 175
11/29/20 12:34:14 - 11/29/20 12:34:16 (02 - 0.3911)                     consumption.lua << Device: "Energie (P1) (P1-poort)", Index: 175
11/29/20 12:34:28 - 11/29/20 12:34:29 (01 - 0.4024)                     consumption.lua << Device: "Energie (P1) (P1-poort)", Index: 175
11/29/20 12:34:40 - 11/29/20 12:34:41 (01 - 0.3648)                     consumption.lua << Device: "Energie (P1) (P1-poort)", Index: 175
11/29/20 12:34:46 - 11/29/20 12:34:47 (01 - 0.4038)                     consumption.lua << Device: "Energie (P1) (P1-poort)", Index: 175
11/29/20 12:34:54 - 11/29/20 12:34:55 (01 - 0.3683)                     consumption.lua << Device: "Energie (P1) (P1-poort)", Index: 175
11/29/20 12:35:12 - 11/29/20 12:35:12 (00 - 0.0868)                          blinds.lua << timer: "every 5 minutes"
11/29/20 12:35:12 - 11/29/20 12:35:15 (03 - 0.8917)                     consumption.lua << Device: "Energie (P1) (P1-poort)", Index: 175
11/29/20 12:35:20 - 11/29/20 12:35:22 (02 - 0.4792)                     consumption.lua << Device: "Energie (P1) (P1-poort)", Index: 175
11/29/20 12:35:28 - 11/29/20 12:35:30 (02 - 0.4508)                     consumption.lua << Device: "Energie (P1) (P1-poort)", Index: 175
11/29/20 12:35:30 - 11/29/20 12:35:30 (00 - 0.0726)                          blinds.lua << HTTPResponse: "AM43-Blinds_Response"
11/29/20 12:35:36 - 11/29/20 12:35:37 (01 - 0.4677)                     consumption.lua << Device: "Energie (P1) (P1-poort)", Index: 175
While the log of Domoticz shows
2020-11-29 12:29:53.382 Error: EventSystem: Warning!, lua script /home/pi/domoticz/dzVents/runtime/dzVents.lua has been running for more than 10 seconds
2020-11-29 12:30:05.560 Error: EventSystem: Warning!, lua script /home/pi/domoticz/dzVents/runtime/dzVents.lua has been running for more than 10 seconds
2020-11-29 12:30:23.294 Error: EventSystem: Warning!, lua script /home/pi/domoticz/dzVents/runtime/dzVents.lua has been running for more than 10 seconds
2020-11-29 12:30:36.331 Error: EventSystem: Warning!, lua script /home/pi/domoticz/dzVents/runtime/dzVents.lua has been running for more than 10 seconds
2020-11-29 12:30:48.827 Error: EventSystem: Warning!, lua script /home/pi/domoticz/dzVents/runtime/dzVents.lua has been running for more than 10 seconds
2020-11-29 12:31:00.565 Error: EventSystem: Warning!, lua script /home/pi/domoticz/dzVents/runtime/dzVents.lua has been running for more than 10 seconds
2020-11-29 12:35:12.368 Error: EventSystem: Warning!, lua script /home/pi/domoticz/dzVents/runtime/dzVents.lua has been running for more than 10 seconds
2020-11-29 12:38:27.314 Error: EventSystem: Warning!, lua script /home/pi/domoticz/dzVents/runtime/dzVents.lua has been running for more than 10 seconds
2020-11-29 12:38:41.116 Error: EventSystem: Warning!, lua script /home/pi/domoticz/dzVents/runtime/dzVents.lua has been running for more than 10 seconds
2020-11-29 12:38:55.260 Error: EventSystem: Warning!, lua script /home/pi/domoticz/dzVents/runtime/dzVents.lua has been running for more than 10 seconds
2020-11-29 12:38:57.131 Error: SMTP Mailer: Error sending Email to: <[email protected]> !
2020-11-29 12:38:57.131 Error: libcurl: (28)
2020-11-29 12:38:57.131 Error: SSL connection timeout
2020-11-29 12:38:57.132 Error: Failed to send Email notification!
