Easiest way to control multiple switches from one switch Topic is solved
Domoberry
Domoticz version: 2026.2
Post by Domoberry »
Hi Forum,
Typical use case this season: got a few smart plugs controlling some xmas lights and I want the timer in a one of the switches to control them all.
What is the most simple and/or practical way to achieve this?
Initially, I assumed 'slave/sub devices' would be the way to go, but as the Wiki already suggests ("one of the most difficult chapters" :D ) I cannot get my head around it for this purpose.
A Dzvents script triggered by a switch and sync the others accordingly seems straightforward.
Or, using a series of json commands with 'on action' / 'off action' to propagate from one switch to the other
or?
probably quite simple...
imautohuttraeger
Domoticz version: latest
Re: Easiest way to control multiple switches from one switch
Post by imautohuttraeger »
Make a scene, include all the devices you want to control and set the timer(s). That's all. Can be done in a few minutes. I do this with roller shutters and you can do it with smart plugs as well.
So this is not a sync of a "leading" smart plug. But you can interpret this scene as the (virtual) master plug ;-)
Stop, look and listen.
Domoberry
Post by Domoberry »
Hi Imautohuttraeger,
Thanks for the tip, just what I need and simple!!
My first group...
I did however opt for 'Group' rather than 'Scene' as a Group more closely resembles what I was looking for.
imautohuttraeger
Patricen
Domoticz version: Beta rel
Post by Patricen »
Did you succeed?
I'm trying to set-up a scene for Melcloud (Mitsubishi air conditioner) that is controlled with a set of switches (mode level switch for off/warm/cold/vent..., temp that is also a level switch, one level for each temperature and many other switches).
I just would like to make a scene or group that sets mode to warm and temperature to 20° but it does not look reliable, although manipulating the individual switches works correctly.
Finally I would like to setup a timer for this scene/group.
I'm using stable version 2020.2 and finally wondering about the fact there might be a bug, but it looks surprising to me.
imautohuttraeger
Seems as if your switches are not simple on/off switches. I guess if you want to control selector switches you need to make a script (under menu point "Events") that can handle different states of a particular switch.
Patricen
Post by Patricen »
Indeed, it looks like!
Weirdly the level is nevertheless implemented in the group définition.
I tried making a simple blocky logical control in place of the group but this idies not works better.
There might be an issue on the python plugin...
imautohuttraeger wrote: Wednesday 25 November 2020 13:10 Seems as if your switches are not simple on/off switches. I guess if you want to control selector switches you need to make a script.
Scenes and Groups are perfectly capable of setting a selector switches or dimmer switches to any available level. No need to script fot that purpose.
Patricen
Post by Patricen »
@Waaren, on multilevel grouped switches, there are fields for both on/off and level. Do you have more piece of information regarding this?
To my opinion, level 0% means off but what does on means?
Best,
Patrice
Patricen wrote: Wednesday 25 November 2020 17:30 @Waaren, on multilevel grouped switches, there are fields for both on/off and level. Do you have more piece of information regarding this?
Scene on
When configured as On + level > 0 -->> switches to the set level (is implicit On).
When configured as Off + any level -->> switches to level 0 and Off
When configured as On + level 0 -->> switches to level 0 and Off
Group On
When configured as level > 0 -->> switches to the set level (is implicit On).
When configured as level 0 --->> switches to level 0 (is implicit Off)
Group Off
When configured as level > 0 -->> switches to level 0 (is implicit Off).
When configured as level 0 --->> switches to level 0 (is implicit Off) // Yes no change but can trigger a subsequent event.
jefft
Domoticz version: 2023.1
Post by jefft »
How about using the first switch as the activation device in a scene with the others?
Domoticz, Z-Stick Gen.5, zzh Zigbee, rxftrx433XL on Ubuntu 22.04, HP 290 G1.
Node Red, MQTT, 80+ Z-wave, ESP8266 & Shelly, handful of Zigbee bulbs. EMS-ESP gateway for Bosch boiler. Controlicz, until it dies :-(
jeroenkl
Post by jeroenkl »
only missing the option to change the scene/group icons
imautohuttraeger
waaren wrote: Wednesday 25 November 2020 16:48
Oh - I haven't known this, thanks. Seems to be quite interesting - I will busy myself with it now.
