Turning on switch based on two thermostats
Posted: Thursday 19 November 2020 11:45
by blader18
Hi guys,
Simple question here.
I have two thermostats. How can I create a condition to enable one switch if one of the thermostat is above a X temperature and the second thermostat is above Y themperature?
Thanks in advance.
Re: Turning on switch based on two thermostats
Posted: Thursday 19 November 2020 13:00
by waaren
blader18 wrote: ↑Thursday 19 November 2020 11:45
Hi guys,
Thanks in advance.
You probably need scripting to do that in domoticz.
Using dzVents it could look like below example
return
on =
devices =
'thermostat1', -- change your thermostat name
'thermostat2', -- change your thermostat name
logging =
level = domoticz.LOG_DEBUG, -- set to domoticz.LOG_ERROR when all ok
marker = 'multiple thermostats',
execute = function(dz)
local thermostat1 = dz.devices('thermostat1') -- change your thermostat name
local thermostat2 = dz.devices('thermostat2') -- change your thermostat name
local mySwitch = dz.devices('mySwitch') -- change your switch name
local xTemperature = 10
local yTemperature = 20
if thermostat1.setPoint > xTemperature and thermostat2.setPoint > yTemperature then
mySwitch.switchOn().checkFirst()