2020-11-29 12:38:57.379 Error: FCM: Could not send message, HTTP Error
2020-11-29 12:38:58.808 Error: Pushover: Could not send message!
2020-11-29 12:39:07.607 Error: EventSystem: Warning!, lua script /home/pi/domoticz/dzVents/runtime/dzVents.lua has been running for more than 10 seconds
2020-11-29 12:39:23.316 Error: dzVents: Error: (3.0.17) Consumption: ------ Finished consumption.lua after >10 seconds. (using 1.967 seconds CPU time !)
2020-11-29 12:39:23.605 Error: EventSystem: Warning!, lua script /home/pi/domoticz/dzVents/runtime/dzVents.lua has been running for more than 10 seconds
2020-11-29 12:39:36.298 Error: EventSystem: Warning!, lua script /home/pi/domoticz/dzVents/runtime/dzVents.lua has been running for more than 10 seconds
2020-11-29 12:39:56.567 Error: EventSystem: Warning!, lua script /home/pi/domoticz/dzVents/runtime/dzVents.lua has been running for more than 10 seconds
2020-11-29 12:40:13.964 Error: EventSystem: Warning!, lua script /home/pi/domoticz/dzVents/runtime/dzVents.lua has been running for more than 10 seconds
I think at this moment it's easier to do a complete reinstall, or do you want to learn from this and need some more info?
Re: dzVents errors
Posted: Sunday 29 November 2020 13:02
by waaren
roblom wrote: Sunday 29 November 2020 12:50 Don't see anything strange
What I consider strange is that your consumption script takes a relatively long time and that your system seems to be very slow. Cannot tell if this is because of CPU / Memory or IO but the values you show here are not what I see on any of my systems.
Can you share the consumption.lua script and your hardware details? (CPU, memory, storage, LAN)
Re: dzVents errors
Posted: Sunday 29 November 2020 17:03
by roblom
Since 21 November the CPU is really high, average is about 92%.
When I use "top" it shows Domoticz is taking up 90%.
I use a Raspberry 3B, storage is 16Gb SanDisk sd-card which is 17% in use. Maximum memory usage is also risen since the 21th.
Consumption script
	This script collects the values below from Domoticz
	  * The Power and energy values (import and export) from a smartmeter
	  * The Power and energy values from a Solar power inverter
	It then calculates the (average) consumed power and energy from the values above with the formula's
	  * EnergyConsumption = EnergyGeneration + EnergyImport - EnergyExport
	  * PowerConsumption = PowerGeneration + PowerImport - PowerExport
	The average power is calculated because it fluctuates much and can cause negative consumption due to timing issues.
	It then updates a virtual device which displays the consumed power and energy in Domoticz
	The base of this scrip comes from
	https://www.domoticz.com/forum/viewtopic.php?f=61&t=4714&p=251778#p251778
local smartMeterIDX = 175	-- IDX of Smart meter device
local solarPanelsIDX = 96	-- IDX of Solar Panels device
local consumptionIDX = 93	-- IDX of Own Usage / calculated value / dummy Elekta kWh + counter
	active = true,
	on =
		devices =
			-- Devices on which this calculation script should trigger.
