Statistics on persistent data
Posted: Thursday 19 November 2020 0:02
by kubrik
i need help with statistical functions on persistent variables.
I've persistent data like this where i store historical temp and humidity for room/zone.
local obj1 = {
["Temp"] = {
[1] = {
["time"] = "2020-11-18 22:50:0.462";
["data"] = {
["hum"] = 73.1;
["zona"] = "Room1";
["temp"] = 20.8;
[2] = {
["data"] = {
["hum"] = 70.0;
["zona"] = "Room2";
["temp"] = 21.3;
[3] = {
["time"] = "2020-11-18 22:40:0.462";
["data"] = {
["hum"] = 75.0;
["zona"] = "Room1";
["temp"] = 19.7;
[4] = {
["data"] = {
["hum"] = 60.0;
["zona"] = "Room2";
["temp"] = 22.5;
[5] = {
["time"] = "2020-11-18 22:30:0.462";
["data"] = {
["hum"] = 60.0;
["zona"] = "Room1";
["temp"] = 22.5;
[6] = {
["data"] = {
["hum"] = 75.0;
["zona"] = "Room2";
["temp"] = 19.7;
How can i get, for example, the AVG "temp" for the "zona" Room1 using the statistical functions avg, avgSince..etc?
Thanks in advance!
Re: Statistics on persistent data
Posted: Thursday 19 November 2020 1:21
by waaren
kubrik wrote: Thursday 19 November 2020 0:02
You stored the historical data of multiple sensors in one table. The standard statistical dzVents functions cannot deal with that. You need to define the historical data per sensor or build your own statistical functions.
example script
return
on =
devices =
3, 19, 471, -- temperature sensors
logging =
level = domoticz.LOG_DEBUG,
marker = 'historical data',
data =
t3 = { history = true, maxMinutes = 60 },
t19 = { history = true, maxMinutes = 60 },
t471 = { history = true, maxMinutes = 60 },
execute = function(dz, item)
local idx = item.idx
-- add new data
dz.data['t' .. idx].add(item.temperature)
-- Check historical storage entries
if dz.data['t' .. idx].size < 3 then
dz.log('Not enough data points yet to produce something useful', dz.LOG_DEBUG)
dz.log(dz.data['t' .. idx].size .. ' entries for ' .. item.name .. ' in History', dz.LOG_DEBUG)
return
-- Calculate
-- average temperature in last 3 minutes
dz.log('Average temperature of ' .. item.name .. ' in last 3 minutes ' .. dz.utils.round(dz.data['t' .. idx].avgSince('00:03:00'),2), dz.LOG_DEBUG)
minutesStored = dz.data['t' .. idx].getOldest().time.minutesAgo
dz.log('Average temperature of ' .. item.name .. ' of all entries in history (' .. minutesStored .. ' minutes) ' ..
dz.utils.round(dz.data['t' .. idx].avg(),2), dz.LOG_DEBUG)
loglines from the example script
2020-11-19 01:17:40.393 Status: dzVents: Info: historical data: ------ Start external script: history.lua: Device: "Internal Temperature (Motherboard)", Index: 3
2020-11-19 01:17:40.408 Status: dzVents: Debug: historical data: Average temperature of Internal Temperature in last 3 minutes 49.33
2020-11-19 01:17:40.408 Status: dzVents: Debug: historical data: Average temperature of Internal Temperature of all entries in history (17 minutes) 49.08
2020-11-19 01:17:40.413 Status: dzVents: Info: historical data: ------ Finished history.lua
content of datafile of example script
- Spoiler: show
-- Persistent Data
local multiRefObjects = {
} -- multiRefObjects
local obj1 = {
["t3"] = {
[1] = {
["data"] = 50;
["time"] = "2020-11-19 0:17:40.245";
[2] = {
["data"] = 49;
["time"] = "2020-11-19 0:16:30.302";
[3] = {
["data"] = 49;
["time"] = "2020-11-19 0:15:20.267";
[4] = {
["data"] = 49;
["time"] = "2020-11-19 0:14:10.143";
[5] = {
["data"] = 49;
["time"] = "2020-11-19 0:13:0.233";
[6] = {
["data"] = 49;
["time"] = "2020-11-19 0:11:50.92";
[7] = {
["data"] = 49;
["time"] = "2020-11-19 0:10:40.128";
[8] = {
["data"] = 49;
["time"] = "2020-11-19 0:9:30.99";
[9] = {
["data"] = 49;
["time"] = "2020-11-19 0:8:20.46";
