It would be great if it was possible to trigger a device on a status or value of another device.
e.g. Blinds closes when the sun sensor is above a specific value, bathroom fan activates when humidity reaches a certain level, spot on the driveway activates when PIR senses moving during the night, etc.
I know you can do a lot with scripting, but I found out that the most easy one (dzvents) has his strange behaviors. It is also not userfriendly for people who are not familiar with scripting.
More options to trigger devices
- waaren
Re: More options to trigger devices
Can you please elaborate on what you call "strange behaviors"alexkoel wrote: Wednesday 18 November 2020 21:03 but I found out that the most easy one (dzvents) has his strange behaviors.
I might be able to explain / clarify.
alexkoel
I copied a very simple script and adjust it to my needs. It switched a light on when temerature was below 14 degrees. It worked. I changed the light to a blind and I received "attempt to call a nil value (field 'SwitchOff'". I changed switchoff() to close(), same result. I changed back to the light. Fault persists. I wasn't able to make the script working.
Not working script below:
timer = { 'every minute' } },
execute = function(domoticz)
local Sensor = domoticz.devices('Temp Druiven')
if Sensor.temperature < 14 then
domoticz.devices('SWD Staande lamp TV').SwitchOff()
}- waaren
Case matters...alexkoel wrote: Wednesday 18 November 2020 23:17 I copied a very simple script and adjust it to my needs. It switched a light on when temerature was below 14 degrees. It worked. I changed the light to a blind and I received "attempt to call a nil value (field 'SwitchOff'". I changed switchoff() to close(), same result. I changed back to the light. Fault persists. I wasn't able to make the script working.
The method SwitchOff() does not exist. Try again and use switchOff()