			smartMeterIDX,
			solarPanelsIDX,
	logging =
		--level = domoticz.LOG_DEBUG,
		level = domoticz.LOG_ERROR,
		marker = 'Consumption',
	data =
		PowerImportHistory = { history = true, maxMinutes = 4 },
		PowerExportHistory = { history = true, maxMinutes = 4 },
		PowerGenerationHistory = { history = true, maxItems = 24 },
		execute = function(dz, item)
		-- Domoticz IDX of the needed devices
		local Smartmeter = dz.devices(smartMeterIDX)
		local Generation = dz.devices(solarPanelsIDX)
		local Consumption = dz.devices(consumptionIDX)
		-- Smartmeter
		-- Energy import and export
		local EnergyImportLow = Smartmeter.usage1
		dz.log('EnergyImportLow	 = ' .. EnergyImportLow/1000 .. ' kWh ', dz.LOG_DEBUG)
		local EnergyImportHigh = Smartmeter.usage2
		dz.log('EnergyImportHigh = ' .. EnergyImportHigh/1000 .. ' kWh ', dz.LOG_DEBUG)
		local EnergyExportLow = Smartmeter.return1
		dz.log('EnergyExportLow	 = ' .. EnergyExportLow/1000 .. ' kWh ', dz.LOG_DEBUG)
		local EnergyExportHigh = Smartmeter.return2
		dz.log('EnergyExportHigh = ' .. EnergyExportHigh/1000 .. ' kWh ', dz.LOG_DEBUG)
		local EnergyImport = EnergyImportLow + EnergyImportHigh
		local EnergyExport = EnergyExportLow + EnergyExportHigh
		-- Power import and export
		-- Add new data for calculating average
		if item == Smartmeter then
			dz.data.PowerImportHistory.add(Smartmeter.usage)
			dz.data.PowerExportHistory.add(Smartmeter.usageDelivered)
		-- Generation
		-- Energy generated
		local EnergyGeneration = Generation.WhTotal
		dz.log('EnergyGeneration = ' .. EnergyGeneration .. ' Wh ', dz.LOG_DEBUG)
		-- Power generated
		if item == Generation then
			dz.data.PowerGenerationHistory.add(Generation.actualWatt)
		-- Check historical storage entries
		if dz.data.PowerImportHistory.size < 3 or dz.data.PowerGenerationHistory.size < 3 then
			dz.log('Not enough data points yet to produce something useful', dz.LOG_DEBUG)
			dz.log('PowerImportHistory entries = ' .. dz.data.PowerImportHistory.size, dz.LOG_DEBUG)
			dz.log('PowerGeneration entries = ' .. dz.data.PowerGenerationHistory.size, dz.LOG_DEBUG)
			return
		-- Calculate
		-- Average power generated
		local PowerGeneration = dz.utils.round(dz.data.PowerGenerationHistory.avgSince('00:02:00'), 2)
		dz.log('PowerGeneration = ' .. PowerGeneration .. ' W ', dz.LOG_DEBUG)
		-- Average power imported and exported
		local PowerImport = dz.utils.round(dz.data.PowerImportHistory.avgSince('00:02:00'), 2)
		dz.log('PowerImport = ' .. PowerImport .. ' W ', dz.LOG_DEBUG)
		local PowerExport = dz.utils.round(dz.data.PowerExportHistory.avgSince('00:02:00'), 2)
		dz.log('PowerExport = ' .. PowerExport .. ' W ', dz.LOG_DEBUG)
		-- Power consumption
		local PowerConsumption = dz.utils.round(PowerGeneration + PowerImport - PowerExport, 0)
		dz.log('PowerConsumption = ' .. PowerConsumption .. ' W ', dz.LOG_DEBUG)
		-- Energy consumption
		local EnergyConsumption = dz.utils.round(EnergyGeneration + EnergyImport - EnergyExport, 0)
		dz.log('EnergyConsumption = ' .. EnergyConsumption/1000 .. ' kWh ', dz.LOG_DEBUG)
		-- Debug for negative power consumption
		if PowerConsumption < 0 then
		dz.log('(NEGATIVE) PowerConsumption = PowerGeneration + PowerImport - PowerExport', dz.LOG_ERROR)
			dz.log('' .. PowerConsumption .. ' W = ' .. PowerGeneration .. ' W + ' .. PowerImport .. ' W - ' .. PowerExport, dz.LOG_ERROR)
			dz.log('PowerConsumption = PowerGeneration + PowerImport - PowerExport', dz.LOG_INFO)
			dz.log('' .. PowerConsumption .. ' W = ' .. PowerGeneration .. ' W + ' .. PowerImport .. ' W - ' .. PowerExport, dz.LOG_INFO)
		-- Update device
		Consumption.updateElectricity(PowerConsumption, EnergyConsumption)
Re: dzVents errors
Posted: Sunday 29 November 2020 17:29
by roblom
When DzEvents is on and no scripts in the script folder, CPU is about 10-15%. As soon as I put one script in the DzEvents script folder the CPU usage raises to a 50-60%. Which script doesn't seems to make any difference.
