Error log - Smart Virtual Thermostat
Posted: Thursday 19 November 2020 13:43
I am using SVT for controlling heating in 9 different zones (rooms) since yesterday, before I tested only 4 zones. Since I added another 5 zones i started to get this in the Domoticz Error log:
2020-11-19 13:15:17.494 Error: (Värme Hall/Badrum) Domoticz API returned an error: status = ERROR
2020-11-19 13:20:12.250 Error: (Värme Förstuga) Domoticz API returned an error: status = ERROR
2020-11-19 13:20:14.547 Error: (Värme Sov SÖ) Domoticz API returned an error: status = ERROR
2020-11-19 13:29:15.733 Error: (Värme Förstuga) Domoticz API returned an error: status = ERROR
So I turned on "Debug-All" in SVT settings for zone "Värme Förstuga", giving the following output:
2020-11-19 13:29:05.186 (Värme Förstuga) 'StartupFolder':'C:\Program Files (x86)\Domoticz\'
2020-11-19 13:29:05.186 (Värme Förstuga) 'UserDataFolder':'C:\Program Files (x86)\Domoticz\'
2020-11-19 13:29:05.186 (Värme Förstuga) 'Database':'C:\Program Files (x86)\Domoticz\domoticz.db'
2020-11-19 13:29:05.186 (Värme Förstuga) 'Language':'sv'
2020-11-19 13:29:05.186 (Värme Förstuga) 'Version':'0.4.9'
2020-11-19 13:29:05.186 (Värme Förstuga) 'Author':'logread'
2020-11-19 13:29:05.186 (Värme Förstuga) 'Name':'Värme Förstuga'
2020-11-19 13:29:05.186 (Värme Förstuga) 'Address':'127.0.0.1'
2020-11-19 13:29:05.186 (Värme Förstuga) 'Port':'8080'
2020-11-19 13:29:05.186 (Värme Förstuga) 'Key':'SVT'
2020-11-19 13:29:05.186 (Värme Förstuga) 'Mode1':'204'
2020-11-19 13:29:05.186 (Värme Förstuga) 'Mode2':'2066'
2020-11-19 13:29:05.186 (Värme Förstuga) 'Mode3':'19'
2020-11-19 13:29:05.186 (Värme Förstuga) 'Mode4':'Forced'
2020-11-19 13:29:05.186 (Värme Förstuga) 'Mode5':'30,0,2,1,60'
2020-11-19 13:29:05.186 (Värme Förstuga) 'Mode6':'-1'
2020-11-19 13:29:05.186 (Värme Förstuga) 'DomoticzVersion':'2020.2 (build 12668)'
2020-11-19 13:29:05.186 (Värme Förstuga) 'DomoticzBuildTime':'2020-11-16 13:47:11'
2020-11-19 13:29:05.186 (Värme Förstuga) Device count: 6
2020-11-19 13:29:05.186 (Värme Förstuga) Device: 1 - ID: 2215, Name: 'Värme Förstuga - Thermostat Control', nValue: 1, sValue: '10'
2020-11-19 13:29:05.186 (Värme Förstuga) Device ID: '2215'
2020-11-19 13:29:05.186 (Värme Förstuga) Device Name: 'Värme Förstuga - Thermostat Control'
2020-11-19 13:29:05.186 (Värme Förstuga) Device nValue: 1
2020-11-19 13:29:05.186 (Värme Förstuga) Device sValue: '10'
2020-11-19 13:29:05.186 (Värme Förstuga) Device LastLevel: 10
2020-11-19 13:29:05.186 (Värme Förstuga) Device: 2 - ID: 2216, Name: 'Värme Förstuga - Thermostat Mode', nValue: 0, sValue: '10'
2020-11-19 13:29:05.186 (Värme Förstuga) Device ID: '2216'
2020-11-19 13:29:05.186 (Värme Förstuga) Device Name: 'Värme Förstuga - Thermostat Mode'
2020-11-19 13:29:05.186 (Värme Förstuga) Device nValue: 0
2020-11-19 13:29:05.186 (Värme Förstuga) Device LastLevel: 0
2020-11-19 13:29:05.186 (Värme Förstuga) Device: 3 - ID: 2217, Name: 'Värme Förstuga - Thermostat Pause', nValue: 0, sValue: ''
2020-11-19 13:29:05.186 (Värme Förstuga) Device ID: '2217'
2020-11-19 13:29:05.186 (Värme Förstuga) Device Name: 'Värme Förstuga - Thermostat Pause'
2020-11-19 13:29:05.186 (Värme Förstuga) Device sValue: ''
2020-11-19 13:29:05.186 (Värme Förstuga) Device: 4 - ID: 2218, Name: 'Värme Förstuga - Setpoint Normal', nValue: 0, sValue: '19.0'
2020-11-19 13:29:05.186 (Värme Förstuga) Device ID: '2218'
2020-11-19 13:29:05.186 (Värme Förstuga) Device Name: 'Värme Förstuga - Setpoint Normal'
2020-11-19 13:29:05.186 (Värme Förstuga) Device sValue: '19.0'
2020-11-19 13:29:05.186 (Värme Förstuga) Device: 5 - ID: 2219, Name: 'Värme Förstuga - Setpoint Economy', nValue: 0, sValue: '20'
2020-11-19 13:29:05.186 (Värme Förstuga) Device ID: '2219'
2020-11-19 13:29:05.186 (Värme Förstuga) Device Name: 'Värme Förstuga - Setpoint Economy'
2020-11-19 13:29:05.186 (Värme Förstuga) Device sValue: '20'
2020-11-19 13:29:05.202 (Värme Förstuga) Device: 6 - ID: 2220, Name: 'Värme Förstuga - Thermostat temp', nValue: 0, sValue: '18.8'
2020-11-19 13:29:05.202 (Värme Förstuga) Device ID: '2220'
2020-11-19 13:29:05.202 (Värme Förstuga) Device Name: 'Värme Förstuga - Thermostat temp'
2020-11-19 13:29:05.202 (Värme Förstuga) Device nValue: 0
2020-11-19 13:29:05.202 (Värme Förstuga) Device sValue: '18.8'
2020-11-19 13:29:05.202 (Värme Förstuga) Device LastLevel: 0
2020-11-19 13:29:05.202 (Värme Förstuga) Calling domoticz API: http://127.0.0.1:8080/json.htm?type=com ... rvariables
2020-11-19 13:29:05.186 Status: (Värme Förstuga) Entering work loop.