[10] = {
["data"] = 49;
["time"] = "2020-11-19 0:7:10.14";
[11] = {
["data"] = 49;
["time"] = "2020-11-19 0:6:0.982";
[12] = {
["data"] = 49;
["time"] = "2020-11-19 0:1:19.837";
[13] = {
["data"] = 49;
["time"] = "2020-11-19 0:0:9.803";
["t19"] = {
[1] = {
["data"] = 9.1000003814697;
["time"] = "2020-11-19 0:13:52.817";
[2] = {
["data"] = 9.3000001907349;
["time"] = "2020-11-19 0:3:52.300";
["t471"] = {
[1] = {
["data"] = 6.6999998092651;
["time"] = "2020-11-19 0:18:7.185";
[2] = {
["time"] = "2020-11-19 0:13:6.263";
[3] = {
["time"] = "2020-11-19 0:8:5.526";
[4] = {
["time"] = "2020-11-19 0:3:4.623";
return obj1
Posted: Thursday 19 November 2020 1:46
by kubrik
waaren wrote: Thursday 19 November 2020 1:21
You stored the historical data of multiple sensors in one table. The standard statistical dzVents functions cannot deal with that. You need to define the historical data per sensor.
Ok, thanks waaren.
example script
data =
And can i assign dynamic "t3", "t19", "t471" instead of static ones like in the example?
I have an init json filled with, for example, room name with its temp/hum sensor and other parameters.
I can add or remove elements from it.
So the data would be:
nameOfRoom1_Temp = { history = true, maxMinutes = 60 },
nameOfRoom1_Hum = { history = true, maxMinutes = 60 },
nameOfRoom2_Temp = { history = true, maxMinutes = 60 },
nameOfRoom2_Hum = { history = true, maxMinutes = 60 },
nameOfRoom3_Temp= { history = true, maxMinutes = 60 },
nameOfRoom3_Hum = { history = true, maxMinutes = 60 },
and so on.
where nameOfRoom is read from this json/array/variable...dynamic.
Posted: Thursday 19 November 2020 12:45
by waaren
kubrik wrote: Thursday 19 November 2020 1:46
No you cannot assign dynamic sensor names in historic persistent data like that. You will have to use a table and because of that you will loose the build-in statistical functions. Luckily you can define them yourself. See how in below example.
return
on =
devices =
3, 19, 471,10,456 -- temperature sensors
logging =
data =
temperatures = { history = true, maxMinutes = 60 },
local function buildHistoryRecord()
local t = {}
t.name = item.name
t.temperature = item.temperature
return t
-- homemade statistical function
local function avgSince(sensor, since)
local since = since or '9999:00:00' -- 9999 hours if not provided
local sensor = sensor or item -- defaults to item
local timeSlicedHistory = dz.data.temperatures.subsetSince(since)
local sumTemperature, recCounter = 0, 0
timeSlicedHistory.forEach(
function(record)
if type(record) == 'table' and record.data.name == sensor.name then
recCounter = recCounter + 1
sumTemperature = sumTemperature + record.data.temperature
end)
if recCounter == 0 then return -999 end -- prevent -nan return when 0 matching records
return dz.utils.round( sumTemperature / recCounter , 2)
-- Add temperature to persistent historical data
dz.data.temperatures.add(buildHistoryRecord())
-- Check number of historical storage entries
dz.log(dz.data.temperatures.size .. ' entries in History', dz.LOG_DEBUG)
-- Check age of oldest entry
local minutesStored = dz.data.temperatures.getOldest().time.minutesAgo
dz.log(minutesStored ..' minutes worth of data in history.' , dz.LOG_DEBUG)
-- get avgSince of current item
dz.log('Average temperature of ' .. item.name .. ' in last 12 minutes is ' .. avgSince(item, '00:12:00') .. ' °C')
-- get overal average of current item
dz.log('Average temperature of ' .. item.name .. ' is ' .. avgSince() .. ' °C')
Re: Statistics on persistent data [Solved]
Posted: Thursday 19 November 2020 14:02
by kubrik
Nice and clean example!
Thank you waaren
