deConz node not connecting to controller
Plantje
Post by Plantje »
Not sure where else to put this...
I have a Trädfri motion sensor that was working fine with Conbee, deConz and Domoticz. Today all of a sudden the node is not connected to the controller in deConz on my host.
How can I reconnect a node like this?
Thorgal789
Re: deConz node not connecting to controller
Post by Thorgal789 »
Only this one ?
Strange, ikea device don't leave the network ..., no battery problem ?
It have stopped working too ?
To reconnect it, just go in phoscon, take "add new sensor" / "ikea" and you will see the procedure for the motion detection device.
You will not loose your setting in domoticz.
Plantje
Post by Plantje »
Ok, Will do. Thanks!
Plantje
Post by Plantje »
Was a battery issue. Adding it as a new one automatically deleted the old one in Phoscon. And in Domoticz everything is up and running as well.
Thanks again for your support!
Thorgal789
Yep, if you haven't issue on a previous entry, never delete the old one.
- There is some issue but the new one can take exactly the same name than the previous one.
- The new one overwrite the previous one. You can have only 1 device with the same Mac adress.
- It can help for integration, some information can be re-used (like for tuya stuff)
- On domoticz side, the plugin use only the mac address, so in case of problem , just restart the plugin and it will find again all your device integrated in domoticz even with different name or ID in deconz (all will be invisible)