2020-11-19 13:29:05.186 Status: (Värme Förstuga) Initialized version 0.4.9, author 'logread'
2020-11-19 13:29:05.202 Status: (Värme Förstuga) This version of domoticz allows status logging by the plugin (in verbose mode)
2020-11-19 13:29:05.202 Status: (Värme Förstuga) Inside Temperature sensors = [204]
2020-11-19 13:29:05.202 Status: (Värme Förstuga) Outside Temperature sensors = [2066]
2020-11-19 13:29:05.202 Status: (Värme Förstuga) Heaters = [19]
2020-11-19 13:29:06.624 (Z-Stick) General/kWh (kWh Meter)
2020-11-19 13:29:06.686 (Z-Stick) Usage (Unknown)
2020-11-19 13:29:06.718 (Z-Stick) General/kWh (kWh Meter)
2020-11-19 13:29:11.640 (RFXCom) Temp + Humidity (Temp Sovrum N)
2020-11-19 13:29:11.999 (Z-Stick) Temp (Temp Badrum/Hall)
2020-11-19 13:29:15.436 (Värme Förstuga) Pushing 'onHeartbeatCallback' on to queue
2020-11-19 13:29:15.499 (Värme Förstuga) Processing 'onHeartbeatCallback' message
2020-11-19 13:29:15.499 (Värme Förstuga) Calling message handler 'onHeartbeat'.
2020-11-19 13:29:15.499 (Värme Förstuga) Calling domoticz API: http://127.0.0.1:8080/json.htm?type=dev ... order=Name
2020-11-19 13:29:15.561 (Värme Förstuga) device: 204-Temp Förstuga = 18.8
2020-11-19 13:29:15.561 (Värme Förstuga - Thermostat temp) Updating device from 0:'18.8' to have values 0:'18.8'.
2020-11-19 13:29:15.592 (Värme Förstuga) No Outside Temperature found...
2020-11-19 13:29:15.592 (Värme Förstuga) Inside Temperature = 18.8
2020-11-19 13:29:15.592 (Värme Förstuga) Outside Temperature = None
2020-11-19 13:29:15.592 (Värme Förstuga) End Heat time = 2020-11-19 13:47:15.592819
2020-11-19 13:29:15.592 (Värme Förstuga) Calling domoticz API: http://127.0.0.1:8080/json.htm?type=dev ... order=Name
2020-11-19 13:29:15.718 (Värme Förstuga) Heater switch 19 currently is 'Off'
2020-11-19 13:29:15.718 (Värme Förstuga) Heating 'On'
2020-11-19 13:29:15.718 (Värme Förstuga) Calling domoticz API: http://127.0.0.1:8080/json.htm?type=com ... itchcmd=On
2020-11-19 13:29:15.733 (Värme Förstuga) End Heat time = 2020-11-19 13:47:15.592819
2020-11-19 13:29:15.733 (Värme Förstuga) Calling domoticz API: http://127.0.0.1:8080/json.htm?type=com ... %3A%201%7D
2020-11-19 13:29:15.749 (Värme Förstuga - Setpoint Normal) Updating device from 0:'19.0' to have values 0:'19.0'.
2020-11-19 13:29:15.764 (Värme Förstuga - Setpoint Economy) Updating device from 0:'20' to have values 0:'20'.
2020-11-19 13:29:15.499 Status: (Värme Förstuga) Next calculation time will be : 2020-11-19 13:59:15.499503
2020-11-19 13:29:15.592 Status: (Värme Förstuga) Temperatures: Inside = 18.8 / Outside = None
2020-11-19 13:29:15.592 Status: (Värme Förstuga) Calculation: Power = 60.6 -> heat duration = 18 minutes
2020-11-19 13:29:25.686 (Värme Förstuga) Pushing 'onHeartbeatCallback' on to queue
2020-11-19 13:29:25.733 (Värme Förstuga) Processing 'onHeartbeatCallback' message
2020-11-19 13:29:25.733 (Värme Förstuga) Calling message handler 'onHeartbeat'.
I do not know if heating still works as expected but I am getting my e-mail folder full of Domoticz error messages, is there something obvious wrong here?
Thanks!!
Thanks!!
