Zigbee2mqtt and WW lamps / colour temperature
Posted: Saturday 21 November 2020 15:39
Hi All,
I just added a couple of Innr tunable white zigbee bulbs to my test system to try them out. Zigbee2mqtt supports the bulb (RB278T) and it pairs okay, but in the domoticz UI, it shows up as a simple dimmer with no colour temperature control.
Checking the database, I see that the Type and SubType values are wrong - a RGBWW dimmer would be 241, 4 but zigbee2mqtt has created this device with 244, 73. As it's a test system, I thought I'd try changing those; sadly, that didn't work. If I send messages to the mqtt broker with a "color_temp" value, that works find. So, it seems that the problem is in how domoticz-zigbee2mqtt-plugin creates the device in domoticz and handles commands from domoticz.
Has anyone had / solved the same issue with Hue, Innr or similar bulbs and zigbee2mqtt? Or any ideas how to fix it?
